Material Library VX - Categories feature and adding textures extremely slow
Graphics card: Quadro 4000/PCIe/SSE2 NVIDIA Corporation 4.4.0
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Addon Information
Name: Material Library (0, 6, 0)
Author: Mackraken
  1. Creating new texture library in Material Library VX - in shading tab. Currently have about 70 textures in library I'm adding textures to. Also have the textures in the Sample Library.
Add a texture from free PBR texture files or other online source. Example: Added Color, Normals, Roughness files to Nodes, following best practices. Set fake user, name material. Click "+Add to Library" in menu. Takes roughly 3 to 5 minutes to add one material to library.
  1. Adding new Categories and tagging materials with them. Click +New. Type in new Category. Hit Enter. Takes a few minutes to create a category. It also takes several minutes to add a single material to a category. This is so slow as to be useless. I have to walk away from the computer while I wait for a single material to be categorized. I am a fairly new user of Blender, but have been a 3DS Max user for over 15 years, and was a beta tester for Discreet Logic Combustion. Thanks for any help you can give.
Related Objects
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 10 2022, 1:47 PM
Adding new materials seems to happen in constant time for me even with 70 entries. Can you attach the material library you are having issues with? You can find that material library in <user-configurations>/blender/matlib/<name-of-library>.blend.
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
