Hello my komputer eror kod
Blender 2.90.0 System Information
Blender:
version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: 0330d1af29c0, type: Release
build date: 2020-08-31, 10:00:13
platform: Windows
binary path: 'D:\\blender-2.90.0-windows64\\blender.exe'
build cflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP /bigobj -openmp
build cxxflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc /bigobj /permissive- /Zc:twoPhase- -openmp /std:c++17
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.7.7 (default, Jun 13 2020, 11:11:23) [MSC v.1916 64 bit (AMD64)]
file system encoding: utf-8:surrogatepass
paths:
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\startup'
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\modules'
'D:\\blender-2.90.0-windows64\\python37.zip'
'D:\\blender-2.90.0-windows64\\2.90\\python\\DLLs'
'D:\\blender-2.90.0-windows64\\2.90\\python\\lib'
'D:\\blender-2.90.0-windows64'
'D:\\blender-2.90.0-windows64\\2.90\\python'
'D:\\blender-2.90.0-windows64\\2.90\\python\\lib\\site-packages'
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\freestyle\\modules'
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\addons\\modules'
'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\scripts\\addons\\modules'
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\addons'
'D:\\blender-2.90.0-windows64\\2.90\\scripts\\addons_contrib'
Python (External Binary):
binary path: 'D:\\blender-2.90.0-windows64\\2.90\\python\\bin\\python.EXE'
version: Command '['D:\\blender-2.90.0-windows64\\2.90\\python\\bin\\python.EXE', '--version']' returned non-zero exit status 3221225781.
Directories:
scripts:
'D:\\blender-2.90.0-windows64\\2.90\\scripts'
user scripts: 'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\scripts'
pref scripts: None
datafiles: 'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\datafiles\\'
config: 'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\config\\'
scripts : 'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\scripts\\'
autosave: 'C:\\Users\\sdgfh\\AppData\\Roaming\\Blender Foundation\\Blender\\2.90\\autosave\\'
tempdir: 'C:\\Users\\sdgfh\\AppData\\Local\\Temp\\blender_a02076\\'
FFmpeg:
avcodec: '58, 54, 100'
avdevice: '58, 8, 100'
avformat: '58, 29, 100'
avutil: '56, 31, 100'
swscale: ' 5, 5, 100'
SDL:
Version: 2.0.12
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
error C1115: unable to find compatible overloaded function "tex2Dgather(usampler2D, vec2, int)"
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x0000000143638FB0
Module : blender.exe
Thread : 0000007c
0, comp :    4, size : 0.00 MiB,	 SRGB8_ALPHA8
GPUTexture: create : TEXTURE_2D, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB, RGBA8
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 1, size : 1.25 MiB, R16UI
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 4, size : 10.03 MiB, RGBA16F
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 2, size : 2.51 MiB, RG16F
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 1, size : 2.51 MiB, DEPTH24_STENCIL8
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 2, size : 1.25 MiB, RG8
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 4, size : 2.51 MiB, RGBA8
GPUTexture: create : TEXTURE_2D, w : 64, h : 16, d : 0, comp : 1, size : 0.00 MiB, R8
GPUTexture: create : TEXTURE_2D, w : 160, h : 560, d : 0, comp : 2, size : 0.17 MiB, RG8
GPUTexture: create : TEXTURE_3D, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB, RGBA8
GPUTexture: create : TEXTURE_1D, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB, RGBA8
GPUTexture: create : TEXTURE_2D, w : 1, h : 1, d : 0, comp : 1, size : 0.00 MiB, DEPTH_COMPONENT24
GPUTexture: create : TEXTURE_2D, w : 1128, h : 583, d : 0, comp : 4, size : 2.51 MiB, SRGB8_ALPHA8
Writing: C:\Users\sdgfh\AppData\Local\Temp\blender.crash.txt
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.EditedSep 5 2020, 10:09 AM
Thank you for your report. Unfortunately, it is missing information, which are required for us to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem.
Please submit a new report through Help > Report a bug in Blender and carefully follow the submission template. Please provide system information (operating system, GPU, driver version), Blender version, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem. Also please upload the crash log located at C:\Users\sdgfh\AppData\Local\Temp\blender.crash.txt. A file can be uploaded by clicking on the upload button as shown in the screenshot below:
Robert Guetzkow (rjg) closed this task as Archived.Sep 5 2020, 10:12 AM
Robert Guetzkow (rjg) claimed this task.
Please ensure that your hardware fulfills the minimum requirements for running Blender and that your graphics driver is up to date. See ticket T67439 for a similar issue.
