Operating system: Mackbook Pro / Catalina - Processor 2.9 GHz 6 Core Intel Core i9. - Memory 32 GB 2400 MHz DDR4
Graphics card: Radeon Pro 560X 4 GB. INTEL UHD Graphics 630 1536 MB
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Has worked before on Blender 2.83. Now on 2.90 crashes every time trying to Render
Error Message after crashing below... Basically, I try to Render out in EEVEE, it starts the Render process, crashes about 20-30 minutes into process. I have Rendered this before in 2.83. I have re-tried to render in 2.83 and does NOT work.
Render whole animation. Computer will crash after 20-30 minutes.
0 org.blenderfoundation.blender 0x000000010af31908 BLI_memblock_elem_get + 40 1 org.blenderfoundation.blender 0x0000000103f024f9 drw_draw_pass_ex + 1497 2 org.blenderfoundation.blender 0x0000000103f01f0f DRW_draw_pass + 31 3 org.blenderfoundation.blender 0x0000000103f211db EEVEE_shadows_draw_cascades + 4635 4 org.blenderfoundation.blender 0x0000000103f1fba0 EEVEE_shadows_draw + 352 5 org.blenderfoundation.blender 0x0000000103f1a5a5 EEVEE_render_draw + 805 6 org.blenderfoundation.blender 0x0000000103f0d5c5 eevee_render_to_image + 981 7 org.blenderfoundation.blender 0x0000000103ef9c8a DRW_render_to_image + 538 8 org.blenderfoundation.blender 0x00000001093b5800 RE_engine_render + 1152 9 org.blenderfoundation.blender 0x00000001093bf69e do_render_all_options + 350 10 org.blenderfoundation.blender 0x00000001093c1894 RE_RenderAnim + 2148 11 org.blenderfoundation.blender 0x0000000104ee95e3 render_startjob + 99 12 org.blenderfoundation.blender 0x0000000103dbdca7 do_job_thread + 39 13 libsystem_pthread.dylib 0x00007fff6e975109 _pthread_start + 148 14 libsystem_pthread.dylib 0x00007fff6e970b8b thread_start + 15
Process: Blender [1120]
Path: /Volumes/VOLUME/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.90.0 (2.90.0 2020-08-26)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [1120]
User ID: 501
Date/Time: 2020-09-02 20:15:48.537 -0700
OS Version: Mac OS X 10.15.5 (19F101)
Report Version: 12
Bridge OS Version: 4.6 (17P6610)
Anonymous UUID: C2AA1430-1FA5-7D63-1099-462EA9E30BF4
Sleep/Wake UUID: 7CD05320-22FA-4BFA-AFDD-483C77B12264
Time Awake Since Boot: 6500 seconds
Time Since Wake: 5200 seconds
System Integrity Protection: enabled
Crashed Thread: 28
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fbe1390b608
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1120]
VM Regions Near 0x7fbe1390b608:
MALLOC_SMALL 00007fbe13000000-00007fbe13800000 [ 8192K] rw-/rwx SM=PRV
MALLOC_TINY 00007fbe13c00000-00007fbe13d00000 [ 1024K] rw-/rwx SM=PRV
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff6e8b4882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff6e975425 _pthread_cond_wait + 698
2 org.blenderfoundation.blender 0x000000010afa452b BLI_ticket_mutex_lock + 59
3 org.blenderfoundation.blender 0x0000000103efbfd2 DRW_opengl_context_enable_ex + 34
4 org.blenderfoundation.blender 0x0000000109970808 GPU_viewport_bind + 56
5 org.blenderfoundation.blender 0x0000000103da8ae1 wm_draw_update + 1649
6 org.blenderfoundation.blender 0x0000000103da6780 WM_main + 48
7 org.blenderfoundation.blender 0x0000000103a68292 main + 914
8 libdyld.dylib 0x00007fff6e770cc9 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff6e8b1e36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff6e717aed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff6e717fbf _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x0000000109488512 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x000000010948707e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff6e975109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff6e970b8b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff68345b16 caulk::mach::semaphore::wait() + 16
2 com.apple.audio.caulk 0x00007fff683459b2 caulk::semaphore::timed_wait(double) + 106
3 com.apple.audio.caulk 0x00007fff683457c4 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff683451e4 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 14:
Thread 15:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff6e8b1dfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6e8b2170 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff33ff2c75 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff33eeef18 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 2677
4 com.apple.audio.CoreAudio 0x00007fff34022c22 HALB_IOThread::Entry(void*) + 72
Thread 16:
1 org.blenderfoundation.blender 0x0000000103d9d338 tbb::internal::rml::private_worker::run() + 104
2 org.blenderfoundation.blender 0x0000000103d9d2c9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff3490ef85 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff3490da52 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff3490cece CFRunLoopRunSpecific + 462
5 com.apple.AppKit 0x00007fff31d25144 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff6e975109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff6e970b8b thread_start + 15
Thread 28 Crashed:
Thread 29:
2 org.blenderfoundation.blender 0x000000010a923fcb threadpool_thread + 139
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
2 org.blenderfoundation.blender 0x000000010a92377d lookahead_thread + 221
Thread 51:
2 libomp.dylib 0x0000000114300c7d __kmp_suspend_64 + 269
3 libomp.dylib 0x00000001142ea954 kmp_flag_64::wait(kmp_info*, int, void*) + 1460
4 libomp.dylib 0x00000001142e7338 __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*) + 152
5 libomp.dylib 0x00000001142ea03d __kmp_fork_barrier(int, int) + 445
6 libomp.dylib 0x00000001142cdf8c __kmp_launch_thread + 428
7 libomp.dylib 0x00000001142ff8ba __kmp_launch_worker(void*) + 330
8 libsystem_pthread.dylib 0x00007fff6e975109 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff6e970b8b thread_start + 15
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
Thread 79:
Thread 80:
Thread 81:
Thread 82:
Thread 83:
Thread 84:
Thread 85:
Thread 86:
Thread 87:
Thread 88:
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
Thread 111:
Thread 112:
Thread 113:
Thread 114:
Thread 115:
Thread 116:
Thread 117:
Thread 118:
Thread 119:
Thread 120:
Thread 121:
Thread 122:
Thread 123:
Thread 124:
Thread 125:
Thread 126:
Thread 127:
Thread 128:
Thread 129:
Thread 130:
Thread 131:
Thread 132:
Thread 133:
Thread 134:
Thread 135:
Thread 136:
Thread 137:
Thread 138:
Thread 139:
Thread 140:
Thread 141:
Thread 142:
Thread 143:
Thread 144:
Thread 145:
Thread 146:
Thread 147:
Thread 148:
Thread 149:
Thread 150:
Thread 151:
Thread 152:
Thread 153:
Thread 154:
Thread 155:
Thread 156:
Thread 157:
Thread 158:
Thread 159:
Thread 160:
Thread 161:
Thread 162:
Thread 163:
Thread 164:
Thread 165:
Thread 166:
Thread 167:
Thread 168:
Thread 169:
Thread 170:
Thread 171:
Thread 172:
Thread 173:
Thread 174:
0 libsystem_pthread.dylib 0x00007fff6e970b68 start_wqthread + 0
Thread 175:
0 libsystem_kernel.dylib 0x00007fff6e8b1e4e semaphore_timedwait_trap + 10
1 libdispatch.dylib 0x00007fff6e717b6b _dispatch_sema4_timedwait + 76
2 libdispatch.dylib 0x00007fff6e717f97 _dispatch_semaphore_wait_slow + 58
3 libdispatch.dylib 0x00007fff6e725795 _dispatch_worker_thread + 284
4 libsystem_pthread.dylib 0x00007fff6e975109 _pthread_start + 148
5 libsystem_pthread.dylib 0x00007fff6e970b8b thread_start + 15
Thread 28 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000020 rdx: 0x0000000000000000
rdi: 0x00000000001dff80 rsi: 0x00007fbe12a0ba08 rbp: 0x0000700008c65930 rsp: 0x0000700008c65930
r8: 0x0000000000000000 r9: 0x0000000000000200 r10: 0x0000000000000210 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000103f02bc0 r14: 0x00007fbcac081be0 r15: 0x0000000000000000
rip: 0x000000010af31908 rfl: 0x0000000000010206 cr2: 0x00007fbe1390b608
Logical CPU: 0
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Binary Images:
0x103927000 - 0x10d98ff5f +org.blenderfoundation.blender (2.90.0 - 2.90.0 2020-08-26) <FD165047-B2B8-3AF9-9EB9-A629FFA6E97E> /Volumes/VOLUME/Blender.app/Contents/MacOS/Blender
0x1142ab000 - 0x114317ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Volumes/VOLUME/Blender.app/Contents/Resources/lib/libomp.dylib
