Gpencil. Additive drawing doesn't work when creating fills
Closed, ResolvedPublicBUG
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-09 00:04, hash: rBb522e834ec30
With the additive drawing switch turned on, creating a fill on a new keyframe doesn't preserve fills or strokes from the previous keyframe.
Expected: with additive drawing switch turned on, creating a fill on a new frame would create a new keyframe that included all strokes and fills from the previous keyframe, plus the new fill.
  • open attached blend file
  • tap in the right-hand shape to fill it
  • fills and stroked from the previous fills layer keyframe aren't preserved in the new keyframe that was created.
Antonio Vazquez (antoniov) claimed this task.
Additive drawing is by layer, so only the active layer is affected. If you have the fill in a different layer, this layer is not included. To do what you want, we would need add an option to enable additive for all layers, but this cannot be consider as a bug, but as a feature request.,
Anyway, you can use I key menu, to duplicate your drawings.
Thanks for the report, bu following the policies of this website, I must close it because it cannot be consider a bug.
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Yes. the bug report is about the active layer only. Adding a fill doesn't preserve strokes or fills from the previous keyframe on the active layer, as i believed 'additive drawing' was supposed to do.
Antonio Vazquez (antoniov) reopened this task as Needs Triage.Aug 14 2020, 6:06 PM
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Confirmed.Aug 14 2020, 6:09 PM
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Bug".
Ah, I see... I had missunderstood the bug.
