Missing denoise function in cycles
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
After updating from 2.83.5 to 2.90.0, I'm missing the denoising function while rendering with cycles. The way over the compositor to denoising the rendered image works fine.
Starting the program, switch to "cycles" go to "Render layers" (I don't know what the exact name is), there are only "View Layer", "Passes", "Filter" and "Override"
Alaska (Alaska) closed this task as Archived.Sep 8 2020, 10:08 AM
Alaska (Alaska) claimed this task.
Alaska (Alaska) added a subscriber: Alaska (Alaska).
This is because the denoise setting is now found in the render settings panel:
Depending on your system you may have three options:
NLM
OpenImageDenoise
OptiX
NLM is the same as the "old denoiser" (Found in the Render layers tab in Blender 2.83).
OpenImageDenoise uses the same type of denoiser used by the compositor.
OptiX uses the OptiX denoiser developed by Nvidia
