Image Sequence Nodes appear to affect each other.
Graphics card: GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: rB3e85bb34d0d7
Worked: ?
Two image sequence nodes, referencing the same image files, in the same material, object or scene appear to affect each other.
  1. Create a new material
  3. Add another Image Sequence Node and select the same image file.
  4. Change one of the node types from Sequence to Single and the other immediately changes.
Two Image Sequence Nodes across and Object or within Scene appear to affect each other differently but I can't tie down the precise behaviour other than to say things stop working as expected. E.g. Setup one Image Sequence Node with a set of frames and then try adding just the first image file using Add | Image | Image As Planes and it will change the playback properties of the previously setup sequence node.
Philipp Oeser (lichtwerk) closed this task as Archived.Oct 23 2020, 9:20 AM
This is expected behavior since those are properties of the Image datablock, not the Texture Node datablock.
If you change something on the same Image datablock, it will change everywhere.
There is nothing stopping you from having a separate Image datablock referencing the same Image on disk though.
Will close, but feel free to comment again if issues persist.
Clicking the '2' to make each one own a separate datablock seems to have solved the problem. Sorry for the false report.
