nodes dont display properly on OSX 10.5
Mackbook Pro 17" 4gb ram, Geforce 8600M GT
In Leopard, using the 10.5 download on the Blender download page. when use composite nodes, any node that has an image displayed will have static, or show two versions of the image side by side, but squished.
if its unreproducible i can post a screen shot.
I've got the same on my 15" MBP, similar specs as yours.
Our lead OS X dev - lukep - is back so hopefully he can have a look
hmm. no problem here with a G5 PPC, Os X 10.4.
static in view and/or 2 images were previously sign of incorrect sync.
This may be 10.5 specific, a bad library, or driver caused.
With Apples changes in the OGL pipeline, there is plenty of failure points
Does it affects all images (eg UV editor) or only nodes ?
10.4 MBP, no problems!
This is similar to background image problem... leave that one open, move this to opengl tracker. (And tell me when apple upgrades!)
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:38 AM
