Operating system: Linux-5.4.0-51-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: AMD Radeon HD 7700 Series (VERDE, DRM 3.35.0, 5.4.0-51-generic, LLVM 11.0.0) X.Org 4.6 (Core Profile) Mesa 20.2.1 - kisak-mesa PPA
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-15 21:02, hash: rBba8233174cd7
Never.
Blender crash with:
received signal SIGILL, Illegal instruction.
0x000000000855e430 in __gmpn_copyi ()
- Add Exact Boolean Modifier to the default cube.
- Add a cylinder to a new collection and setect that collection in the cube modifier.
- Duplicate the cylinder.
- Blender crasches:
gdb output
... New Thread 0x7fffce53d700 (LWP 24229)] [New Thread 0x7fffcd93c700 (LWP 24230)] [New Thread 0x7fffcb57f700 (LWP 24231)] [New Thread 0x7fffcabff700 (LWP 24232)] [Thread 0x7fffcabff700 (LWP 24232) exited] [New Thread 0x7fffca3fe700 (LWP 24233)] found bundled python: /opt/blender/blender-2.91.0-ba8233174cd7-linux64-201015/2.91/python LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr4 = V_CNDMASK_B32_e32 32768, killed $vgpr5, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr2 = V_CNDMASK_B32_e32 32768, killed $vgpr2, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part Thread 1 "blender91" received signal SIGILL, Illegal instruction. 0x000000000855e430 in __gmpn_copyi () bt #0 0x000000000855e430 in __gmpn_copyi () #1 0x00000000085663e3 in __gmpn_tdiv_qr () #2 0x0000000008564617 in __gmpn_gcd () #3 0x000000000855fdd8 in __gmpz_gcd () #4 0x00000000085413f0 in () #5 0x0000000008541583 in __gmpq_add () #6 0x0000000008440ba8 in blender::incircle(blender::mpq2 const&, blender::mpq2 const&, blender::mpq2 const&, blender::mpq2 const&) () #7 0x000000000841891d in void blender::meshintersect::dc_tri<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >(blender::meshintersect::CDTArrangement<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >*, blender::Array<blender::meshintersect::SiteInfo<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >, blender::default_inline_buffer_capacity(sizeof (blender::meshintersect::SiteInfo<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >)), blender::GuardedAllocator>&, int, int, blender::meshintersect::SymEdge<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >**, blender::meshintersect::SymEdge<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >**) () #8 0x000000000841d17f in void blender::meshintersect::initial_triangulation<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >(blender::meshintersect::CDTArrangement<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >*) () #9 0x0000000008421250 in blender::meshintersect::CDT_result<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> > blender::meshintersect::delaunay_calc<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> >(blender::meshintersect::CDT_input<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> > const&, CDT_output_type) () #10 0x000000000841552a in blender::meshintersect::delaunay_2d_calc(blender::meshintersect::CDT_input<__gmp_expr<__mpq_struct [1], __mpq_struct [1]> > const&, CDT_output_type) () #11 0x0000000008486fd0 in () #12 0x00000000084896d6 in () #13 0x00000000084ac012 in () #14 0x00000000010f3505 in () #15 0x00000000084ac72c in () #16 0x0000000001100c05 in () #17 0x0000000001100ebb in () #18 0x00000000010fe300 in () #19 0x00000000084abdef in BLI_task_parallel_range () #20 0x000000000848d017 in blender::meshintersect::trimesh_nary_intersect(blender::meshintersect::IMesh const&, int, std::function<int (int)>, bool, blender::meshintersect::IMeshArena*) () #21 0x000000000847619a in blender::meshintersect::boolean_trimesh(blender::meshintersect::IMesh&, blender::meshintersect::BoolOpType, int, std::function<int (int)>, bool, blender::meshintersect::IMeshArena*) () #22 0x00000000084795aa in blender::meshintersect::boolean_mesh(blender::meshintersect::IMesh&, blender::meshintersect::BoolOpType, int, std::function<int (int)>, bool, blender::meshintersect::IMesh*, blender::meshintersect::IMeshArena*) () #23 0x0000000001b3c618 in () #24 0x0000000001b3d3a6 in BM_mesh_boolean () #25 0x00000000013a78ec in () #26 0x00000000010633e8 in () #27 0x0000000001063fc5 in () #28 0x000000000106545f in makeDerivedMesh () #29 0x0000000000ef4f00 in BKE_object_handle_data_update () #30 0x0000000000ef520f in BKE_object_eval_uber_data () #31 0x00000000070f8842 in () #32 0x00000000070f8a12 in () #33 0x00000000010f3505 in () #34 0x00000000084aba43 in () #35 0x0000000001100c05 in () #36 0x0000000001100ebb in () #37 0x00000000084ab88a in BLI_task_pool_work_and_wait () #38 0x00000000070f8dc0 in blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*) () #39 0x0000000000f2e1d8 in () #40 0x000000000110988b in wm_event_do_depsgraph () #41 0x00000000011099c7 in wm_event_do_refresh_wm_and_depsgraph () #42 0x00000000011101aa in wm_event_do_notifiers () #43 0x0000000001105d88 in WM_main () #44 0x0000000000d9d78d in main () (gdb) disass Dump of assembler code for function __gmpn_copyi: 0x000000000855e240 <+0>: cmp $0x7,%rdx 0x000000000855e244 <+4>: jbe 0x855e4be <__gmpn_copyi+638> 0x000000000855e24a <+10>: test $0x8,%dil 0x000000000855e24e <+14>: je 0x855e255 <__gmpn_copyi+21> 0x000000000855e250 <+16>: movsq %ds:(%rsi),%es:(%rdi) 0x000000000855e252 <+18>: dec %rdx 0x000000000855e255 <+21>: test $0x8,%sil 0x000000000855e259 <+25>: jne 0x855e2d4 <__gmpn_copyi+148> 0x000000000855e25b <+27>: jmp 0x855e28e <__gmpn_copyi+78> 0x000000000855e25d <+29>: nopl (%rax) 0x000000000855e260 <+32>: movdqa (%rsi),%xmm0 0x000000000855e264 <+36>: movdqa 0x10(%rsi),%xmm1 0x000000000855e269 <+41>: movdqa 0x20(%rsi),%xmm2 0x000000000855e26e <+46>: movdqa 0x30(%rsi),%xmm3 0x000000000855e273 <+51>: lea 0x40(%rsi),%rsi 0x000000000855e277 <+55>: movdqa %xmm0,(%rdi) 0x000000000855e27b <+59>: movdqa %xmm1,0x10(%rdi) 0x000000000855e280 <+64>: movdqa %xmm2,0x20(%rdi) 0x000000000855e285 <+69>: movdqa %xmm3,0x30(%rdi) 0x000000000855e28a <+74>: lea 0x40(%rdi),%rdi 0x000000000855e28e <+78>: sub $0x8,%rdx 0x000000000855e292 <+82>: jae 0x855e260 <__gmpn_copyi+32> 0x000000000855e294 <+84>: test $0x4,%dl 0x000000000855e297 <+87>: je 0x855e2b3 <__gmpn_copyi+115> 0x000000000855e299 <+89>: movdqa (%rsi),%xmm0 0x000000000855e29d <+93>: movdqa 0x10(%rsi),%xmm1 0x000000000855e2a2 <+98>: lea 0x20(%rsi),%rsi 0x000000000855e2a6 <+102>: movdqa %xmm0,(%rdi) 0x000000000855e2aa <+106>: movdqa %xmm1,0x10(%rdi) 0x000000000855e2af <+111>: lea 0x20(%rdi),%rdi 0x000000000855e2b3 <+115>: test $0x2,%dl 0x000000000855e2b6 <+118>: je 0x855e2c8 <__gmpn_copyi+136> 0x000000000855e2b8 <+120>: movdqa (%rsi),%xmm0 0x000000000855e2bc <+124>: lea 0x10(%rsi),%rsi 0x000000000855e2c0 <+128>: movdqa %xmm0,(%rdi) 0x000000000855e2c4 <+132>: lea 0x10(%rdi),%rdi 0x000000000855e2c8 <+136>: test $0x1,%dl 0x000000000855e2cb <+139>: je 0x855e2d3 <__gmpn_copyi+147> 0x000000000855e2cd <+141>: mov (%rsi),%r8 0x000000000855e2d0 <+144>: mov %r8,(%rdi) 0x000000000855e2d3 <+147>: retq 0x000000000855e2d4 <+148>: cmp $0x10,%rdx 0x000000000855e2d8 <+152>: jb 0x855e417 <__gmpn_copyi+471> 0x000000000855e2de <+158>: movaps 0x78(%rsi),%xmm7 0x000000000855e2e2 <+162>: movaps 0x68(%rsi),%xmm6 0x000000000855e2e6 <+166>: movaps 0x58(%rsi),%xmm5 0x000000000855e2ea <+170>: movaps 0x48(%rsi),%xmm4 0x000000000855e2ee <+174>: movaps 0x38(%rsi),%xmm3 0x000000000855e2f2 <+178>: movaps 0x28(%rsi),%xmm2 0x000000000855e2f6 <+182>: lea 0x80(%rsi),%rsi 0x000000000855e2fd <+189>: sub $0x20,%rdx 0x000000000855e301 <+193>: jb 0x855e3a8 <__gmpn_copyi+360> 0x000000000855e307 <+199>: nopw 0x0(%rax,%rax,1) 0x000000000855e310 <+208>: movaps -0x68(%rsi),%xmm1 0x000000000855e314 <+212>: sub $0x10,%rdx 0x000000000855e318 <+216>: movaps -0x78(%rsi),%xmm0 0x000000000855e31c <+220>: palignr $0x8,%xmm6,%xmm7 0x000000000855e322 <+226>: movaps -0x88(%rsi),%xmm8 0x000000000855e32a <+234>: movdqa %xmm7,0x70(%rdi) 0x000000000855e32f <+239>: palignr $0x8,%xmm5,%xmm6 0x000000000855e335 <+245>: movaps 0x78(%rsi),%xmm7 0x000000000855e339 <+249>: movdqa %xmm6,0x60(%rdi) 0x000000000855e33e <+254>: palignr $0x8,%xmm4,%xmm5 0x000000000855e344 <+260>: movaps 0x68(%rsi),%xmm6 0x000000000855e348 <+264>: movdqa %xmm5,0x50(%rdi) 0x000000000855e34d <+269>: palignr $0x8,%xmm3,%xmm4 0x000000000855e353 <+275>: movaps 0x58(%rsi),%xmm5 0x000000000855e357 <+279>: movdqa %xmm4,0x40(%rdi) 0x000000000855e35c <+284>: palignr $0x8,%xmm2,%xmm3 0x000000000855e362 <+290>: movaps 0x48(%rsi),%xmm4 0x000000000855e366 <+294>: movdqa %xmm3,0x30(%rdi) 0x000000000855e36b <+299>: palignr $0x8,%xmm1,%xmm2 0x000000000855e371 <+305>: movaps 0x38(%rsi),%xmm3 0x000000000855e375 <+309>: movdqa %xmm2,0x20(%rdi) 0x000000000855e37a <+314>: palignr $0x8,%xmm0,%xmm1 0x000000000855e380 <+320>: movaps 0x28(%rsi),%xmm2 0x000000000855e384 <+324>: movdqa %xmm1,0x10(%rdi) 0x000000000855e389 <+329>: palignr $0x8,%xmm8,%xmm0 0x000000000855e390 <+336>: lea 0x80(%rsi),%rsi 0x000000000855e397 <+343>: movdqa %xmm0,(%rdi) 0x000000000855e39b <+347>: lea 0x80(%rdi),%rdi 0x000000000855e3a2 <+354>: jae 0x855e310 <__gmpn_copyi+208> 0x000000000855e3a8 <+360>: movaps -0x68(%rsi),%xmm1 0x000000000855e3ac <+364>: movaps -0x78(%rsi),%xmm0 0x000000000855e3b0 <+368>: movaps -0x88(%rsi),%xmm8 0x000000000855e3b8 <+376>: palignr $0x8,%xmm6,%xmm7 0x000000000855e3be <+382>: movdqa %xmm7,0x70(%rdi) 0x000000000855e3c3 <+387>: palignr $0x8,%xmm5,%xmm6 0x000000000855e3c9 <+393>: movdqa %xmm6,0x60(%rdi) 0x000000000855e3ce <+398>: palignr $0x8,%xmm4,%xmm5 0x000000000855e3d4 <+404>: movdqa %xmm5,0x50(%rdi) 0x000000000855e3d9 <+409>: palignr $0x8,%xmm3,%xmm4 0x000000000855e3df <+415>: movdqa %xmm4,0x40(%rdi) 0x000000000855e3e4 <+420>: palignr $0x8,%xmm2,%xmm3 0x000000000855e3ea <+426>: movdqa %xmm3,0x30(%rdi) 0x000000000855e3ef <+431>: palignr $0x8,%xmm1,%xmm2 0x000000000855e3f5 <+437>: movdqa %xmm2,0x20(%rdi) 0x000000000855e3fa <+442>: palignr $0x8,%xmm0,%xmm1 0x000000000855e400 <+448>: movdqa %xmm1,0x10(%rdi) 0x000000000855e405 <+453>: palignr $0x8,%xmm8,%xmm0 0x000000000855e40c <+460>: movdqa %xmm0,(%rdi) 0x000000000855e410 <+464>: lea 0x80(%rdi),%rdi 0x000000000855e417 <+471>: test $0x8,%dl 0x000000000855e41a <+474>: je 0x855e463 <__gmpn_copyi+547> 0x000000000855e41c <+476>: movaps 0x38(%rsi),%xmm3 0x000000000855e420 <+480>: movaps 0x28(%rsi),%xmm2 0x000000000855e424 <+484>: movaps 0x18(%rsi),%xmm1 0x000000000855e428 <+488>: movaps 0x8(%rsi),%xmm0 0x000000000855e42c <+492>: movaps -0x8(%rsi),%xmm4 => 0x000000000855e430 <+496>: palignr $0x8,%xmm2,%xmm3 0x000000000855e436 <+502>: movdqa %xmm3,0x30(%rdi) 0x000000000855e43b <+507>: palignr $0x8,%xmm1,%xmm2 0x000000000855e441 <+513>: movdqa %xmm2,0x20(%rdi) 0x000000000855e446 <+518>: palignr $0x8,%xmm0,%xmm1 0x000000000855e44c <+524>: movdqa %xmm1,0x10(%rdi) 0x000000000855e451 <+529>: palignr $0x8,%xmm4,%xmm0 0x000000000855e457 <+535>: lea 0x40(%rsi),%rsi 0x000000000855e45b <+539>: movdqa %xmm0,(%rdi) 0x000000000855e45f <+543>: lea 0x40(%rdi),%rdi 0x000000000855e463 <+547>: test $0x4,%dl 0x000000000855e466 <+550>: je 0x855e491 <__gmpn_copyi+593> 0x000000000855e468 <+552>: movaps 0x18(%rsi),%xmm1 0x000000000855e46c <+556>: movaps 0x8(%rsi),%xmm0 0x000000000855e470 <+560>: palignr $0x8,%xmm0,%xmm1 0x000000000855e476 <+566>: movaps -0x8(%rsi),%xmm3 0x000000000855e47a <+570>: movdqa %xmm1,0x10(%rdi) 0x000000000855e47f <+575>: palignr $0x8,%xmm3,%xmm0 0x000000000855e485 <+581>: lea 0x20(%rsi),%rsi 0x000000000855e489 <+585>: movdqa %xmm0,(%rdi) 0x000000000855e48d <+589>: lea 0x20(%rdi),%rdi 0x000000000855e491 <+593>: test $0x2,%dl 0x000000000855e494 <+596>: je 0x855e4b2 <__gmpn_copyi+626> 0x000000000855e496 <+598>: movdqa 0x8(%rsi),%xmm0 0x000000000855e49b <+603>: movdqa -0x8(%rsi),%xmm3 0x000000000855e4a0 <+608>: palignr $0x8,%xmm3,%xmm0 0x000000000855e4a6 <+614>: lea 0x10(%rsi),%rsi 0x000000000855e4aa <+618>: movdqa %xmm0,(%rdi) 0x000000000855e4ae <+622>: lea 0x10(%rdi),%rdi 0x000000000855e4b2 <+626>: test $0x1,%dl 0x000000000855e4b5 <+629>: je 0x855e4bd <__gmpn_copyi+637> 0x000000000855e4b7 <+631>: mov (%rsi),%r8 0x000000000855e4ba <+634>: mov %r8,(%rdi) 0x000000000855e4bd <+637>: retq 0x000000000855e4be <+638>: lea -0x8(%rdi),%rdi 0x000000000855e4c2 <+642>: sub $0x4,%edx 0x000000000855e4c5 <+645>: jb 0x855e4f6 <__gmpn_copyi+694> 0x000000000855e4c7 <+647>: nopw 0x0(%rax,%rax,1) 0x000000000855e4d0 <+656>: mov (%rsi),%r8 0x000000000855e4d3 <+659>: mov 0x8(%rsi),%r9 0x000000000855e4d7 <+663>: lea 0x20(%rdi),%rdi 0x000000000855e4db <+667>: mov 0x10(%rsi),%r10 0x000000000855e4df <+671>: mov 0x18(%rsi),%r11 0x000000000855e4e3 <+675>: lea 0x20(%rsi),%rsi 0x000000000855e4e7 <+679>: mov %r8,-0x18(%rdi) 0x000000000855e4eb <+683>: mov %r9,-0x10(%rdi) 0x000000000855e4ef <+687>: mov %r10,-0x8(%rdi) 0x000000000855e4f3 <+691>: mov %r11,(%rdi) 0x000000000855e4f6 <+694>: test $0x1,%dl 0x000000000855e4f9 <+697>: je 0x855e50a <__gmpn_copyi+714> 0x000000000855e4fb <+699>: mov (%rsi),%r8 0x000000000855e4fe <+702>: mov %r8,0x8(%rdi) 0x000000000855e502 <+706>: lea 0x8(%rdi),%rdi 0x000000000855e506 <+710>: lea 0x8(%rsi),%rsi 0x000000000855e50a <+714>: test $0x2,%dl 0x000000000855e50d <+717>: je 0x855e51e <__gmpn_copyi+734> 0x000000000855e50f <+719>: mov (%rsi),%r8 0x000000000855e512 <+722>: mov 0x8(%rsi),%r9 0x000000000855e516 <+726>: mov %r8,0x8(%rdi) 0x000000000855e51a <+730>: mov %r9,0x10(%rdi) 0x000000000855e51e <+734>: retq End of assembler dump. (gdb)
dmesg
[64949.609311] traps: blender91[24302] trap invalid opcode ip:855e430 sp:7ffc6fcff658 error:0 in blender[400000+b614000]
