Bevel Modifier Ruins Shade Smooth?
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.77
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
So when you activate the bevel modifier, it shouldn't make it so that you can now see the individual flat faces of the mesh, but it does?
With Bevel Turned off, smooth shading
With Bevel modifier turned on, smooth shading. See how the individual faces are now showing? Why?
Here's a file with a random cube, with bevel turned off:
With Bevel turned on:
shouldn't the faces be smooth irrespective to the bevel modifier?
Thanks
You have the limit method set to none which means every edge will be beveled. Turn on wire frame mode to see it.
Should you have questions like these in the future, I suggest taking a look at Blender Stack Exchange.
This is not a bug.
The generated mesh is the expected one for the defined configurations.
And the visualized geometry is the expected result in any application that uses OpenGL.
Search for "Smooth Shading".
