Particle system Rendered result different from viewport
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 443.18
Broken: version: 2.83.2, branch: master, commit date: 2020-07-09 05:50, hash: rB239fbf7d936f
Worked: n/a
Rendered view of particle system looks much more 'clumped' than viewport.
https://drive.google.com/file/d/10lFJytEtnMDZmhmGmFhGSHmCjBiIfhn8/view?usp=sharing
Viewport:
Rendered:
(notice that the rendered result has clumped particles, whereas the viewport is much more detailed)
Daegon Kim (dk123) updated the task description. (Show Details)
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Oct 26 2020, 8:43 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
This issue seems to be caused by the fact that you have it setup so the final render has 10x as many hairs as the viewport render.
This can be resolved by setting the two values marked with red the same. (Set both to 10).
Does this resolve the issue for you?
Nice, that definitely resolves things!
Alaska (Alaska) closed this task as Resolved.Oct 26 2020, 9:02 PM
Alaska (Alaska) claimed this task.
