Sequencer - Force Orginal Size Image
Closed, ArchivedPublicPATCH
Hi All
I'm working on new functionality in Image strip properties.
New button "Orginal Size" have been added. When button is pressed Offset X and Y is possible to set.
By default when new image strip is added, image is scaled to render image size.
It was problem for may everyday work, because wenever i want to add smaller image than render window - like my logo I had to use transform strip to rescale image to orginal size or make image in orginal size to avoid scaling.
Now I can only press button and set Offset - This is simple solution for simple efect.
Please take a look at attached files:
seq_orginal_size_01.diff - patch
sequencer.jpg - secuencer
nosize_render.jpg - oryginal effect
size_render.jpg - render with forced orginal size
