Smoke does not leave through open domain boundary
Confirmed, NormalPublicBUG
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: rB3e85bb34d0d7
unknown
  1. start blender
  2. add fluid domain to default cube
  3. add border collision to bottom
  4. Change cache type to Modular
  5. Change gas bouyancy density to 0 and Heat to 0
  6. Add 0.5m mesh plane
  7. add fluid->inflow to mesh plane
  8. set inflow initial temperature to 0
  9. enable initial velocity to mesh plane
  10. set initial z-velocity to -1m/s
  11. bake fluid domain
  12. See how smoke is crawling up along side walls despite that border collision is not enable for these walls. I see this as a bug.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Oct 5 2020, 1:27 PM
Can confirm.
It is not the same as having the Domain Border collision being turned on on the sides, but still, some smoke seems to collide with the Domain border here.
Same thing also happens with just a Plane as collider (so it is not isolated to specific Domain Border collision being turned on)
I have similar errors with 2.93.5, the smoke seems to collide before removed from the simulation. Maybe just following smoke is hitting smoke that is queued to be removed.
I tested with no gravity and used force to let the smoke "collide" with the border with a border collisions all turned off.
Smoke collides with border collision is turned off and 0, 10, 45, 90 angle rotation:
45° looks correct
Removing smoke with outflow has not this problem:
Test .blend
