Using Solidify with boolean modifier closes hole / unexpected results
I'm using Blender 2.9, Ubuntu 18.04
I was testing the differences between 2.83 and 2.9 using the Solidify and Boolean modifier and found an issue with some objects.
I was following this video
https://youtu.be/qEtIACrEk-I?t=229
I tried to increase the Thickness value gradually and the hole closes up before I get to 0.2mm for thickness see test1.gif video / animation below
I also tried Flipping normals but that prevents the bolt threads from increasing in size to 0.2mm see test2.gif video / animation below
I've also attached the Blend file
