Grease Pencil: Subdivide Modifier does not subdivide one of the segments of a closed loop
Closed, ResolvedPublicKNOWN ISSUE
Operating system:Windows 10 Pro
Graphics card:NVIDIA GeForce GTX 750 Ti
Broken: 2.90
Worked: n/a
This is the result of a subdivided polygon:
  • Draw a polygon
  • Apply the Subdivide modifier
Shigenori Iwase (SHIWA) updated the task description. (Show Details)
This comment was removed by Shigenori Iwase (SHIWA).
Germano Cavalcante (mano-wii) renamed this task from can't draw a perfect circle to Grease Pencil: Subdivide Modifier does not subdivide one of the segments of a closed loop.Sep 22 2020, 9:59 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
I'm not sure if this fits as a bug or ToDo but I'm confirming it as a bug for now.
Antonio Vazquez (antoniov) changed the subtype of this task from "Bug" to "Known Issue".Sep 23 2020, 4:13 PM
I will set a Know Issue because this is a non supported feature. Actually, the modifier works from first to last point, and the cyclic flag is only at draw time (not real geometry), so the section that closes the stroke is not subdivided because it doesn't exist as geometry.. To add this feature, I would have to implement the same algorithm used when you select first and last point and press ' F`. In this case, the algoritm adds points at the same distance of the average distance in the stroke.
I add this feature to my ToDo list.
Fixed with e296d58cf220