0x114a07000 - 0x114a09ff3 com.apple.CloudDocsFileProvider (1.0 - 698.14) <96DFA9EF-1BA8-3A50-B30B-72773341B00B> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x114a12000 - 0x114a15fff com.apple.FileProviderOverride (304.1 - 304.1) <198EE5E5-B1B9-3223-8E23-1DFF89A553FA> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x114a38000 - 0x114ac9eff dyld (750.5) <E4698FBD-806A-3396-B279-E685BA37430B> /usr/lib/dyld
0x118c84000 - 0x118dddff7 com.apple.audio.units.Components (1.14 - 1.14) <AFECE153-6FBF-307E-8DC7-AD29AC611EA4> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x118e10000 - 0x119270fff com.apple.audio.AudioDSPComponents (1.0 - 1) <0678D586-9249-3019-8A02-53AA8B7F0207> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
0x1192dd000 - 0x1192e0047 libobjc-trampolines.dylib (787.1) <8212B354-A106-3806-A022-A60F2B2FA5C9> /usr/lib/libobjc-trampolines.dylib
0x119353000 - 0x119419fff com.apple.AMDRadeonX4000GLDriver (3.9.15 - 3.0.9) <35DFDCB5-77BC-3216-A42B-CC4B31B9E63E> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x11dd4e000 - 0x11dd4fff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Volumes/VOLUME/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
0x11dd98000 - 0x11dd9dffb +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Volumes/VOLUME/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
0x11eb4d000 - 0x11eb64ffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.5.10) <CF308A32-9994-3092-81F4-DE59438CD142> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff2797d000 - 0x7fff27bcaff8 com.apple.RawCamera.bundle (9.02.0 - 1350.29) <0CC24FF1-0754-3A75-BA2D-212CF70ADDC1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff27bcd000 - 0x7fff27cfbff0 com.apple.AMDMTLBronzeDriver (3.9.15 - 3.0.9) <D901C675-0E10-38B7-975A-82BB92383B60> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff27cfc000 - 0x7fff27d32fff ATIRadeonX4000SCLib.dylib (3.9.15) <8EF3D12C-FC1A-31AF-BDDA-7F697AE1BAB7> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff2920c000 - 0x7fff29b8dffb libSC.dylib (3.9.15) <8B9CE960-1CF4-3618-8B5D-2A231D185639> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff2c287000 - 0x7fff2d28eff7 com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.6.18 - 14.0.6) <B049C672-7CE4-3251-937E-99D0A84430D7> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff2d28f000 - 0x7fff2d68eff1 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.6.18 - 14.0.6) <568AB53D-A275-3FAC-932C-A32C3E277CA3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff3012e000 - 0x7fff30329ffb com.apple.avfoundation (2.0 - 1850.2) <4820F165-5E20-3120-913D-C047FDB68392> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3032a000 - 0x7fff303f6ffe com.apple.audio.AVFAudio (1.0 - 415.72) <C0FE6926-F8E6-339A-9D11-C6E3BEE688BF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff30516000 - 0x7fff30516fff com.apple.Accelerate (1.11 - Accelerate 1.11) <56DFF715-6A4E-3231-BDCC-A348BCB05047> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff30517000 - 0x7fff3052dfef libCGInterfaces.dylib (524.2.1) <A423F932-C044-3CEB-BF20-BF4CB323361E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3052e000 - 0x7fff30b84fff com.apple.vImage (8.1 - 524.2.1) <17C93AB9-1625-3FDB-9851-C5E77BBE3428> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff30b85000 - 0x7fff30decff7 libBLAS.dylib (1303.60.1) <CBC28BE4-3C78-3AED-9565-0D625251D121> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff30ded000 - 0x7fff312c0fef libBNNS.dylib (144.100.2) <8D653678-1F9B-3670-AAE2-46DFB8D37643> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff312c1000 - 0x7fff3165cfff libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3165d000 - 0x7fff31672fec libLinearAlgebra.dylib (1303.60.1) <D2C1ACEA-2B6A-339A-9EEB-62A76CC92CBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff31673000 - 0x7fff31678ff3 libQuadrature.dylib (7) <3112C977-8306-3190-8313-01A952B7F3CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff31679000 - 0x7fff316e9fff libSparse.dylib (103) <40510BF9-99A7-3155-A81D-6DE5A0C73EDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff316ea000 - 0x7fff316fcfef libSparseBLAS.dylib (1303.60.1) <3C1066AB-20D5-38D2-B1F2-70A03DE76D0B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff316fd000 - 0x7fff318d4fd7 libvDSP.dylib (735.121.1) <74702E2E-ED05-3765-B18C-64BEFF62B517> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff318d5000 - 0x7fff31997fef libvMisc.dylib (735.121.1) <137558BF-503D-3A6E-96DC-A181E3FB31FF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff31998000 - 0x7fff31998fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D7E8E400-35C8-3174-9956-8D1B483620DA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff31999000 - 0x7fff319f8ff0 com.apple.Accounts (113 - 113) <0510C893-F1F2-38B2-B3AA-A30DB2F5B688> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff31b42000 - 0x7fff32902ffd com.apple.AppKit (6.9 - 1894.50.103) <61269B8C-C432-335F-8894-B95C235A41A5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff32952000 - 0x7fff32952fff com.apple.ApplicationServices (48 - 50) <EEC73694-1A37-3C14-A839-6991E2BD8655> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff32953000 - 0x7fff329befff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <A6912C4A-55CC-3701-BACA-E63423B99481> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff32a57000 - 0x7fff32a95ff0 libFontRegistry.dylib (274.0.5.1) <A78A7869-C96C-3AD6-A038-DE541639BB60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff32af0000 - 0x7fff32b1ffff com.apple.ATSUI (1.0 - 1) <4B3C2201-DBB3-352C-936B-9C423122EFF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff32b20000 - 0x7fff32b24ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <47D42CDE-2E9A-3AF6-9365-1BFD1189196B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff32bbe000 - 0x7fff32c15ffa com.apple.HIServices (1.22 - 675.1) <273492E3-FF0F-3A8A-A83F-0F11F99B5F26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff32c16000 - 0x7fff32c24fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <DA175323-5BE3-3C54-92D4-A171A4A067E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff32c25000 - 0x7fff32c6affa com.apple.print.framework.PrintCore (15.4 - 516.2) <99AEBCDB-2DCA-3A13-906F-7F0D7962B002> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff32c6b000 - 0x7fff32c75ff7 com.apple.QD (4.0 - 413) <D2E1DC80-D26F-3508-BBA5-B8AE7ED6CB0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff32c76000 - 0x7fff32c83ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <823C0DE7-1351-3B39-8F06-AB5FCAD2C874> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff32c84000 - 0x7fff32d65ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <75651F0A-F2CE-3F68-B86A-E66B8815DCF4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff32d67000 - 0x7fff32d67fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <E51DCB3C-CF4F-320B-AC86-D445E30C0891> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff330fd000 - 0x7fff3348bffd com.apple.CFNetwork (1126 - 1126) <BB8F4C63-10B8-3ACD-84CF-D4DCFA9245DD> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff33507000 - 0x7fff33507fff com.apple.Carbon (160 - 162) <4F1F60CB-6C1E-3D79-832E-8D606601F282> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff33508000 - 0x7fff3350bff3 com.apple.CommonPanels (1.2.6 - 101) <333BBF55-AF23-3B99-A9FF-7906175B9406> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3350c000 - 0x7fff33800ff3 com.apple.HIToolbox (2.1.1 - 994.6) <5C44ACA7-D158-3F9B-8F88-0477510D44FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff33801000 - 0x7fff33804ff3 com.apple.help (1.3.8 - 71) <4B2701A0-8813-35F8-82F8-676B184D15C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff33805000 - 0x7fff3380aff7 com.apple.ImageCapture (9.0 - 1600.60.4.2) <20872A2D-CBF9-38E6-BD16-C1D387120651> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3380b000 - 0x7fff3380bfff com.apple.ink.framework (10.15 - 227) <5B60FDDE-D60E-326B-BD3D-6EA5FA1CBB76> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3380c000 - 0x7fff33826ffa com.apple.openscripting (1.7 - 185.1) <E59F893B-1A73-3098-8924-79227EC9787E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff33847000 - 0x7fff33847fff com.apple.print.framework.Print (15 - 