Objects are not distorted by hair particle curves
Operating system: MacOs High Sierra 10.13.2
Graphics card: Intel Iris Graphics 6100
2.90.0 Alpha and earlier
Loaded object ignore length and direction of particle curves from Particle Edit
  1. Create mesh
  2. Add hair particle
  3. Open Render option
  4. Select Render As: Object
  5. Add Instance object
Blend file
You reported as addon bug.
What do I need to do??
Edit and change the tag to BF Blender
Richard Antalik (ISS) renamed this task from [Bug] Objects are not distorted by hair particle curves to Objects are not distorted by hair particle curves.Jul 8 2020, 2:44 AM
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Jul 8 2020, 3:06 AM
Oops did not want to confirm yet.
It looks like object is placed with origin at root and aligns Y axis with hair direction. Length does affect object as well.
Is this what you wanted to achieve?
Yes. Thanks! Is it normal that they don't bending?
Richard Antalik (ISS) closed this task as Archived.EditedJul 24 2020, 4:50 AM
Richard Antalik (ISS) claimed this task.
I will close this report then.
I think objects will not bend with this setup. I think it could be possibe to achieve with armature or some modifier, but I am not sure. You have to google some tutorial for this or ask at one of the community websites: https://www.blender.org/community/
