Grease Pencil strokes bugs
Broken: Blender 2.83.3, the same issue was in Blender 2.83.2
Worked: Blender 2.82.7
Strokes always converge to origin plane.
  1. Open File
  2. Switch to side view
  3. Make a stroke originating from existing stroke (as in picture)
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Aug 4 2020, 6:32 AM
Could you explain this in a bit more detail? Perhaps provide a screenshot or recording to ilustrate the bug. But detailed steps would be better.
Still can't reproduce. I assume you used only mirror modifier here.
Are there any settings I need to enable to reproduce the issue?
I am using the default scene settings + mirror modifier. That's all.
Sounds weird, that you can't reproduce this issue.
Could you record your screen and paste here. I would like to see how all looks from your side. I want to be sure that we think about the same issue :)
I can make screen recording, but please upload file that does exhibit this issue so we can be 100% sure we are testing with same settings
ok, how I suppose, you still don't get what is the issue :)
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Information from Developers.Aug 13 2020, 12:21 PM
Richard Antalik (ISS) updated the task description. (Show Details)
@Antonio Vazquez (antoniov) I am not sure if this is bug or intentional change. Can you look into this?
I don't see the problem with Stroke mode.
Richard Antalik (ISS) closed this task as Archived.Aug 13 2020, 1:38 PM
Richard Antalik (ISS) claimed this task.
@Antonio Vazquez (antoniov) Thanks for example. So setting snapping to first point seems to be the issue. In 2.82 this seems to work different, that's why I confirmed.
I will close this since it is working as expected now.