271) <07C50BF6-2222-3769-A5B8-79D7F996183F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff33848000 - 0x7fff3384aff7 com.apple.securityhi (9.0 - 55008) <D7017D5A-4206-3E2F-9F8E-0F932422CA87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3384b000 - 0x7fff33851fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1188E643-967C-334E-BC1A-60A0F82C67E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff33852000 - 0x7fff339eaffa com.apple.cloudkit.CloudKit (867 - 867) <C68C376E-E2CF-34FE-BC1F-B254233F980D> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff339eb000 - 0x7fff339ebfff com.apple.Cocoa (6.11 - 23) <87426C3A-7C6C-39D0-905C-C591B997029E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff339f9000 - 0x7fff33aeffff com.apple.ColorSync (4.13.0 - 3394.9) <61698A7B-BB8C-3891-9547-703FF84671A8> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff33dda000 - 0x7fff342e3ffb com.apple.audio.CoreAudio (5.0 - 5.0) <62BEE4B7-8A26-3951-9D78-4E193617AF7A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff34336000 - 0x7fff3436efff com.apple.CoreBluetooth (1.0 - 1) <6BC7F863-4495-371F-BC54-543E5CFE1665> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3436f000 - 0x7fff34759fe8 com.apple.CoreData (120 - 977.3) <D902A2E3-1D0A-3995-974E-A526976E5735> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff3475a000 - 0x7fff3488affe com.apple.CoreDisplay (1.0 - 186.6.12) <EA74CC46-8715-3B90-95E8-4594D2F0CC8A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff3488b000 - 0x7fff34d0affb com.apple.CoreFoundation (6.9 - 1676.105) <6AF8B3CC-BC3F-3869-B9FB-1D881422364E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff34d0c000 - 0x7fff35380ff8 com.apple.CoreGraphics (2.0 - 1355.17) <E1CE3919-F36B-309F-89BA-79F36DC8125E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3538e000 - 0x7fff356e9ff0 com.apple.CoreImage (15.0.0 - 940.9) <44F68E8C-315A-32A6-BB19-7F24C00AB347> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff356ea000 - 0x7fff35753ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <B1E3382A-62ED-36F0-AB86-F46D7B7FF9AE> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff357a7000 - 0x7fff35aa9ff2 com.apple.CoreML (1.0 - 1) <06598905-BA5B-3D89-9921-39C6D5889DD9> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff35aaa000 - 0x7fff35b85ffc com.apple.CoreMedia (1.0 - 2620.11.40.2) <0F490101-ED30-3189-B099-E247B6361A0B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff35b86000 - 0x7fff35be8ffe com.apple.CoreMediaIO (1000.0 - 5125.6) <9435B82E-4728-362C-9FF0-E8AEC19D6E3C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff35c72000 - 0x7fff35c72fff com.apple.CoreServices (1069.24 - 1069.24) <D9F6AB40-10EC-3682-A969-85560E2E4768> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff35c73000 - 0x7fff35cf8fff com.apple.AE (838.1 - 838.1) <5F26DA9B-FB2E-3AF8-964B-63BD6671CF12> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff35cf9000 - 0x7fff35fdaff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <8022AF47-AA99-3786-B086-141D84F00387> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff35fdb000 - 0x7fff36028ffd com.apple.DictionaryServices (1.2 - 323.6) <C0F3830C-A4C6-3046-9A6A-DE1B5D448C2C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff36029000 - 0x7fff36031ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <E4B2CAF2-1203-335F-9971-1278CB6E2AE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff36032000 - 0x7fff3626cff6 com.apple.LaunchServices (1069.24 - 1069.24) <2E0AD228-B1CC-3645-91EE-EB7F46F2147B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3626d000 - 0x7fff36305ff1 com.apple.Metadata (10.7.0 - 2076.6) <C8034E84-7DD4-34B9-9CDF-16A05032FF39> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff36306000 - 0x7fff36333fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <72FDEA52-7607-3745-AC43-630D80962099> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff36334000 - 0x7fff3639bfff com.apple.SearchKit (1.4.1 - 1.4.1) <086EB5DF-A2EC-3342-8028-CA7996BE5CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3639c000 - 0x7fff363c0ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <AE333DA2-C279-3751-8C15-B963E58EE61E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3661d000 - 0x7fff366e4ffc com.apple.CoreTelephony (113 - 7560.1) <BAC6EEA9-89A0-3D03-BE0B-C65A3838C9D0> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff366e5000 - 0x7fff3689cffc com.apple.CoreText (643.1.5.1 - 643.1.5.1) <715FE3F7-E8FB-3997-85A0-3AB2839F6C30> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3689d000 - 0x7fff368e1ffb com.apple.CoreVideo (1.8 - 344.3) <A200AFC7-2CB2-30CD-8B2A-1269CA64A29B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff368e2000 - 0x7fff3696fffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <855E51AA-DF3A-3BB9-A4F0-6880D42B8762> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff36b37000 - 0x7fff36be1ff0 com.apple.DiscRecording (9.0.3 - 9030.4.5) <D9033DDA-E4C8-36FB-AE60-4EF66F4F1F9E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff36c06000 - 0x7fff36c0cfff com.apple.DiskArbitration (2.7 - 2.7) <52E7D181-2A18-37CD-B24F-AA32E93F7A69> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff36dff000 - 0x7fff36f2dff6 com.apple.FileProvider (304.1 - 304.1) <58D64236-947E-3E6A-85E6-C66AEF9E0EE0> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff36f42000 - 0x7fff36f44ff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <F9831460-E612-3812-910C-8708822F3DA1> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff36f45000 - 0x7fff3730afff com.apple.Foundation (6.9 - 1676.105) <1FA28BAB-7296-3A09-8E1E-E62A7D233DB8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff37377000 - 0x7fff373c7ff7 com.apple.GSS (4.0 - 2.0) <4E241C00-42A5-3572-9430-D950FBB7A4A0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff37504000 - 0x7fff37618ff3 com.apple.Bluetooth (7.0.5 - 7.0.5f6) <5897C368-9674-3E34-B144-FFB06A2DF37B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3767e000 - 0x7fff37722ff3 com.apple.framework.IOKit (2.0.2 - 1726.121.1) <A0F54725-036F-3279-A46E-C2ABDBFD479B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff37724000 - 0x7fff37735ffb com.apple.IOSurface (269.11 - 269.11) <D3CC2AA1-4AE2-30EE-A9DB-C04CCAA88ADE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff37753000 - 0x7fff377b3ff7 com.apple.ImageCaptureCore (1.0 - 1600.60.4.2) <8BA11284-66A0-3567-A13C-72AD1CC0C2EA> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff377b4000 - 0x7fff37910ffe com.apple.ImageIO.framework (3.3.0 - 1976.6) <5B4C2E04-9161-3C82-A7FB-F4D51E3C1E10> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff37911000 - 0x7fff37914fff libGIF.dylib (1976.6) <3B26EE1C-C570-305C-A9A3-EA62D2F2E7B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff37915000 - 0x7fff379cefff libJP2.dylib (1976.6) <EB4E4E09-DD81-3E6B-A513-3667E810AEF3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff379cf000 - 0x7fff379f2fe3 libJPEG.dylib (1976.6) <9D7FAC55-85A6-34AB-9F26-0BCA381E8CE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff37c6e000 - 0x7fff37c88fef libPng.dylib (1976.6) <4886A1F8-E9CA-38F2-BF2F-1FCA1DFDD1C9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff37c89000 - 0x7fff37c8afff libRadiance.dylib (1976.6) <FA759D33-131A-33B8-943E-32409F162738> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff37c8b000 - 0x7fff37cd4fff libTIFF.dylib (1976.6) <E9994BF8-6CF5-3422-B4FD-A14DC390EF12> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff37ced000 - 0x7fff3817cff8 com.apple.Intents (1.0 - 1) <EA4EEE84-D337-3C59-9C02-261205CA04E7> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff3817f000 - 0x7fff3921ffe9 com.apple.JavaScriptCore (15609 - 15609.2.9.1.2) <62158DFB-C250-3A18-AE52-6296544AEA43> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff39236000 - 0x7fff39248ff3 com.apple.Kerberos (3.0 - 1) <AE0E56CA-D924-3CC8-BBAA-8C6EEC3038BE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff39249000 - 0x7fff39249fff libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff395db000 - 0x7fff395e5ffb com.apple.MediaAccessibility (1.0 - 125.1) <DBF40A12-65A6-33E4-839C-292600B7D910> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff396b1000 - 0x7fff39dfeff5 