Drivers graph not updating immediately
Operating system: Windows 10
Graphics card:
Broken: 2.83.3
Drivers pane doesn't refresh immediately
  1. make some object with a shape key transformation
  2. add an empty to use as driver for the shape key
  3. assign Z-translation of the empty to the shapekey value as driver
  1. split the screen so you can see both the 3D viewport and the Drivers pane
(deactivate "only show selected" in the drivers pane so we can see what is happening in the graph at all times)
4 a) WORKING: translate the empty on Z-axis --> the dot on the graph moves
4 b) NOT WORKING (until you click in the viewport) -->use the "N" panel in the 3D viewport. Use the Z-location slider.
The Driver viewport gets not updated until the user clicks somewhere in the 3D viewport.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Aug 4 2020, 8:04 AM
Please upload example file.
More than a week without reply or activity.
Due to the policy of the tracker closing for until required info/data are provided.
If the problem persists please open a new report with the required information.
