Operating system: windows 10
Graphics card: gtx1080
Broken version: Last release of 2.90 blender-2.90.0-75a09ba2ed26-windows64
Last Version where things were working well to my knowledge:
version: 2.90.0 Alpha, branch: master, commit date: 2020-06-01 20:37, hash: 1d4bae856690, type: Release
build date: 2020-06-01, 21:08:47
platform: Windows
The error is also not present in 2.83.2
Texture paint brush does not create line until the stroke is released from the screen.
This bug as far I could tell only happens with painting bump maps, I dont know if it could be triggered by other things tho,
I cant post the blend file because it contains nodes groups from a payed addon so I'm not sure if I should be sharing the nodes,
however as far as I can see it does seem to be a bug because on 2.83.2 and on older builds from 2.90
this problem does not exist, i.e. I can paint strokes like ones I'm trying to do on this video with not problems,
I just load the file and all works perfectly on those builds, the occasional lag does happen but this is an
entirely new problem.
So on the video you can see I try to paint strokes that create new height/bump maps by means of a bw mask and a bump node connection, however when I click on
the mesh to draw a shape only until I release the stroke does the lines get drawn, I can move the wacom stylus all over the mesh in texture paint mode
after I do the initial stroke, but Blender only draws the line until I release the stroke from the screen.
Something must have changed after the 2 of june on how some part of the texture paint systems work as the last build I have of 2.90 where I can
paint without this problem I think is from that date.
This is a link to a google drive folder that has one video showing the problem, and one showing how things should work, and a
zip file with the last Blender build of 2.90 were the problem was not present, maybe comparing this one to the current 2.90 build
where this is happening a solution could be found?
https://drive.google.com/drive/folders/1hUUQAjQ6aDGD9NUJzZlRVMld4-gpmtiM?usp=sharing
I hope this helps, Im really looking forward to having this working as I can't do the texture painting I need to do for work unless this is solved,
having to jump from the 2.90 build where this is not happening to the new one that has the Intel denoiser to do renders is very time consuming.
That being said even with the occasional bug Blender allows me to work for a living doing 3d, so Thank you for making Blender so Awesome
that I can do so many things with it :) Cheers!