com.apple.MediaToolbox (1.0 - 2620.11.40.2) <40F16AF6-79D1-3C2E-976C-E7E7870A4EF9> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff39e00000 - 0x7fff39ecaff7 com.apple.Metal (212.7 - 212.7) <CC7BF715-142B-3C2A-81AD-0E35693230F2> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff39ecc000 - 0x7fff39ee6ff5 com.apple.MetalKit (141.2 - 141.2) <8162AFB6-327C-3BE1-AEF7-2BEA999B1DFB> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff39ee7000 - 0x7fff39f24ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <52089325-EC97-3EED-ABB3-9B39EC0BD429> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff39f25000 - 0x7fff39faffe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <9E434EA0-6BCA-3903-B882-CEB69730A63B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff39fb0000 - 0x7fff39fd5ff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <EDD6C3A5-E231-3FB1-B4D4-45742AFB9A4E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff39fd6000 - 0x7fff39febffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C5A2B865-5CE2-3E5D-8452-54639FCB0954> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff39fec000 - 0x7fff3a14affc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <47CCDBAC-5843-366A-A68C-6E8851D0865D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3a14b000 - 0x7fff3a19aff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <302BDF8E-B00A-3123-A6C4-E262B7513CF6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3a19b000 - 0x7fff3a19cff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <14F84B42-9DA2-39A1-81B4-666B8020520C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3b223000 - 0x7fff3b22fffe com.apple.NetFS (6.0 - 4.0) <AC74E6A4-6E9B-3AB1-9577-8277F8A3EDE0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3b230000 - 0x7fff3b387ff3 com.apple.Network (1.0 - 1) <B5B8E999-BBCC-3DEF-8881-8FFF69F8EC4B> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3b388000 - 0x7fff3b5e7ff5 com.apple.NetworkExtension (1.0 - 1) <446D0D36-E8F8-3F2C-B32B-5C3630177FBC> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff3b672000 - 0x7fff3b694fff com.apple.audio.OpenAL (1.8 - 1.8) <A75CF8AC-E0C2-3D6C-8BB6-0683DE2F1A9D> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff3ddaf000 - 0x7fff3ddb7ff7 libcldcpuengine.dylib (2.14) <D8583B54-FE2A-33FD-A702-ABF307D99FD1> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff3ddb8000 - 0x7fff3de10fff com.apple.opencl (3.5 - 3.5) <9B101D40-EA79-3C0D-B7AE-A3F18094B2D7> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff3de11000 - 0x7fff3de2dfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <BFC32EBE-D95C-3267-B95C-5CEEFD189EA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff3de2e000 - 0x7fff3de39ffd com.apple.OpenDirectory (10.15 - 220.40.1) <76A20BBA-775F-3E17-AB0F-FEDFCDCE0716> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff3e79f000 - 0x7fff3e7a1fff libCVMSPluginSupport.dylib (17.10.22) <AAE07E0C-4B28-364B-A7D9-028C7CD14954> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff3e7a2000 - 0x7fff3e7a7fff libCoreFSCache.dylib (176.15) <609C5DFC-9A97-344D-BBC7-E0B08D862C63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff3e7a8000 - 0x7fff3e7acfff libCoreVMClient.dylib (176.15) <8F8DD27F-AC7C-398D-A8E3-396F1528E317> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff3e7ad000 - 0x7fff3e7b5ff7 libGFXShared.dylib (17.10.22) <D0649AB5-5331-328D-8141-E5A6F06D4AD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff3e7b6000 - 0x7fff3e7c0fff libGL.dylib (17.10.22) <116DDBF7-D725-3B8C-BD0B-A21B758FE421> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff3e7c1000 - 0x7fff3e7f5ff7 libGLImage.dylib (17.10.22) <2B314C76-C7E6-3AC5-9157-70B0529C1F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff3e7f6000 - 0x7fff3e98aff7 libGLProgrammability.dylib (17.10.22) <757192B3-4509-3C26-B3B3-C10165F97661> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff3e98b000 - 0x7fff3e9c7fff libGLU.dylib (17.10.22) <B29F73B2-B5A9-3C38-AF77-351173D2E3DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff3f403000 - 0x7fff3f412ff7 com.apple.opengl (17.10.22 - 17.10.22) <D5BF32A8-2E0A-345D-80A3-7CA7C2CF748D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff3f413000 - 0x7fff3f58cfff GLEngine (17.10.22) <0B6AF0FD-DBF3-3D91-B0EA-80402E9E1484> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff3f58d000 - 0x7fff3f5b5fff GLRendererFloat (17.10.22) <A3D159EB-39BB-3F7C-8C1E-005D81788963> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff3f5c4000 - 0x7fff3f6b7ff0 com.apple.PDFKit (1.0 - 835.7) <346881D8-3E09-3787-B877-6284D1D3B24A> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff3f6b8000 - 0x7fff3f7cfff9 com.apple.PencilKit (1.0 - 1) <AD3C6D86-17D6-35A3-AE5C-BEDB872197BF> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff3fa70000 - 0x7fff3fa76ff6 com.apple.PushKit (1.0 - 1) <B4E45366-8C51-3248-BDAF-2ECFE94D5378> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff3fb97000 - 0x7fff3fdddff7 com.apple.imageKit (3.0 - 1081) <F0AD8D71-D6BE-3ABC-9B5F-93825F3F96B1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff3fdde000 - 0x7fff4029dfff com.apple.QuartzComposer (5.1 - 378) <351442B3-92C1-30FB-B5BC-E64759CCA5FC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff4029e000 - 0x7fff402c3ffc com.apple.quartzfilters (1.10.0 - Tag) <F491CB46-3837-3525-AE31-23EB89692BA1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff402c4000 - 0x7fff403ceff7 com.apple.QuickLookUIFramework (5.0 - 906.2) <731A1F57-2064-3941-823E-2D23BD1D9CB1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff403cf000 - 0x7fff403cffff com.apple.quartzframework (1.5 - 23) <E2368AAF-5B01-328F-9D5D-9089CBB9C8FA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff403d0000 - 0x7fff40652ff9 com.apple.QuartzCore (1.11 - 841.2) <444E6F22-DFA6-391B-B51F-A96AE69E524D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff40653000 - 0x7fff406acff5 com.apple.QuickLookFramework (5.0 - 906.2) <E6F25D56-E003-3B3B-851B-1566C132E006> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff406ad000 - 0x7fff406e2ffc com.apple.QuickLookThumbnailing (1.0 - 1) <469201A4-C87A-335F-91C1-81055CF89844> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff40bb3000 - 0x7fff40bcbff0 com.apple.SafariServices.framework (15609 - 15609.2.9.1.2) <DBB58DF1-3DA2-3558-B185-B7DAAB005113> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff411d3000 - 0x7fff4151cff1 com.apple.security (7.0 - 59306.120.7) <AEA33464-1507-36F1-8CAE-A86EB787F9B5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff4151d000 - 0x7fff415a5ffb com.apple.securityfoundation (6.0 - 55236.60.1) <79289FE1-CB5F-3BEF-A33F-11A29A93A681> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff415d4000 - 0x7fff415d8ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <4194D29D-F0D4-33F8-839A-D03C6C62D8DB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff42284000 - 0x7fff422f2ff7 com.apple.SystemConfiguration (1.19 - 1.19) <0CF8726A-BE41-3E07-B895-FBC44B75450E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff42571000 - 0x7fff428f4ff4 com.apple.VideoToolbox (1.0 - 2620.11.40.2) <53E0D852-61CA-34FE-9A9B-788708ADE495> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff46253000 - 0x7fff46318ff7 com.apple.APFS (1412.120.2 - 1412.120.2) <1E8FD511-FDC4-31A2-ACDE-EB5192032BC6> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff47428000 - 0x7fff47429ff1 com.apple.AggregateDictionary (1.0 - 1) <B907CE7A-0122-3E63-BF39-0A242B0DD7C4> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff476f4000 - 0x7fff4783fff5 com.apple.AnnotationKit (1.0 - 325.9) <E9B0F74B-CB16-3E07-9015-8CBF158EB08D> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff47840000 - 0x7fff4785dff4 com.apple.AppContainer (4.0 - 448.100.6) <9C2D0065-9B38-3D1C-A090-46F129A1B3CA> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff478b2000 - 0x7fff478c0ff7 com.apple.AppSandbox (4.0 - 448.100.6) <7DAB58B1-8176-3FB0-A7B0-8A38E118E90B> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff47d3b000 - 0x7fff47d5fffb com.apple.framework.Apple80211 (13.0 - 1610.1) <B4B80CD6-B38E-3748-B30B-5088CCE9A7A8> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4801d000 - 