Multires artifacts when undo
Closed, DuplicatePublic
Operating system: Windows 10
Graphics card:
Broken: blender-2.91.0-144f780c71ed-windows64
Worked: quadro m1000m
Somehow the multires is showing weird artifacts when you undo
open blender
add a monkey
go to sculpt mode
add a multires and subdivide a few times
choose the clay strips brush and make the brush size a little bigger
perform a few "extreme" brush strokes and then undo
artifacts will start to show up. and if you keep doing this, more and more artifacts will appear
dupli of T79487
No, it doesn't look like the same issue. I'm not switching levels here.
Hello I am a user, I did the steps exactly the same in the version that you have which is blender-2.91.0-144f780c71ed-windows64, but when downloading the latest Alpha which is blender-2.91.0-6791b88d2805-windows64 and it did not generates no error, you could download the latest Alpha to see how it gives, but to me it does not generate an error in the latest version but the previous one if I generate the same error of yours, tells us how it went.
Sometimes it doesn't happen on the first try. You need to keep doing it.
Here with the latest alpha version:
For the community, a big greeting for everyone: I generate the same error as indicated in the user video @Nelson (NAS) with the Alpha version blender-2.91.0-6791b88d2805-windows64, thank you very much to you @Nelson (NAS) and to the community.
Even though it has different steps than the T79487, I'm pretty sure it's the same problem.
Switching levels may trigger the problem more often.
So I will merge the reports.
If that is resolved but this is not, then it can be reopened.
