OS: Windows 10 Home
CPU: AMD Ryzen 7 2700X
RAM: 32gb
GPU: Nvidia RTX 2080 8gb
Broken: 2.90.0 Beta
Worked: 2.83.4
If viewport shading is in rendered mode (Cycles) and VDB object cache frame is changed Blender crashes. Can be reproduced with VDB sequence in scene and scrubbing timeline or with sequence option off and change the loaded cache frame manually by changing filename frame number.
Download this VDB sample (or any other) to use in sample Blender file to reproduce crashes:
https://jangafx.com/software/embergen/download/free-vdb-animations/
File: Simple Fire (65mb)
Sample Blender file:
- Load sample VDB file in VDB object
- Change 3D viewport shading to rendered
- Scrub timeline CRASH
or
- Disable Sequence option and manually change frame number in loaded VDB filename. CRASH