0x7fff4802cfd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <2E75CF51-B693-3275-9A4F-40571D48745E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4812b000 - 0x7fff48136ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <F4651654-E24F-3BF4-8DDF-8F91E5219BA4> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff48178000 - 0x7fff481c0ff7 com.apple.AppleJPEG (1.0 - 1) <4655FF70-9772-3D7C-8159-5A5E56C9F84B> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff48583000 - 0x7fff485a9ffb com.apple.aps.framework (4.0 - 4.0) <34F0F991-2D0F-3376-B5B2-BDED2108552A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff485aa000 - 0x7fff485aeff7 com.apple.AppleSRP (5.0 - 1) <B683AD55-A121-31DD-9A87-3A31C35FEABF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff485af000 - 0x7fff485d1fff com.apple.applesauce (1.0 - 16.25) <33B66B71-64A4-365D-9953-E0545E69A5E7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff48690000 - 0x7fff48693ffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <92580EE3-74BF-3488-90ED-C8EBD7A1B4C3> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff48694000 - 0x7fff486e4ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <39C3583D-C824-3168-B67A-498487FD03D9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4872d000 - 0x7fff4873cff9 com.apple.AssertionServices (1.0 - 223.100.31) <478D2004-9B84-3AE9-9A0B-0A0B68ED028F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff48c7e000 - 0x7fff49079ff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <9ABFE41A-FD01-3111-BA73-D2DD1BF96525> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff491b8000 - 0x7fff49209ff9 com.apple.audio.AudioSession (1.0 - 17) <92B19FA8-828E-3E2D-9345-A833082C4972> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff4920a000 - 0x7fff49237ff7 libSessionUtility.dylib (17) <C1A99F99-B940-338E-9F87-8F089965AD7E> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff492cf000 - 0x7fff4950ffe0 com.apple.audio.AudioToolboxCore (1.0 - 1104.84) <FA17E892-6A1A-309D-95C7-30ACFC44319C> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff49513000 - 0x7fff4962fff0 com.apple.AuthKit (1.0 - 1) <375C3886-5430-3C02-BD2C-4244BF490ABA> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff497ec000 - 0x7fff497f5ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <F070F440-27AB-3FCF-9602-F278C332CA01> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff497f6000 - 0x7fff49897ff5 com.apple.backup.framework (1.11.5 - 1298.5.10) <637CA389-627A-365C-98C2-D297C47D6EE3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff49898000 - 0x7fff49924ff6 com.apple.BaseBoard (466.3 - 466.3) <1718A41A-9923-3FD0-96B8-82376E153D27> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff49a26000 - 0x7fff49a62ff7 com.apple.bom (14.0 - 219.2) <586F1D9C-23B0-3F38-9C5B-728E9DD8B953> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff49b80000 - 0x7fff49bb7ff5 com.apple.C2 (1.3 - 495) <4C624CDB-C2A8-3039-BC45-224FB8671969> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff4a5e1000 - 0x7fff4a630fff com.apple.ChunkingLibrary (307 - 307) <32E0F1A1-9DD6-3B52-91C2-93643041AA60> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4a78a000 - 0x7fff4a815ff8 com.apple.CloudDocs (1.0 - 698.14) <4CFF0DF0-8A89-3DAD-8A07-A208FDDD163B> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4b4d7000 - 0x7fff4b4e7ffb com.apple.CommonAuth (4.0 - 2.0) <91EC83B5-857D-3D4F-93B1-AAD7E0E029D8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4b4fb000 - 0x7fff4b512fff com.apple.commonutilities (8.0 - 900) <12C6DEE5-1740-39A5-9711-6F815C6D77BD> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4bc16000 - 0x7fff4bfebfc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <BA9522E5-95D0-30D0-BEF4-691CEB51035B> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4bfec000 - 0x7fff4c019ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <14FC549B-86BD-396A-B03E-6F5219482943> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4c03c000 - 0x7fff4c05bffc com.apple.analyticsd (1.0 - 1) <A4F653CA-2FD6-348B-B7B3-48D91A67508A> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4c164000 - 0x7fff4c1daff7 com.apple.corebrightness (1.0 - 1) <D1E20AF2-A96B-318C-9605-9A3BD6EC27C2> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff4c366000 - 0x7fff4c371ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8F8E586D-C153-3ABA-88B7-6CEC7F476F0E> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4c372000 - 0x7fff4c57dff1 com.apple.CoreDuet (1.0 - 1) <C933EE99-D7D2-32F8-8B96-938A0FB612FB> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff4c57e000 - 0x7fff4c5cbff3 com.apple.coreduetcontext (1.0 - 1) <64FD6DBA-89E3-34FC-A758-3240D4737F75> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff4c5cc000 - 0x7fff4c5dcffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <00D3E768-CBBF-36DE-B8D8-218F7B562F6F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff4c5df000 - 0x7fff4c5e1fff com.apple.CoreDuetDebugLogging (1.0 - 1) <DBE17F86-59D6-368D-AEF1-4BDF85D2E735> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff4c5f2000 - 0x7fff4c602ff3 com.apple.CoreEmoji (1.0 - 107.1) <CDCCB4B0-B98F-38E8-9568-C81320E756EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff4c7b8000 - 0x7fff4c905fff com.apple.CoreHandwriting (161 - 1.2) <7F6BAABE-71D0-34F6-876D-C6C53331B5F3> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff4cc42000 - 0x7fff4ccacff0 com.apple.CoreNLP (1.0 - 213) <40FC46D2-844C-3282-A8E4-69DD827F05C5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff4cf6f000 - 0x7fff4cff7ffe com.apple.CorePDF (4.0 - 518.4.1) <98F39D44-028B-3714-AC76-0884D08DD6CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff4d0da000 - 0x7fff4d0e2ff8 com.apple.CorePhoneNumbers (1.0 - 1) <B2CE100D-B82F-3481-86F6-7F85FF8BFAFB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff4dacf000 - 0x7fff4daf2fff com.apple.CoreSVG (1.0 - 129) <3141D198-0507-3F72-A2C9-752EAFE3EEB3> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff4daf3000 - 0x7fff4db26fff com.apple.CoreServicesInternal (446.7 - 446.7) <B2CEC515-2225-3CB1-B34A-904AAEA54FDF> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff4db27000 - 0x7fff4db55ffd com.apple.CSStore (1069.24 - 1069.24) <C96E5CE8-D604-3F13-B079-B2BA33B90081> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff4e07a000 - 0x7fff4e110ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0E7A1529-C737-33FD-AA7D-A32EB8B192DA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff4e1a8000 - 0x7fff4e2d4ff6 com.apple.coreui (2.1 - 609.4) <9B93CC42-804B-305A-8FCE-5F06821B544C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff4e2d5000 - 0x7fff4e48bff5 com.apple.CoreUtils (6.2.1 - 621.5) <CD4B58E5-1494-3457-84FF-3869378E2DC9> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff4e5c5000 - 0x7fff4e5d8ff1 com.apple.CrashReporterSupport (10.13 - 15016) <827F4E31-9F23-3683-AC5A-59CCA90F2359> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff4e691000 - 0x7fff4e6a3ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <19F79D32-71D3-3A87-98C9-B5C6C96076C4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4e6a4000 - 0x7fff4e6a9fff com.apple.DSExternalDisplay (3.1 - 380) <971F24F1-B1FC-3674-9C00-F88EEF94DC05> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff4e733000 - 0x7fff4e7adff0 com.apple.datadetectorscore (8.0 - 659) <9FD9BDFA-3724-3BEA-946C-0473447196A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff4e7f9000 - 0x7fff4e836ff8 com.apple.DebugSymbols (194 - 194) <9BCE6685-6C45-3DF9-98EB-FCF8196160F0> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff4e837000 - 0x7fff4e9bfff6 com.apple.desktopservices (1.14.5 - 1281.5.3) <79972B8B-7B60-3AD5-9A5F-17976DE8080B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff4ed0f000 - 0x7fff4ede2ff1 com.apple.DiskManagement (13.0 - 1648.120.5) <650DBBE4-6624-3064-A26D-6BCAA0FE41F9> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff4ede3000 - 0x7fff4ede7ff1 com.apple.DisplayServicesFW (3.1 - 380) <A5F74849-D8E4-30DC-A638-BFD4332CD6AB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff4ee41000 - 0x7fff4ee65ff9 com.apple.DuetActivityScheduler (1.0 - 1) <C63FCC5A-CF9B-31B0-B549-04FC4527B826> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff4ee8f000 - 0x7fff4eec4ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <E0BAD6DA-3F7C-32A4-AB32-13C9D604690B> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff4eec5000 - 0x7fff4eec9ff9 com.apple.EFILogin (2.0 - 2) <B95015BC-5BC2-33D9-AD94-01905DD56193> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff4fa12000 - 0x7fff5007cff9 com.apple.vision.EspressoFramework (1.0 - 188.4) <4502588F-70F2-3A5F-9089-4B2F29159961> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff50357000 - 0x7fff50772ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <1B5D7DD6-718E-3111-A702-EB04B8903662> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff50dc9000 - 0x7fff50dc9ff7 com.apple.FinderSyncPriv (1.0.5 - 1298.5.10) <DF26ECCB-29C1-3B7E-8121-96A3275EC6EB> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff50e10000 - 0x7fff50f48ffc libFontParser.dylib (277.2.5.3) <DEB18756-082F-359B-AE93-F9C3B5EC7AF4> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff50f49000 - 0x7fff50f7dfff libTrueTypeScaler.dylib (277.2.5.3) <B16255A6-C51A-328B-B679-8FBF64495770> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff50fe2000 - 0x7fff50ff2ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <6396BC1F-13C1-37D7-91B9-1FF60910C7FA> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff544d3000 - 0x7fff544d4fff libmetal_timestamp.dylib (902.14.11) <BE88F259-0A3C-3910-8983-FB5E2C905E87> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff55b85000 - 0x7fff55b90ff7 libGPUSupportMercury.dylib (17.10.22) <B2E086E1-6E50-3A3D-B014-FCDAACBACE90> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff55b91000 - 0x7fff55b97fff com.apple.GPUWrangler (5.2.4 - 5.2.4) <5B819701-9F0C-374B-8925-A22DFC16514F> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff55eb6000 - 0x7fff55edcff1 com.apple.GenerationalStorage (2.0 - 314) <5613706F-710A-39E0-8B25-BA103A768613> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff55ef5000 - 0x7fff56edfffc com.apple.GeoServices (1.0 - 1624.24.10.29.41) <9A6FF368-7127-336F-9595-B261141810EA> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5700b000 - 0x7fff57019ffb com.apple.GraphVisualizer (1.0 - 100.1) <0A86C9FF-4484-3C7F-BC71-3D23BDBE81CE> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff57082000 - 0x7fff5708fff9 com.apple.HID (1.0 - 1) <C750D8D3-C4DD-3E77-94B2-6A7B4D56DF2A> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff571b8000 - 0x7fff57276ff4 com.apple.Heimdal (4.0 - 2.0) <F2C504F6-E211-3AB0-9754-D96D2F96634B> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff593f0000 - 0x7fff593f9ffe com.apple.IOAccelMemoryInfo (1.0 - 1) <903349F6-F3B0-3269-8946-2CE3E2C49E70> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff593fa000 - 0x7fff59402ff5 com.apple.IOAccelerator (438.5.4 - 438.5.4) <A3CF45E0-4D88-33BF-BAEC-690D5664CDA0> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5940f000 - 0x7fff59426fff com.apple.IOPresentment (1.0 - 37) <3EDBB454-D248-394B-A026-9717CD8535C3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff597ae000 - 0x7fff597f9ff1 com.apple.IconServices (438.3 - 438.3) <2AE74790-64F1-3B0A-9534-DEEEE307E562> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff59996000 - 0x7fff599a4fff com.apple.IntentsFoundation (1.0 - 1) <C2C31BEB-FFCE-31E1-BA23-A093693C0BDC> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff599b7000 - 0x7fff599beff9 com.apple.InternationalSupport (1.0 - 45.4) <C22AA77A-EDA6-3626-8816-521A8CD43C4A> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff59c4b000 - 0x7fff59c6affd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <76DB5326-BE5D-3339-975C-D9FCF39A341E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff59d9f000 - 0x7fff59e6dffd com.apple.LanguageModeling (1.0 - 215.1) <A6FAA215-9A01-3EE1-B304-2238801C5883> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff59e6e000 - 0x7fff59eb6fff com.apple.Lexicon-framework (1.0 - 72) <6AE1872C-0352-36FE-90CC-7303F13A5BEF> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff59ebd000 - 0x7fff59ec2ff3 com.apple.LinguisticData (1.0 - 353.18) <686E7B7C-640F-3D7B-A9C1-31E2DFACD457> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff59ee9000 - 0x7fff59f0dffe com.apple.locationsupport (2394.0.22 - 2394.0.22) <5C15E3FF-D269-3A99-B3EF-B806F61EE1EA> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff5a75a000 - 0x7fff5a75dfff com.apple.Mangrove (1.0 - 25) <11A30F47-B1C1-375E-9FE7-0A196E92A52C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5a91b000 - 0x7fff5a941ffc com.apple.MarkupUI (1.0 - 325.9) <FB688EC0-67FD-37A2-BED0-A017F4FA029A> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff5a9c6000 - 0x7fff5aa50ff8 com.apple.MediaExperience (1.0 - 1) <34E15DA2-02AA-32FA-99E1-9A139521E226> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5aa51000 - 0x7fff5aa84fff com.apple.MediaKit (16 - 923) <14E38848-C9BD-37F1-AE44-FC4CC839E8A1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5b229000 - 0x7fff5b275fff com.apple.spotlight.metadata.utilities (1.0 - 2076.6) <C3AEA22D-1FEB-3E38-9821-1FA447C8AF9D> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5b276000 - 0x7fff5b347ffa com.apple.gpusw.MetalTools (1.0 - 1) <A23FFAB6-437C-303C-A3E8-99F323F8E734> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5b3a5000 - 0x7fff5b3beff4 com.apple.MobileAssets (1.0 - 619.120.1) <5AF95641-68C7-351A-A317-3C7B793502D6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5b57b000 - 0x7fff5b599fff com.apple.MobileKeyBag (2.0 - 1.0) <B564179F-A5E9-3BD8-892D-CEF2BE0DA0D7> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5b665000 - 0x7fff5b7fbffd com.apple.Montreal (1.0 - 121.1) <9A9642A5-CE1F-3C1E-ACEF-C3CC789A1D26> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff5b7fc000 - 0x7fff5b82cff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <4E7CB188-382E-3128-8671-4A3EF6E06622> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5bd2c000 - 0x7fff5bd36fff com.apple.NetAuth (6.2 - 6.2) <D660F2CB-5A49-3DD0-9DB3-86EF0797828C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5c74c000 - 0x7fff5c797ffb com.apple.OTSVG (1.0 - 643.1.5.1) <CD494F00-9AA4-3A48-916B-EA8661F9772D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5d9ab000 - 0x7fff5d9b6ff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <941698D6-EF00-3D59-8560-F160BC04B412> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5d9b7000 - 0x7fff5d9dfffb com.apple.persistentconnection (1.0 - 1.0) <FFC20BB6-9CF3-39F2-AE5C-8DEE348FE0C1> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff5f458000 - 0x7fff5f488ff7 com.apple.pluginkit.framework (1.0 - 1) <6A417FEF-CEDE-3EE0-93ED-42680A31C886> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff5f4b3000 - 0x7fff5f4c6ffc com.apple.PowerLog (1.0 - 1) <63A89A9B-2ACC-3378-9BD0-7FA971E07C2A> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff60342000 - 0x7fff6039cff6 com.apple.ProtectedCloudStorage (1.0 - 1) <969BF7A2-E989-3A22-BC1B-72B72E107229> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff6039d000 - 0x7fff603b6ffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <A2E34123-7CED-378B-A43D-1B98B5B85F5C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff604c8000 - 0x7fff604cbff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <4579D418-9C34-3F29-B121-0046F2B87D0B> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff604cc000 - 0x7fff604efff0 com.apple.quicklook.QuickLookSupport (1.0 - 1) <D4E71FA6-5776-304F-B007-51FFC81C6780> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff60536000 - 0x7fff605afff3 com.apple.Rapport (1.9.5 - 195.2) <6DB4EFB5-A70C-36AA-971B-3B728EEF41AB> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff60815000 - 0x7fff6083eff1 com.apple.RemoteViewServices (2.0 - 148) <1C61CFC2-F76F-31E5-BA13-EFD5DC69C8D5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff609a3000 - 0x7fff609deff0 com.apple.RunningBoardServices (1.0 - 223.100.31) <9FD1FC53-186A-3327-A359-B0BC7F4360EF> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff622be000 - 0x7fff622c1ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <813B3E57-6A95-3D7B-9094-C65D687A72B8> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff62434000 - 0x7fff6255bff0 com.apple.Sharing (1526.31 - 