Motion Blur in EEVEE is not blending steps properly for camera motion in newer versions
Operating system: Microsoft Windows 10 Pro
Graphics card: Nvidia GeForce GTX 1050
Processor: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz, 3301 Mhz, 4 Core(s), 4 Logical Processor(s)
Broken: blender-2.92.0-e4728d0a167c-windows64
Worked: New in 2.90, didn't work in older builds of 2.90
When there is very high camera motion blur in EEVEE, a step value greater than 1 introduces noticeable steps which don't get properly blended. There is some post-process blur but not enough to fill the gaps. Changing Max Blur or Background Separation doesn't help.
This bug was previously reported. I thought that the bug got fixed, but in reality time step blur was temporarily not working, making it look like the blending issue was not present. In the newest versions, the bug is now present again.
Start with default blend file
Go to frame 1 and rotate the camera so the default cube is at the left of the screen
Add a keyframe (of rotation)
Go to frame 5 and rotate the camera so the default cube is at the right of the screen
Add another rotation keyframe
Turn on motion blur with steps set to 4
Render a still image at frame 3
Notice stepping artifacts not being blended properly by the post-process motion blur.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Oct 16 2020, 7:51 PM
I tested it on different versions of 2.90 and got the same result.
What was the subversion of 2.90 that really worked? (you can share the System Info in Help -> Save System Info)
Here the file I used:
But compared to the images in the manual, 4 steps apparently should have a smoother transition.
So I'm not sure if the transition with 4 steps shown in the image is really expected. (@Clément Foucault (fclem)?)
It never actually worked. There was just a version where I couldn't use multiple time steps due to a different bug (https://developer.blender.org/T79646). At first I didn't realize there was a bug, and no time steps meant no blending issues (since there were no steps to blend between) so I thought it was gone. The bug later got fixed (not this blending bug but the time step one) and the blending issues came back. The hash mentioned in the post is rBa93be410c974. So, even in that version the bug was not fixed. As far as I know, it has been there ever since the new motion blur was added. I hope I am clear.
Additional info: this bug only affects camera motion, if I do the exact same thing but changing location of the cube rather than camera position, it blends fine.
Clément Foucault (fclem) changed the task status from Needs Information from User to Confirmed.Oct 17 2020, 8:33 PM
Clément Foucault (fclem) claimed this task.
artworker updated the task description. (Show Details)Oct 24 2020, 3:54 AM
