Graphics card: GeForce RTX 2070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-17 21:36, hash: rBf425f40c4e17
Worked: never because it's a new feature
When Alt dragging a value or using "copy to selected" the keyframe values are updated to the correct values but if the keyframes are in "free" or "aligned" mode the bezier handles stay in place which is wrong behaviour.
There is NO case where you want to move the keyframes and have the beziers stay in the same absolute place
Create an object.
Set several keyframes.
Select the keyframes
Press V and select free or aligned.
Use alt drag to slide the value of the active keyframe.
keyframes move but handles stay.
(look at the gif above as it shows the wrong and correct behaviour)