1526.31) <2CB07F08-7794-3BF2-9ED5-BAB5C55C9D2C> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff625d3000 - 0x7fff625f3ff5 com.apple.sidecar-core (1.0 - 209.40.4) <A5BEBCF6-0B2F-3BA7-9F4C-A65E4AECB2E6> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff625f4000 - 0x7fff62606ff0 com.apple.sidecar-ui (1.0 - 209.40.4) <55486B3A-B65A-3023-89C7-A154A39D0D7E> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff6396e000 - 0x7fff63c64ff7 com.apple.SkyLight (1.600.0 - 451.4) <F5B9065A-E975-36D1-8D53-9FBF02171FAB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff644b1000 - 0x7fff644bfffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <820602AB-117B-3C3E-B20B-819CBC97B7A4> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff64581000 - 0x7fff6480bffe com.apple.spotlight.index (10.7.0 - 2076.6) <38E208FE-A4E5-3B6C-9937-97CA152F1BB2> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff64b99000 - 0x7fff64bdaff9 com.apple.StreamingZip (1.0 - 1) <EFCDDC94-28EE-3BCA-A105-0A928D15ED8C> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff64cf1000 - 0x7fff64cfaff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <581F31D6-94CB-38AA-BD56-1A63606E516E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff64fb1000 - 0x7fff64fc1ff3 com.apple.TCC (1.0 - 1) <FD146B21-6DC0-3B66-BB95-57A5016B1365> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff654e6000 - 0x7fff655acff0 com.apple.TextureIO (3.10.9 - 3.10.9) <E23E05ED-8190-3564-985E-446F15CB0709> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff65771000 - 0x7fff659c9ff0 com.apple.UIFoundation (1.0 - 662) <DFD3DD4A-E661-3A12-BB02-06898949617D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff65a60000 - 0x7fff65a66ffe com.apple.URLFormatting (119 - 119.18) <CE5B7B2B-7CB9-3214-BFA2-D6D4F13D7652> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6663c000 - 0x7fff6665cffc com.apple.UserManagement (1.0 - 1) <E168206A-9DC1-3C67-A9A6-52D816DBD5B1> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff67408000 - 0x7fff674f2ff8 com.apple.ViewBridge (464.1 - 464.1) <C698BAC9-26C8-39F1-BBC0-F57EBD2EFD7B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff67698000 - 0x7fff67699fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <3B8EBB6B-77D0-317C-A3DB-D0D2E294B18D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff682c6000 - 0x7fff682c9ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D4F09EC7-C63F-3861-B5DA-3F7C0DFF153D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff68343000 - 0x7fff68351ff5 com.apple.audio.caulk (1.0 - 32.3) <7D3D2F91-8B1D-3558-B324-45BDF11306DB> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff68693000 - 0x7fff68695ff3 com.apple.loginsupport (1.0 - 1) <31F02734-1ECF-37D9-9DF6-7C3BC3A324FE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff68696000 - 0x7fff686a9ffd com.apple.login (3.0 - 3.0) <1DC570FD-29EC-3AE8-BD34-D44C00E4621B> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff686db000 - 0x7fff686e7ffd com.apple.perfdata (1.0 - 51.100.6) <2F2B9D0F-CB87-3712-B04B-DA075A48002B> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff6b16c000 - 0x7fff6b178ff9 libAudioStatistics.dylib (1104.84) <CBFD7F79-15F1-3828-B2FF-921F71C91FDC> /usr/lib/libAudioStatistics.dylib
0x7fff6b179000 - 0x7fff6b1acffa libAudioToolboxUtility.dylib (1104.84) <BB234563-F952-3E7F-B630-4140DB5E0380> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6b1b3000 - 0x7fff6b1e7fff libCRFSuite.dylib (48) <02C52318-C537-3FD8-BBC4-E5BD25430652> /usr/lib/libCRFSuite.dylib
0x7fff6b1ea000 - 0x7fff6b1f4fff libChineseTokenizer.dylib (34) <04A7CB5A-FD68-398A-A206-33A510C115E7> /usr/lib/libChineseTokenizer.dylib
0x7fff6b1f5000 - 0x7fff6b27dfff libCoreStorage.dylib (551) <BBD3B3DC-270D-35F2-8C67-4595A257EEBB> /usr/lib/libCoreStorage.dylib
0x7fff6b280000 - 0x7fff6b282ff7 libDiagnosticMessagesClient.dylib (112) <27220E98-6CE2-33E3-BD48-3CC3CE4AA036> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6b2c8000 - 0x7fff6b47fffb libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
0x7fff6b4a6000 - 0x7fff6b4acff3 libIOReport.dylib (54) <E3A2148E-C5B2-30A8-ACD3-E081DD02BE90> /usr/lib/libIOReport.dylib
0x7fff6b58e000 - 0x7fff6b595fff libMatch.1.dylib (36) <081FB6A9-0482-3697-A98B-6821FF476C6E> /usr/lib/libMatch.1.dylib
0x7fff6b5c4000 - 0x7fff6b5e4fff libMobileGestalt.dylib (826.120.5) <1977AD00-533A-31AA-8D74-EA6CB962F668> /usr/lib/libMobileGestalt.dylib
0x7fff6b664000 - 0x7fff6b741ff7 libSMC.dylib (20) <5FCE668E-C4D5-3E36-98B9-6DF720DCD886> /usr/lib/libSMC.dylib
0x7fff6b756000 - 0x7fff6b757fff libSystem.B.dylib (1281.100.1) <B6FDA8A9-3D2B-3BD5-B5B0-57D311C0FF3D> /usr/lib/libSystem.B.dylib
0x7fff6b758000 - 0x7fff6b7e3ff7 libTelephonyUtilDynamic.dylib (5017.1) <4C11A09D-9B7E-3743-B9E6-39B4D466BAF1> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6b7e4000 - 0x7fff6b7e5fff libThaiTokenizer.dylib (3) <97DC10ED-3C11-3C89-B366-299A644035E7> /usr/lib/libThaiTokenizer.dylib
0x7fff6b7fd000 - 0x7fff6b813fff libapple_nghttp2.dylib (1.39.2) <B99D7150-D4E2-31A2-A594-36DA4B90D558> /usr/lib/libapple_nghttp2.dylib
0x7fff6b848000 - 0x7fff6b8baff7 libarchive.2.dylib (72.100.1) <20B70252-0C4B-3AFD-8C8D-F51921E9D324> /usr/lib/libarchive.2.dylib
0x7fff6b8bb000 - 0x7fff6b954fe5 libate.dylib (3.0.1) <C4A5AE88-4E44-36FA-AD3E-0629AF9B94E0> /usr/lib/libate.dylib
0x7fff6b958000 - 0x7fff6b958ff3 libauto.dylib (187) <85383E24-1592-36BC-BB39-308B7F1C826E> /usr/lib/libauto.dylib
0x7fff6ba1e000 - 0x7fff6ba2effb libbsm.0.dylib (60.100.1) <B2331E11-3CBB-3BCF-93A6-12627AE444D0> /usr/lib/libbsm.0.dylib
0x7fff6ba2f000 - 0x7fff6ba3bfff libbz2.1.0.dylib (44) <BF40E193-8856-39B7-98F8-7A17B328B1E9> /usr/lib/libbz2.1.0.dylib
0x7fff6ba3c000 - 0x7fff6ba8efff libc++.1.dylib (902.1) <AD0805FE-F98B-3E2F-B072-83782B22DAC9> /usr/lib/libc++.1.dylib
0x7fff6ba8f000 - 0x7fff6baa4ffb libc++abi.dylib (902) <771E9263-E832-3985-9477-8F1B2D73B771> /usr/lib/libc++abi.dylib
0x7fff6baa5000 - 0x7fff6baa5fff libcharset.1.dylib (59) <FF23D4ED-A5AD-3592-9574-48486C7DF85B> /usr/lib/libcharset.1.dylib
0x7fff6baa6000 - 0x7fff6bab7fff libcmph.dylib (8) <296A51E6-9661-3AC2-A1C9-F1E3510F91AA> /usr/lib/libcmph.dylib
0x7fff6bab8000 - 0x7fff6bacffd7 libcompression.dylib (87) <21F37C2E-B9AA-38CE-9023-B763C8828AC6> /usr/lib/libcompression.dylib
0x7fff6bda9000 - 0x7fff6bdbfff7 libcoretls.dylib (167) <9E5D1E0C-03F8-37B6-82A1-0D0597021CB8> /usr/lib/libcoretls.dylib
0x7fff6bdc0000 - 0x7fff6bdc1fff libcoretls_cfhelpers.dylib (167) <C23BE09B-85D1-3744-9E7B-E2B11ACD5442> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6c36b000 - 0x7fff6c376fff libcsfde.dylib (551) <8FBB94EC-712C-3C0F-A8A9-88EE5F4679EF> /usr/lib/libcsfde.dylib
0x7fff6c37e000 - 0x7fff6c3ddff7 libcups.2.dylib (483.6) <FFE8FE67-A6CC-3C38-A9D7-D411D7B562F1> /usr/lib/libcups.2.dylib
0x7fff6c4e7000 - 0x7fff6c4e7fff libenergytrace.dylib (21) <DBF8BDEE-7229-3F06-AC10-A28DCC4243C0> /usr/lib/libenergytrace.dylib
0x7fff6c4e8000 - 0x7fff6c500fff libexpat.1.dylib (19.60.2) <C9163264-BA81-3CC6-9B8C-48A9A0709DD5> /usr/lib/libexpat.1.dylib
0x7fff6c50e000 - 0x7fff6c510fff libfakelink.dylib (149.1) <122F530F-F10E-3DD5-BBEA-91796BE583F3> /usr/lib/libfakelink.dylib
0x7fff6c51f000 - 0x7fff6c524fff libgermantok.dylib (24) <DD279BF6-E906-30D3-A69E-DC797E95F147> /usr/lib/libgermantok.dylib
0x7fff6c525000 - 0x7fff6c52eff7 libheimdal-asn1.dylib (564.100.1) <68FA1BE5-8FFC-3345-8980-8D8629EBA451> /usr/lib/libheimdal-asn1.dylib
0x7fff6c52f000 - 0x7fff6c61ffff libiconv.2.dylib (59) <F58FED71-6CCA-30E8-9A51-13E9B46E568D> /usr/lib/libiconv.2.dylib
0x7fff6c620000 - 0x7fff6c877fff libicucore.A.dylib (64260.0.1) <7B9204AC-EA14-3FF3-B6B9-4C85B37EED79> /usr/lib/libicucore.A.dylib
0x7fff6c891000 - 0x7fff6c892fff liblangid.dylib (133) <36581D30-1C7B-3A58-AA07-36237BD75E0E> /usr/lib/liblangid.dylib
0x7fff6c893000 - 0x7fff6c8abff3 liblzma.5.dylib (16) <4DB30730-DBD1-3503-957A-D604049B98F9> /usr/lib/liblzma.5.dylib
0x7fff6c8c3000 - 0x7fff6c96aff7 libmecab.dylib (883.11) <66AD729B-2BCC-3347-B9B3-FD88570E884D> /usr/lib/libmecab.dylib
0x7fff6c96b000 - 0x7fff6cbcdff1 libmecabra.dylib (883.11) <2AE744D2-AC95-3720-8E66-4F9C7A79384C> /usr/lib/libmecabra.dylib
0x7fff6cf3a000 - 0x7fff6cf69fff libncurses.5.4.dylib (57) <B0B09D08-A7C9-38E9-8BF4-E4F4882F93A6> /usr/lib/libncurses.5.4.dylib
