Crop and transparent in render
System Information:
Operating system: Windows 10
Graphics card: RTX 2080Ti
CPU: Intel i9 9900K
Blender Version:
Broken: Last 2.90 Beta 4f59e4bddcb0
Worked: 2.82a
Short description of the error:
Rendering an image, gives a crop in the image from the left bottom and gives a transparent part in the right up of the image (see the image examples).
I have delete everything from my scene to isolate the problem but seems that even like that the problem is still there.
Exact steps for others to reproduce the error:
Open the file render bug.blend in the Blender 2.9 and then press F12 and render the image and you will see a crop in the image from the left bottom and gives a transparent part in the right up of the image.
You can also open the same file in 2.82a and do a render image and you will not see the problem.
Alaska (Alaska) closed this task as Resolved.Aug 7 2020, 11:39 PM
Alaska (Alaska) claimed this task.
Alaska (Alaska) added a subscriber: Alaska (Alaska).
This issue has been fixed with rB58909abc685b. Wait until that version is avaliable through the build bot then test again. If you continue to experience issues, please open a new report,
