When the cycles render building BVH then crash
Graphics card: Intel(R) UHD Graphics 630 Intel 4.5.0 - Build 27.20.100.8280
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: rB3e85bb34d0d7
When I try to render with F12, render windows show "Updating Scence, Building BVH 1%", then crashes and closes blender.
Open blender file, press F12 to render, wait to show "Updating Scence, Building BVH 1%", then crashes and closes blender.
Exception Record:
ExceptionCode : EXCEPTION_ACCESS_VIOLATION
Exception Address : 0x00007FF7C7C97CEE
Exception Module : blender.exe
Exception Flags : 0x00000000
Exception Parameters : 0x2
Parameters[0] : 0x0000000000000000
Parameters[1] : 0x00000093E7DF8260
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Oct 16 2020, 12:35 PM
Can you please check if this issue also occurs in Blender 2.83 and 2.91?
Thank’s to Robert reply, I tried to use the latest version 2.91, but the problem remains. Now I‘m testing the 2.83.7 version, and it seems that no crash has occurred.
Thank you for checking. Does this only occur in a particular project or does this also happen with the default cube scene? If this happens in a particular project, please create a copy of the .blend file and remove everything that is not relevant to the error. Upload the minimal .blend file that still exhibits the issue to your bug report.
It happens in a particular project, I have uploaded the minimal .blend file.
Robert Guetzkow (rjg) changed the task status from Needs Information from User to Needs Triage.Oct 16 2020, 1:18 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Oct 20 2020, 4:40 AM
@Wang Yuanqing (yuanqing_w) Can you check if you have enough free RAM? How much RAM do you have?
I have 32GB of RAM, which only takes up about 25GB when rendering.
I tested that this happens in versions above 2.90. It is normal when used after a clean install. After repeated rendering several times, it starts to crashes and closes blender.
And preview in views has also become unstable, often closes blender. The 2.83.7 is very normal and stable.
@Wang Yuanqing (yuanqing_w) Can you try to simplify file even more? I guess you would need to simplify the actual mesh here.
The file is too big for me to do anything to it.
Because my scene is very large, it requires a lot of subdivision grids to reproduce the natural water wave effect of raindrops falling on the water surface. I tried to simplify or rebuild the water mesh,this problem may not happen. This problem occurred after I added particles and dynamic painting and baked it. The baked physics file is too big, so I not provided together. I don't know which step produced it.
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Triage.Oct 22 2020, 4:16 PM
You also don't mention this step in steps to reproduce though. This may be important I think.
Without being able to reproduce the issue there is nothing we can do. I can get more RAM to check this, but please make sure we have all informations we need.
You can bake the physical files yourself, because the physical files are about 580GB in size, I can’t provide them. But the missing physical files should not affect the crash and closing of blender during rendering.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Oct 22 2020, 5:08 PM
That is insane amount of data. I don't even have drive handy to store that.
As I said, I will try to confirm when I get more RAM, but we may still need either steps to create this file or simplify it.
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Triage.Oct 22 2020, 5:09 PM
Oops did not want to change status.
Hello Richard, thanks for reply me. I have created a new blender file and appended the objects in the original file to this new file. Now this file size is reduced to 400MB, and then I used the blender 2.90.1 cycles to render this scence crash and closing again.
This is the blender file I resubmitted.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Nov 9 2020, 6:45 PM
I have looked at your file with 64GB RAM and had no crash. Memory usage was ~32GB during rendering.
In some cases Blender needs to allocate continuous array for large blocks, so even if you have free memory, but it is fragmented, it can cause crash.
If you can't simplify example file beyond this point, it's very likely you run out of memory, but this is not considered a bug.
So please simplify your example file and check if you can reproduce this issue.
Thank you Richard. After I replaced the RTX3080 graphics card, I no longer had the problem of crash and closing. It should be caused by insufficient video memory.
Robert Guetzkow (rjg) closed this task as Archived.Nov 10 2020, 9:41 AM
Robert Guetzkow (rjg) claimed this task.
Your report says, that you used Intel(R) UHD Graphics 630 Intel 4.5.0 - Build 27.20.100.8280 GPU.
In some sases windows doesn't detect "correct" GPU to be used with Blender so this may have been the problem if you had different dedicated GPU.
In any case, I'm glad this is resolved. Thanks for reporting.
