When using the 'Image Editor' > 'Paint' tools, reducing the size of the 'editor window' to half the screen, with another 'editor type' on the other half, the dropdowns named: 'advanced', 'stroke', 'fallout', 'brush tip', 'texture' and 'texture mask' are all hidden as they slide out of the right side as the second 'editor window' is made larger.
Rather than do this, they should drop down to beneath their original position; beneath the 'TexDraw' and 'color' fields, the 'brush blending mode', 'Radius' and 'Strength' slider. That way, these functions would still be accessible even with only a 1/2 sized screen, without taking up much space.
If this is not a bug it should be changed for, as it stands, having to scroll through the options is wasteful of time. Both options can be kept, but the ability to 'pull it down' should be added.
Thank you
