Changing dimension on multiple objects no-longer works
Confirmed, NormalPublicKNOWN ISSUE
Operating system: Windows
working version:
2.79b
Last known working version:
blender-2.80.0 Beta (dec 2018)
Hash: e4dbfe0a98c1
Bransh blender2.7
2.80.39
Earliest known broken version
blender-2.80.0 Beta (april 2019)
Hash: 480a09a92f7f
Bransh blender2.7
2.80.60→2.83.2→2.90.0 Alpha
Manipulating the values in ‘3d viewn-paneldimensions:' with ‘alt-key’ held down and dragging the mouse cursor will no-longer affect all the selected objects, only the parent.
(feature still present for 'Location', 'Rotation', 'Scale'.)
  1. Duplicate the default cube and move it so both cubes are visible.
  2. select both cubes and go to ‘3d viewn-panelDimensions:'
  3. With both cubes selected, hold down the alt-key and start manipulate the value by dragging your cursor in one of the three fields for 'Dimensions'
PS. feature did not have the same affect as just scaling the objects, (see animated gif bellow)
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jul 21 2020, 7:10 AM
@Campbell Barton (campbellbarton) Since I'm working on these dimensions buttons in D8681 anyway, do you see a way to make them work for multiple objects? Since they're not RNA buttons I would probably doubt it, but maybe that functionality is available.
If not, I will classify this as a known issue.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Oct 14 2020, 5:22 PM
@Hans Goudey (HooglyBoogly) I don't think there is a straightforward solution here, we could set the RNA pointer+property which can work on a basic level. Then we run into the bugs we had when this used to b RNA, where setting multiple values at once failed.
@Campbell Barton (campbellbarton) Okay, that's what I figured, I just wanted to make sure I wasn't missing anything. Seems fine to keep this as a known issue then.
