Blender often crashes after iMac "wakes up" from "sleeping"
Closed, DuplicatePublic
Operating system: macOS Catalina Version 10.15.7
Graphics card: Radeon Pro Vega 56 8GB
Blender Version Broken: 2.90.1 2020-09-23
Worked: 2.8x
Very often, but not always, Blender 2.90.1 crashes after my iMac wakes up from sleeping. The resulting crash report is as follows:
Leave Blender running. Switch to another task via Command+Tab. Put iMac to sleep or let it do so automatically after preset time. Wake up computer. Switch back to Blender via Command+Tab. Blender will often crash with the following results:
Process: Blender [76200]
Path: /Applications/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.90.1 (2.90.1 2020-09-23)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [76200]
User ID: 501
Date/Time: 2020-10-26 07:38:43.550 -0700
OS Version: Mac OS X 10.15.7 (19H2)
Report Version: 12
Bridge OS Version: 4.6 (17P6610)
Anonymous UUID: 0E7E653C-A0A7-162E-A7EC-7915E610507B
Sleep/Wake UUID: 4577EF06-200D-4946-9E45-F5F706418B51
Time Awake Since Boot: 330000 seconds
Time Since Wake: 80 seconds
System Integrity Protection: enabled
Crashed Thread: 1
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [76200]
Thread 0:: Dispatch queue: com.apple.main-thread
0 org.blenderfoundation.blender 0x000000010cc55cc8 BM_mesh_bm_from_me + 2280
1 org.blenderfoundation.blender 0x000000010c94b2fa BKE_mesh_to_bmesh + 138
2 org.blenderfoundation.blender 0x000000010d13ee1e EDBM_mesh_make + 46
3 org.blenderfoundation.blender 0x000000010d15b5fc ED_object_editmode_enter_ex + 348
4 org.blenderfoundation.blender 0x000000010d15b9b8 editmode_toggle_exec + 360
5 org.blenderfoundation.blender 0x000000010cb82f8b wm_operator_invoke + 411
6 org.blenderfoundation.blender 0x000000010cb7d5ae wm_operator_call_internal + 302
7 org.blenderfoundation.blender 0x000000010cb7dae0 WM_operator_name_call_ptr + 32
8 org.blenderfoundation.blender 0x000000010d161de7 ED_object_mode_set_ex + 327
9 org.blenderfoundation.blender 0x000000010d15ccb0 object_mode_set_exec + 272
10 org.blenderfoundation.blender 0x000000010cb82f8b wm_operator_invoke + 411
11 org.blenderfoundation.blender 0x000000010cb845d9 wm_handler_operator_call + 633
12 org.blenderfoundation.blender 0x000000010cb83c96 wm_handlers_do_intern + 1814
13 org.blenderfoundation.blender 0x000000010cb7f21f wm_handlers_do + 31
14 org.blenderfoundation.blender 0x000000010cb7ec3b wm_event_do_handlers + 2923
15 org.blenderfoundation.blender 0x000000010cb77ec0 WM_main + 32
16 org.blenderfoundation.blender 0x000000010c839812 main + 914
17 libdyld.dylib 0x00007fff6f6fbcc9 start + 1
Thread 1 Crashed:
0 libsystem_kernel.dylib 0x00007fff6f83ce36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff6f6a2aed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff6f6a2fbf _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x0000000112614142 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x0000000112612cae void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff692cfb16 caulk::mach::semaphore::wait() + 16
2 com.apple.audio.caulk 0x00007fff692cf9b2 caulk::semaphore::timed_wait(double) + 106
3 com.apple.audio.caulk 0x00007fff692cf7c4 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff692cf1e4 void* caulk::thread_proxy<std::1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 18:
Thread 19:
0 org.blenderfoundation.blender 0x000000010e2caa8b ccl::bsdf_eval(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderClosure const*, ccl::float3, float*) + 59
1 org.blenderfoundation.blender 0x000000010e2c9976 ccl::direct_emission(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderData*, ccl::LightSample*, ccl::PathState*, ccl::Ray*, ccl::BsdfEval*, bool*, float) + 1094
2 org.blenderfoundation.blender 0x000000010e253d58 ccl::kernel_branched_path_surface_connect_light(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderData*, ccl::PathState*, ccl::float3, float, ccl::PathRadiance*, int) + 4760
3 org.blenderfoundation.blender 0x000000010e23305f ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 75775
4 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
5 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
6 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
7 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
8 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
9 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
10 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
11 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
12 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
13 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
14 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
15 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
16 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 20:
0 org.blenderfoundation.blender 0x000000010f3aed39 embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 425
