Play problem
Operating system:Windows 10
Graphics card:Intel integrated graphics card-6gb
Broken:2.90
(example: 2.79b release)
Short description of errorI made a model of monkey on fire when I try to run it does not run and also if I view it from different views the smoke cloud just gets overlap and overlap
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Sep 24 2020, 3:23 PM
Cannot reproduce here.
Are you sure this folder exists on your side?
If I set it to an existing folder on my side, playback is fine.
What GPU and driver version are you using?
Ankit Meel (ankitm) closed this task as Archived.Oct 7 2020, 9:44 AM
Ankit Meel (ankitm) claimed this task.
