Fluid is not working on large domains
Operating system: macOS Big Sur - Macbook Pro 15 2015-mid - Core i7.
Graphics card: Intel Iris Pro 1536 MB
Broken: 2.90 0330d1af29c0 2020-08-31 11:26 Master
Fluid simulation doesn't work if domain is in larger than 64x64x64m .
  • Does work
    • Create a new file
    • Create a cube if deleted the default one. (Its current dimension are 2x2x2m) let's call it Small Cube
    • Don't scale it or do anything with it, Just press Shift+D (Duplicate it)
    • Scale the second cube, almost 10x (dimension are 20x20x20m) - let's call it Large Cube
    • Large Cube is selected -> Physics Properties -> Fluid -> (type: Domain) + (Domain Type: Liquid) + (Cache -> type: Modular)
    • Select the Small Cube -> Physics Properties -> Fluid -> (type: Flow) + (Flow Type: Liquid) + (Flow Behavior: Inflow).
    • Select Large Cube and hit -> Physics Properties -> Bake Date
    • It does simulate water.
  • Doesn't Work
    • Same set as above
    • Select the Large Cube and Scale it almost 32x (dimension are 64x64x64m)
    • Select the Large Cube and hit -> Physics Properties -> Bake Date
    • It does not simulate water.
  • Does Work
    • Select the Large Cube and Scale it almost 31x (dimension are 62x62x62m)
TIP : You can also scaleup the particle size ... in Particle Properties -> Liquid -> (Viewport Display) size
Please find the attached fluid_issue.blend file. and simulate 3 different Fluid Setups with three scales 20x20x20m (Working) / 62x62x62m (Working) / 64x64x64m (Not working)
screenshot to match the view.
Muhammad Farooqi (mfarooqi) claimed this task.
I'm sorry.. Please ignore this bug or issue. This was my fault.... the resolution division were limited to 32... I raised that and it started simulating now.