0x7fff6d099000 - 0x7fff6d515ff5 libnetwork.dylib (1880.120.4) <715FB943-BA01-351C-BEA6-121970472985> /usr/lib/libnetwork.dylib
0x7fff6d516000 - 0x7fff6d52dfff libnetworkextension.dylib (1095.120.6) <782E43F6-1FB9-3A5F-AF24-AC21A63C1A37> /usr/lib/libnetworkextension.dylib
0x7fff6d5b6000 - 0x7fff6d5e9fde libobjc.A.dylib (787.1) <CA836D3E-4595-33F1-B70C-7E39A3FBBE16> /usr/lib/libobjc.A.dylib
0x7fff6d5fc000 - 0x7fff6d600fff libpam.2.dylib (25.100.1) <732E8D8E-C630-3EC2-B6C3-A1564E3B68B8> /usr/lib/libpam.2.dylib
0x7fff6d603000 - 0x7fff6d639ff7 libpcap.A.dylib (89.120.1) <CF2ADF15-2D44-3A35-94B4-DD24052F9B23> /usr/lib/libpcap.A.dylib
0x7fff6d679000 - 0x7fff6d687ff9 libperfcheck.dylib (37.100.2) <4B1B7D59-2A8B-3E32-AAE6-B428252A5204> /usr/lib/libperfcheck.dylib
0x7fff6d6bd000 - 0x7fff6d6d5fff libresolv.9.dylib (67.40.1) <B0F5D204-7EF2-3B0B-90EF-BB4D196FCC62> /usr/lib/libresolv.9.dylib
0x7fff6d6d7000 - 0x7fff6d71bff7 libsandbox.1.dylib (1217.120.7) <728BC15F-9A6C-3634-9427-60C01CB5A5D6> /usr/lib/libsandbox.1.dylib
0x7fff6d72f000 - 0x7fff6d730ff7 libspindump.dylib (281.3) <0C3A8B48-DC31-3F61-B4CC-746157042D0E> /usr/lib/libspindump.dylib
0x7fff6d731000 - 0x7fff6d91bff7 libsqlite3.dylib (308.5) <AF518115-4AD1-39F2-9B82-E2640E2221E1> /usr/lib/libsqlite3.dylib
0x7fff6db6c000 - 0x7fff6db6fffb libutil.dylib (57) <D33B63D2-ADC2-38BD-B8F2-24056C41E07B> /usr/lib/libutil.dylib
0x7fff6db70000 - 0x7fff6db7dff7 libxar.1.dylib (425.2) <943A4CBB-331B-3A04-A11F-A2301189D40B> /usr/lib/libxar.1.dylib
0x7fff6db83000 - 0x7fff6dc65ff7 libxml2.2.dylib (33.3) <262EF7C6-7D83-3C01-863F-36E97F5ACD34> /usr/lib/libxml2.2.dylib
0x7fff6dc69000 - 0x7fff6dc91fff libxslt.1.dylib (16.9) <86FE4382-BD77-3C19-A678-11EBCD70685A> /usr/lib/libxslt.1.dylib
0x7fff6dc92000 - 0x7fff6dca4ff3 libz.1.dylib (76) <DB120508-3BED-37A8-B439-5235EAB4618A> /usr/lib/libz.1.dylib
0x7fff6e552000 - 0x7fff6e557ff3 libcache.dylib (83) <A5ECC751-A681-30D8-B33C-D192C15D25C8> /usr/lib/system/libcache.dylib
0x7fff6e558000 - 0x7fff6e563fff libcommonCrypto.dylib (60165.120.1) <C321A74A-AA91-3785-BEBF-BEDC6975026C> /usr/lib/system/libcommonCrypto.dylib
0x7fff6e564000 - 0x7fff6e56bfff libcompiler_rt.dylib (101.2) <652A6012-7E5C-3F4F-9438-86BC094526F3> /usr/lib/system/libcompiler_rt.dylib
0x7fff6e56c000 - 0x7fff6e575ff7 libcopyfile.dylib (166.40.1) <40113A69-A81C-3397-ADC6-1D16B9A22C3E> /usr/lib/system/libcopyfile.dylib
0x7fff6e576000 - 0x7fff6e608fe3 libcorecrypto.dylib (866.120.3) <5E4B0E50-24DD-3E04-9374-EDA9FFD6257B> /usr/lib/system/libcorecrypto.dylib
0x7fff6e715000 - 0x7fff6e755ff0 libdispatch.dylib (1173.100.2) <201EDBF3-0B36-31BA-A7CB-443CE35C05D4> /usr/lib/system/libdispatch.dylib
0x7fff6e756000 - 0x7fff6e78cfff libdyld.dylib (750.5) <7E711A46-5E4D-393C-AEA6-440E2A5CCD0C> /usr/lib/system/libdyld.dylib
0x7fff6e78d000 - 0x7fff6e78dffb libkeymgr.dylib (30) <52662CAA-DB1F-30A3-BE13-D6274B1A6D7B> /usr/lib/system/libkeymgr.dylib
0x7fff6e78e000 - 0x7fff6e79aff3 libkxld.dylib (6153.121.2) <5EBB4886-C7B6-31D6-AA63-D861B2D58FCE> /usr/lib/system/libkxld.dylib
0x7fff6e79b000 - 0x7fff6e79bff7 liblaunch.dylib (1738.120.8) <07CF647B-F9DC-3907-AD98-2F85FCB34A72> /usr/lib/system/liblaunch.dylib
0x7fff6e79c000 - 0x7fff6e7a1ff7 libmacho.dylib (959.0.1) <D91DFF00-E22F-3796-8A1C-4C1F5F8FA03C> /usr/lib/system/libmacho.dylib
0x7fff6e7a2000 - 0x7fff6e7a4ff3 libquarantine.dylib (110.40.3) <D3B7D02C-7646-3FB4-8529-B36DCC2419EA> /usr/lib/system/libquarantine.dylib
0x7fff6e7a5000 - 0x7fff6e7a6ff7 libremovefile.dylib (48) <B5E88D9B-C2BE-3496-BBB2-C996317E18A3> /usr/lib/system/libremovefile.dylib
0x7fff6e7a7000 - 0x7fff6e7beff3 libsystem_asl.dylib (377.60.2) <1170348D-2491-33F1-AA79-E2A05B4A287C> /usr/lib/system/libsystem_asl.dylib
0x7fff6e7bf000 - 0x7fff6e7bfff7 libsystem_blocks.dylib (74) <7AFBCAA6-81BE-36C3-8DB0-AAE0A4ACE4C5> /usr/lib/system/libsystem_blocks.dylib
0x7fff6e7c0000 - 0x7fff6e847fff libsystem_c.dylib (1353.100.2) <935DDCE9-4ED0-3F79-A05A-A123DDE399CC> /usr/lib/system/libsystem_c.dylib
0x7fff6e848000 - 0x7fff6e84bffb libsystem_configuration.dylib (1061.120.2) <EA9BC2B1-5001-3463-9FAF-39FF61CAC87C> /usr/lib/system/libsystem_configuration.dylib
0x7fff6e84c000 - 0x7fff6e84ffff libsystem_coreservices.dylib (114) <3D0A3AA8-8415-37B2-AAE3-66C03BCE8B55> /usr/lib/system/libsystem_coreservices.dylib
0x7fff6e850000 - 0x7fff6e858fff libsystem_darwin.dylib (1353.100.2) <6EEC9975-EE3B-3C95-AA5B-030FD10587BC> /usr/lib/system/libsystem_darwin.dylib
0x7fff6e859000 - 0x7fff6e860fff libsystem_dnssd.dylib (1096.100.3) <0115092A-E61B-317D-8670-41C7C34B1A82> /usr/lib/system/libsystem_dnssd.dylib
0x7fff6e861000 - 0x7fff6e862ffb libsystem_featureflags.dylib (17) <AFDB5095-0472-34AC-BA7E-497921BF030A> /usr/lib/system/libsystem_featureflags.dylib
0x7fff6e863000 - 0x7fff6e8b0ff7 libsystem_info.dylib (538) <851693E9-C079-3547-AD41-353F8C248BE8> /usr/lib/system/libsystem_info.dylib
0x7fff6e8b1000 - 0x7fff6e8ddff7 libsystem_kernel.dylib (6153.121.2) <9F9902C9-A46F-3CA9-B7F9-5CCFE98FBF75> /usr/lib/system/libsystem_kernel.dylib
0x7fff6e8de000 - 0x7fff6e925fff libsystem_m.dylib (3178) <436CFF76-6A99-36F2-A3B6-8D017396A050> /usr/lib/system/libsystem_m.dylib
0x7fff6e926000 - 0x7fff6e94dfff libsystem_malloc.dylib (283.100.6) <D4BA7DF2-57AC-33B0-B948-A688EE43C799> /usr/lib/system/libsystem_malloc.dylib
0x7fff6e94e000 - 0x7fff6e95bffb libsystem_networkextension.dylib (1095.120.6) <6DE86DB0-8CD2-361E-BD6A-A34282B47847> /usr/lib/system/libsystem_networkextension.dylib
0x7fff6e95c000 - 0x7fff6e965ff7 libsystem_notify.dylib (241.100.2) <7E9E2FC8-DF26-340C-B196-B81B11850C46> /usr/lib/system/libsystem_notify.dylib
0x7fff6e966000 - 0x7fff6e96efef libsystem_platform.dylib (220.100.1) <736920EA-6AE0-3B1B-BBDA-7DCDF0C229DF> /usr/lib/system/libsystem_platform.dylib
0x7fff6e96f000 - 0x7fff6e979fff libsystem_pthread.dylib (416.100.3) <77488669-19A3-3993-AD65-CA5377E2475A> /usr/lib/system/libsystem_pthread.dylib
0x7fff6e97a000 - 0x7fff6e97eff3 libsystem_sandbox.dylib (1217.120.7) <20C93D69-6452-3C82-9521-8AE54345C66F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff6e97f000 - 0x7fff6e981fff libsystem_secinit.dylib (62.100.2) <E851113D-D5B1-3FB0-9D29-9C7647A71961> /usr/lib/system/libsystem_secinit.dylib
0x7fff6e982000 - 0x7fff6e989ffb libsystem_symptoms.dylib (1238.120.1) <25C3866B-004E-3621-9CD3-B1E9C4D887EB> /usr/lib/system/libsystem_symptoms.dylib
0x7fff6e98a000 - 0x7fff6e9a0ff2 libsystem_trace.dylib (1147.120) <A1ED1D3A-5FAD-3559-A1D6-1BE4E1C5756A> /usr/lib/system/libsystem_trace.dylib
0x7fff6e9a2000 - 0x7fff6e9a7ff7 libunwind.dylib (35.4) <253A12E2-F88F-3838-A666-C5306F833CB8> /usr/lib/system/libunwind.dylib
0x7fff6e9a8000 - 0x7fff6e9ddffe libxpc.dylib (1738.120.8) <68D433B6-DCFF-385D-8620-F847FB7D4A5A> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 11
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 3581
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=901.7M resident=0K(0%) swapped_out_or_unallocated=901.7M(100%)
Writable regions: Total=17.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=17.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 1
CG backing stores 1160K 2
CG image 1132K 9
CoreAnimation 156K 12
CoreGraphics 8K 1
CoreImage 28K 3
CoreServices 132K 1
CoreUI image data 876K 7
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 14.5G 1014
MALLOC guard page 48K 9
Memory Tag 242 12K 1
OpenGL GLSL 256K 3
STACK GUARD 704K 176
Stack 1.0G 177
VM_ALLOCATE 2.2G 1970
__DATA 114.2M 390
__DATA_CONST 412K 7
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 432.7M 15
__OBJC_RO 32.2M 1
__OBJC_RW 1892K 2
__TEXT 469.0M 374
__UNICODE 564K 1
mapped file 67.8M 24
shared memory 636K 15
TOTAL 18.9G 4222
Model: MacBookPro15,1, BootROM 1037.147.4.0.0 (iBridge: 17.16.16610.0.0,0), 6 processors, 6-Core Intel Core i9, 2.9 GHz, 32 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro560XItem, Radeon Pro 560X, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Feb 28 2020 15:24:56 version 9.30.357.35.32.5.47 FWID 01-9ce4adf3
Bluetooth: Version 7.0.5f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.1 Bus
USB Device: Apple T2 Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 47.4
