Hiding in the Outliner and hiding in the 3D viewport bug
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-05 21:23, hash: rB3178dc25f6ed
Worked: 2.90.1
If you hide an object in the Outliner using the eye icon, the object's title is greyed out as it should, but if you hide an object in the 3D viewport using the H shortcut, the object's title in the Outliner stays the same. Also, if you hide the object using the eye icon and then you press the shortcut Alt+H to make everything visible again, the object's title is still greyed out (SEE VIDEO ATTACHED).
H SHORTCUT BUG: Activate the *hide in viewport* icon in the outliner's restriction column>Add an object>Hide the object in the 3D viewport using the H shortcut.
ALT+H SHORTCUT BUG: Activate the *hide in viewport* icon in the outliner's restriction column>Add an object>Hide the object in the Outliner using the eye icon>Press the ALT+H shortcut in the 3D viewport.
[Based on the default startup]
slwk1d (Slowwkidd) updated the task description. (Show Details)
Henrik Dick (weasel) changed the task status from Needs Triage to Confirmed.Oct 6 2020, 11:07 PM
Can confirm.
Also note that if you change any property from the outliner, it will update the greyed out state of all objects.
Bastien Montagne (mont29) changed the task status from Confirmed to Needs Information from User.Oct 14 2020, 4:59 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
Cannot reproduce that with current master, can someone please confirm whether it is working again or not? Thanks.
I tested again. The problem is also gone for me.
Operating system: Linux-5.8.0-2-amd64-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.66
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-09 21:39, hash: rB7ab8d7c939e8
Fixed: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-14 15:18, hash: rB4fa424546438
slwk1d (Slowwkidd) added a comment.EditedOct 14 2020, 7:48 PM
Also for me, evidently the problem was somehow fixed with a newer release: I don't know how, I just reported the bug I'm not a developer, should I just change the report as closed?
version: 2.91.0 Alpha, branch: master, commit date: 2020-10-14 07:52, hash: 5edba9b42f68, type: Release
build date: 2020-10-14, 09:25:08
Philipp Oeser (lichtwerk) closed this task as Resolved.Oct 14 2020, 7:51 PM
OKi, thx getting back, will close then (have not hunted down the exact commit though).
