Tiles missing in render in Cycles
Graphics card: Quadro 2000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 377.83
Broken: version: 2.83.2, branch: master, commit date: 2020-07-09 05:50, hash: rB239fbf7d936f
Worked: not found
during rendering short (about 320frames) animation in Cycles on CPU I've found twelve frames that were rendered badly. There are tiles missing in them- just blank space instead of render in these tiles.
  1. Open file
  2. Render
You may need to render few times or render animation. Majority of images should produce bug
Issue can not be reproduced when you disable subdiv modifier in Cube.012 object
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jul 15 2020, 1:04 AM
Can you upload simple example file?
ok, here is upload
Thanks for example file, I guess to reproduce we need to use hdr texture, is that correct? Also file is very slow to render. Can you simplify it as much as possible to reproduce problem as quickly as possible?
adrian (adi0) added a comment.EditedJul 17 2020, 2:00 AM
right, I forgot about hdr texture for environment. I used this one attached here. I'm not sure - how to simplify this .blend file ?
Delete any objects that doesn't cause bug. Usually you need only handful of elements to reproduce the issue
@adrian (adi0) could you provide a simplified blend? Otherwise this report will be closed.
adrian (adi0) added a comment.EditedJul 29 2020, 9:29 PM
I don't know how to make it simplier and which (if) objects casues the problem. Please verify problem with rendering on this file. As I said - problem happens on random frames and random time and different tiles are missing at the same frame rendered few times - it means I can render the same frame with different (good or bad) result without changing anything so I really don't know what causes the problem and what not delete
adrian (adi0) renamed this task from tales missing in render in Cycles to tiles missing in render in Cycles .Jul 29 2020, 11:02 PM
adrian (adi0) updated the task description. (Show Details)
We don't know either. I have been able to confirm issue now at least, but still don't know exactly what cause this. So far I got this file
It would definitely help us to strip it down further. deleting all objects seems to be too much.
I have swapped environment texture to check if that is problem and I got this result:
So tiles are not black, but rather coordinates are different somehow.
Had another go at this issue, found problematic object. If I disable subdiv modifier, the issue disappears, so perhaps there is some data corruption.
Reproducibility is now near 100%
Richard Antalik (ISS) renamed this task from tiles missing in render in Cycles to Tiles missing in render in Cycles .Aug 7 2020, 3:27 AM
Richard Antalik (ISS) changed the task status from Needs Information from User to Confirmed.
Richard Antalik (ISS) updated the task description. (Show Details)
@Richard Antalik (ISS) Hi, can you still reproduce it? Because I just tried it in 2.90 (release) and could not reproduce it...
Will have a look. Best way to check if issue is solved is to check with version mentioned in report to see if the issue is still there
Richard Antalik (ISS) closed this task as Resolved.Sep 8 2020, 2:10 AM
Richard Antalik (ISS) claimed this task.
Indeed this issue seems to be resolved in 2.90 release