1 org.blenderfoundation.blender 0x000000010f95c8bf embree::avx2::InstanceIntersector1::intersect(embree::avx2::InstanceIntersector1::Precalculations const&, embree::RayHitK<1>&, embree::IntersectContext*, embree::InstancePrimitive const&) + 207
2 org.blenderfoundation.blender 0x000000010fc2ded8 embree::avx2::BVHNIntersector1<4, 1, false, embree::avx2::ArrayIntersector1<embree::avx2::InstanceIntersector1> >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 1128
3 org.blenderfoundation.blender 0x000000010e9a5687 rtcIntersect1 + 39
4 org.blenderfoundation.blender 0x000000010e2d31e5 ccl::shadow_blocked_opaque(ccl::KernelGlobals*, ccl::ShaderData*, ccl::PathState*, unsigned int, ccl::Ray*, ccl::Intersection*, ccl::float3*) + 501
5 org.blenderfoundation.blender 0x000000010e253eca ccl::kernel_branched_path_surface_connect_light(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderData*, ccl::PathState*, ccl::float3, float, ccl::PathRadiance*, int) + 5130
6 org.blenderfoundation.blender 0x000000010e23305f ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 75775
7 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
8 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
9 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
10 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
11 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
12 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
13 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
14 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
15 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
16 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
17 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
18 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
19 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 21:
0 org.blenderfoundation.blender 0x000000010f3af4ec embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 2396
4 org.blenderfoundation.blender 0x000000010e226230 ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 22992
5 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
6 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
7 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
8 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
9 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
10 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
11 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
12 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
13 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
14 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
15 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
16 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
17 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 22:
0 org.blenderfoundation.blender 0x000000010f3aefdb embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 1099
Thread 23:
0 org.blenderfoundation.blender 0x000000010f3aedfd embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 621
Thread 24:
0 org.blenderfoundation.blender 0x000000010e24e14e ccl::shader_setup_from_ray(ccl::KernelGlobals*, ccl::ShaderData*, ccl::Intersection const*, ccl::Ray const*) + 4446
1 org.blenderfoundation.blender 0x000000010e22d2a4 ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 51780
2 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
3 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
4 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
5 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
6 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
7 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
8 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
9 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
10 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
11 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
12 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
13 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
14 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 25:
0 org.blenderfoundation.blender 0x000000010e26ca17 ccl::svm_eval_nodes(ccl::KernelGlobals*, ccl::ShaderData*, ccl::PathState*, float*, ccl::ShaderType, int) + 439
1 org.blenderfoundation.blender 0x000000010e22d535 ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 52437
Thread 26:
0 org.blenderfoundation.blender 0x000000010f3aefff embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 1135
Thread 27:
0 org.blenderfoundation.blender 0x000000010e21ab7f ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 15
1 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
2 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
3 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
4 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
5 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
6 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
7 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
