Blender 2.81 - 2.90: Applying more than one material on a mesh object does not work on Linux System
Closed, DuplicatePublic
Operating system: Linux-5.0.0-15-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: AMD TAHITI (DRM 2.50.0, 5.0.0-15-generic, LLVM 10.0.1) X.Org 4.5 (Core Profile) Mesa 20.2.0-devel (git-e2e89fb 2020-07-25 bionic-oibaf-ppa)
Broken: version: >2.81, 2.83.4, branch: master, commit date: 2020-08-05 06:00, hash: rBc113af82881a, blender-2.90.0-c300fc56c3cc-linux64
Worked: blender-2.80-linux-glibc217-x86_64
Origin is a double cube with two others and assigned materials.
Shading Tab -> Material Properties icon
Plus sign -> New button (Add a new material)
Edit Mode -> Face selected -> Assign button
In edit mode, both assigned parts are visible. After switching to the object mode, the one assigned to the second material disappears.
Only first material is rendered. If materials order is swapped then another is rendered (always first).
This issue affects versions: 2.81 - 2.83.4, in: solid mode, material mode and render preview (Eevee).
In: vieport shading mode and render preview (Cycles) is OK
In the earlier version 2.80, both materials were rendered correctly
Related bug reports
T72228, T68826, T70106
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Aug 16 2020, 11:45 AM
It seems you're using a development version of Mesa from a PPA. Have you checked if this issue also occurs when using a stable/official release?
@Robert Guetzkow (rjg): Due to other dependencies, I couldn't install the previous stable version. I just add that I have upgraded the system, the kernel and upgraded the version to Mesa 20.3.0-devel (git-6668d7a 2020-08-16 bionic-oibaf-ppa). Unfortunately, I still have same problem. I'm beginning to suspect that it may have something to do with the graphics card (Asus R9280X-DC2T-3GD5), and not only on Linux. I checked on the old Windows 7 system and the lower part of the cube is displayed, but strange artifacts appear. Before that, I didn't see any problems with 3D games. In 2.80 I can see the model correctly. Strange
The graphics chip in that GPU is Radeon™ R9 280 which has the GCN first generation micro-architecture. It meets the minimum requirements as far as I can tell.
Robert Guetzkow (rjg) changed the task status from Needs Information from User to Needs Triage.Aug 30 2020, 1:16 AM
