Autosave does not work for me under Mac OS
Operating system: Mac OS Catalina 10.15.6
Graphics card: AMD Radeon Pro 5500M 8 GB and Intel UHD Graphics 630 1536 MB
Broken: 2.83 and 2.9 Mac
Worked: None
Autosave does not work. I have tried default settings. And I have tried putting the Application on Desktop and run it from there to se if that was some starange stuff goin on when running it from Applications folder. My user is the only user on this computer.
Start default scene and check so the settings are correct (default) save on desktop (and the same in every folder I have tried) and waited for 5 minutes to se if there is any autosave.blend files. But none.
AutoSave files are saved in temp directory, make sure you are looking in the right place.
File > Recover > Auto Save...
https://docs.blender.org/manual/en/dev/troubleshooting/recover.html
Yes, but I don't get any temp, tmp or other folder with autosaves ether. And when I press File > Recover > Auto Save... I don't have any files there.
https://pasteboard.co/JqgFqFG.png
Try running Blender from the Terminal.
cd /Applications/Blender.app/Contents/MacOS
./Blender
Then close Blender. There (in the normal case) should be a report like:
Saved session recovery to '/var/folders/78/83_rsx0j1jb338_yc2gbsyz00000gn/T/quit.blend'
What do you have? Also wait until autosave, there may be an error message.
I get this from ther terminal:
haffy@MBP-Haffy ~ % cd /Applications/Blender\ 2.9.app/Contents/MacOS
haffy@MBP-Haffy MacOS % ./Blender
Read prefs: /Users/haffy/Library/Application Support/Blender/2.90/config/userpref.blend
found bundled python: /Applications/Blender 2.9.app/Contents/Resources/2.90/python
register_class(...):
Warning: 'CloudIssuesList' doesn't contain '_UL_' with prefix & suffix
Warning: 'NodeReportList' doesn't contain '_UL_' with prefix & suffix
2020-09-09 12:52:50,450 ; INFO ; #### LOGGING START #####
2020-09-09 12:52:50,450 ; INFO ; Blender Version ; (2, 90, 0)
2020-09-09 12:52:50,450 ; INFO ; Bl Build type ; b'Release'
2020-09-09 12:52:50,450 ; INFO ; Bl Build Branch ; b'master'
2020-09-09 12:52:50,450 ; INFO ; Bl Platform ; b'Darwin'
2020-09-09 12:52:50,450 ; INFO ; Bl bundled python ver ; 3.7.7 (default, Jul 8 2020, 14:54:17)
[Clang 11.0.0 (clang-1100.0.33.8)]
2020-09-09 12:52:50,451 ; INFO ; cr build type ; release
2020-09-09 12:52:50,451 ; INFO ; cr build branch ; trunk/Blender_addon/2.80/User/Crowdrender r$LastChangedRevision: 1541 $
2020-09-09 12:52:50,451 ; INFO ; cr logging mode is ; 20
2020-09-09 12:52:50,451 ; INFO ; cr version is ; (0, 2, 8)
2020-09-09 12:52:50,451 ; INFO ; System architecture ; x86_64
2020-09-09 12:52:50,451 ; INFO ; Computer name ; MBP-Haffy.local
2020-09-09 12:52:50,451 ; INFO ; Platform details ; Darwin-19.6.0-x86_64-i386-64bit
2020-09-09 12:52:50,451 ; INFO ; OS version ; ('10.15.6', ('', '', ''), 'x86_64')
Crowd Render user_session add-on enabled
chocofur_model_manager_28 updater verbose is enabled
chocofur_model_manager_28 Updater: Read in json settings from file
chocofur_model_manager updater: Running background check for update
2020-09-09 12:52:50,493 ; INFO ; CRClient Network interfaces initialised
starting crowdrender...
hash_tree created
top hash changed, new value: 8273020388897257154136175873457376
Crowdrender: number of hash tree nodes: 25
Crowdrender: mem usage for hash tree: 3040
STARTED CROWDRENDER
Blender 2.90.0 (hash 0330d1af29c0 built 2020-08-31 12:16:14)
Crowd Render Client Interface Process ready
Crowd Render Server Interface Process ready
2020-09-09 12:52:54,501 ; INFO ; SIP is AlIVE
2020-09-09 12:52:54,532 ; INFO ; CIP is ALIVE
2020-09-09 12:52:54,532 ; INFO ; sent refresh requests for user credit, node list and
rental instances
Info: Saved "untitled.blend"
Saved session recovery to '/var/folders/0n/9j6c5rxj6wjcct0fwrj9zw840000gn/T/quit.blend'
File "/Users/haffy/Library/Application Support/Blender/2.90/scripts/addons/crowdrender/src/py_3_7/cl_int_start.py", line 65, in <module>
  cs_manager = client_interface.CRClientServerManager()
File "/CR_BUILD_SYSTEM/client_interface.py", line 1217, in __init__
File "/CR_BUILD_SYSTEM/client_interface.py", line 1543, in cs_manager_main
File "/CR_BUILD_SYSTEM/client_interface.py", line 1355, in process_msgs
File "/Users/haffy/Library/Application Support/Blender/2.90/scripts/addons/crowdrender/lib/Darwin/3_7/zmq/sugar/poll.py", line 103, in poll
  return zmq_poll(self.sockets, timeout=timeout)
File "zmq/backend/cython/_poll.pyx", line 143, in zmq.backend.cython._poll.zmq_poll
File "zmq/backend/cython/_poll.pyx", line 123, in zmq.backend.cython._poll.zmq_poll
File "zmq/backend/cython/checkrc.pxd", line 26, in zmq.backend.cython.checkrc._check_rc
zmq.error.ZMQError: Socket operation on non-socket
Error in atexit._run_exitfuncs:
File "/CR_BUILD_SYSTEM/client_interface.py", line 3534, in shutdown
File "/Users/haffy/Library/Application Support/Blender/2.90/scripts/addons/crowdrender/lib/Darwin/3_7/zmq/sugar/socket.py", line 584, in send_string
  return self.send(u.encode(encoding), flags=flags, copy=copy, **kwargs)
File "/Users/haffy/Library/Application Support/Blender/2.90/scripts/addons/crowdrender/lib/Darwin/3_7/zmq/sugar/socket.py", line 416, in send
  return super(Socket, self).send(data, flags=flags, copy=copy, track=track)
File "zmq/backend/cython/socket.pyx", line 728, in zmq.backend.cython.socket.Socket.send
File "zmq/backend/cython/socket.pyx", line 769, in zmq.backend.cython.socket.Socket.send
File "zmq/backend/cython/socket.pyx", line 135, in zmq.backend.cython.socket._check_closed
Blender quit
Blender quit
Blender quit
Try also renaming the 2.90 folder or moving it to a different location.
This way you can run a clean Blender without add-ons or settings.
What happens when you press "File" > "Recover" > "Last Session",
the quit.blend is saved in the same folder as autosave.blend.
So it should be here:
I have now downloaded a new 2.9, put it inside a "Blender 2.9 default" folder inside "Applications" and checked that default settings is used, and then I ran it from the terminal. And this is what I get, and I GET AN AUTOSAVE file :) Finally some progress, I thought it was a myth ;)
found bundled python: /Applications/Blender 2.9 default/Blender.app/Contents/Resources/2.90/python
Info: Total files 0 | Changed 0 | Failed 0
Blender quit
Richard Antalik (ISS) closed this task as Archived.Sep 15 2020, 11:40 AM
Richard Antalik (ISS) claimed this task.
@Fredrik Hallén (haffy) If I read this correctly, the problem is resolved, so I will close this report.
