- rBe7acf17b745 Nodes Add emitters events forces and control flow socket types (Jacques Lucke)
- rB9f7bea6e839 Simulations UI for core particle nodes (Jacques Lucke)
- rBb78f2675d7e Simulations Use some shader nodes in simulation node trees (Jacques Lucke)
- rB8dbbac43bb3 Simulations Add Boolean Math Switch and Float Compare node UI (Jacques Lucke)
- rBb55c78a289c Simulation Add modifier to access simulation data (Jacques Lucke)
- rB838e1f248d8 Nodes add Combine Strings and Group Instance ID node UIs (Jacques Lucke)
- rB1e999c7bdb6 Particles: initial Quick Particles operator (Jacques Lucke)
- rB396d0b5cd0b Particles new Age Reached Event Kill Particle and Random Float node (Jacques Lucke)
- rB4cad74e589f Particles add Size attribute (Jacques Lucke)
- rB9c807325ddf Particles rename Size attribute to Radius (Jacques Lucke)
- rB7cd2c1fd2e7 Particles support custom particle events in solver (Jacques Lucke)
Related Objects
Related Objects
- Mentioned In
- T81708: Experimental Features Documentation
- Mentioned Here
- rB4cad74e589f7: Particles: add Size attribute
rB9c807325ddff: Particles: rename Size attribute to Radius
rB7cd2c1fd2e7a: Particles: support custom particle events in solver
rB396d0b5cd0bc: Particles: new Age Reached Event, Kill Particle and Random Float node
rB1e999c7bdb63: Particles: initial Quick Particles operator
rBe7acf17b7458: Nodes: Add emitters, events, forces and control flow socket types
rB9f7bea6e8396: Simulations: UI for core particle nodes
rBb78f2675d7e5: Simulations: Use some shader nodes in simulation node trees
rB8dbbac43bb38: Simulations: Add Boolean Math, Switch and Float Compare node UI
rB838e1f248d84: Nodes: add Combine Strings and Group Instance ID node UIs
rBb55c78a289c6: Simulation: Add modifier to access simulation data
