HardOps and BoxCutter issue with missing icons on Mac when using workbench
Closed, DuplicatePublic
Operating system: MacOS 10.15.6 Catalina
Graphics card: AMD Radeon Pro 5700 XT 16 GB
Broken: 2.83.4 2020-08-05
(example: 2.79b release)
When working in workbench, icons are missing in some add-ons like boxcutter and hardops. Both are the most recent versions 7.16.15 Catlin and 9 MercuryX respectively. When changing workbench, to EEVEE, the icons show up normally.
I normally work on workbench. I installed first HardOps following the instructions to unzip file directly inside the add-on folder of blender. Installed box cutter normally by using blenders add on installer in the preferences panel. I uninstalled and reinstalled both apps in different ways and I always got the same error. That is until I switched to EEVEE. Restarting the app again in workbench makes the icons disappear again.
