version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: 0330d1af29c0, type: Release
build date: 2020-08-31, 10:00:13
platform: Windows with updated gpu driver.
If you set the viewport clipping distance start to a lower number than (0.001 meters) you cannot see the green square that snaps to vertices and the tool does not work.
This also happens in blender 2.82.
Reproduce:
- Set viewport clip start to 0.0001 or lower.
- Make a box and go into edit mode.
- Press K and try to make a cut - this should not be possible.
- Set the Clip start to 0.001 or higher, now you should be able to cut again.
