Clay Strips Brush Doesn't work correctly when the size brush is bigger and the thickness is thin.
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
Clay Strips Brush Doesn't work correctly when the size brush is bigger and the thickness is thin. The brush works correctly when I use the key control. I was working on sculpting 3D character y this problem occurred when I sculpted on the foot. And Later I simplified the geometry in a new file but it was the same result.
1-Sculpt mode 2-Clay strips brush 3-Bigger size 4-Sculpt on the thinnest surface
Go to the brush settings/advanced, then enable "front faces only"
Thanks. For future problems, I am going to check this before. :)
As you can see in the fallowoff options, this brush affects the entire area within a sphere.
So it is natural that the back part in a thin thickness geometry is affected.