8 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
9 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
10 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
11 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
12 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 28:
0 org.blenderfoundation.blender 0x000000010e2f1fe8 ccl::kernel_path_surface_bounce(ccl::KernelGlobals*, ccl::ShaderData*, ccl::float3*, ccl::PathState*, ccl::PathRadianceState*, ccl::Ray*) + 44440
1 org.blenderfoundation.blender 0x000000010e233093 ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 75827
Thread 29:
0 org.blenderfoundation.blender 0x000000010f3aef6a embree::avx::BVHNIntersector1<4, 1, true, embree::avx::ArrayIntersector1<embree::avx::TriangleMiIntersector1Pluecker<4, 4, true> > >::intersect(embree::Accel::Intersectors const*, embree::RayHitK<1>&, embree::IntersectContext*) + 986
Thread 30:
0 org.blenderfoundation.blender 0x000000010e2c7a1b ccl::light_sample(ccl::KernelGlobals*, int, float, float, float, ccl::float3, int, ccl::LightSample*) + 8267
1 org.blenderfoundation.blender 0x000000010e253cfc ccl::kernel_branched_path_surface_connect_light(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderData*, ccl::PathState*, ccl::float3, float, ccl::PathRadiance*, int) + 4668
2 org.blenderfoundation.blender 0x000000010e23305f ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 75775
3 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
4 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
5 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
6 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
7 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
8 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
9 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
10 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
11 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
12 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
13 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
14 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
15 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 31:
0 org.blenderfoundation.blender 0x000000010e9adb01 rtcGetGeometry + 17
1 org.blenderfoundation.blender 0x000000010e22aaf7 ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 41623
Thread 32:
0 org.blenderfoundation.blender 0x000000010e22606b ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 22539
1 org.blenderfoundation.blender 0x000000010e21ab96 ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 38
2 org.blenderfoundation.blender 0x000000010dd56dfd ccl::CPUDevice::render(ccl::DeviceTask&, ccl::RenderTile&, ccl::KernelGlobals*) + 477
3 org.blenderfoundation.blender 0x000000010dd562ca ccl::CPUDevice::thread_render(ccl::DeviceTask&) + 858
4 org.blenderfoundation.blender 0x000000010dd55d65 ccl::CPUDevice::task_add(ccl::DeviceTask&)::'lambda'()::operator()() const + 101
5 org.blenderfoundation.blender 0x0000000111b3daa3 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 19
6 org.blenderfoundation.blender 0x000000010cb73df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
7 org.blenderfoundation.blender 0x000000010cb734e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
8 org.blenderfoundation.blender 0x000000010cb64945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
9 org.blenderfoundation.blender 0x000000010cb6dc8b tbb::internal::market::process(rml::job&) + 43
10 org.blenderfoundation.blender 0x000000010cb6ead8 tbb::internal::rml::private_worker::run() + 184
11 org.blenderfoundation.blender 0x000000010cb6ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
12 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
13 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 33:
0 org.blenderfoundation.blender 0x000000010e252d0b ccl::kernel_branched_path_surface_connect_light(ccl::KernelGlobals*, ccl::ShaderData*, ccl::ShaderData*, ccl::PathState*, ccl::float3, float, ccl::PathRadiance*, int) + 587
1 org.blenderfoundation.blender 0x000000010e23305f ccl::kernel_path_trace(ccl::KernelGlobals*, float*, int, int, int, int, int) + 75775
Thread 34:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff6f83cdfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6f83d170 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff3568bef5 CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff3568a9c2
CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff35689e3e CFRunLoopRunSpecific + 462
5 com.apple.AppKit 0x00007fff32a9d954 _NSEventThread + 132
Thread 35:
12 org.blenderfoundation.blender 0x000000010e9de768 tbb::internal::task_group_base::wait() + 24
13 org.blenderfoundation.blender 0x0000000111b3cbe2 ccl::TaskPool::wait_work(ccl::TaskPool::Summary*) + 18
14 org.blenderfoundation.blender 0x000000010e912434 ccl::Session::run_cpu() + 1444
15 org.blenderfoundation.blender 0x000000010e90f74a ccl::Session::run() + 314
16 org.blenderfoundation.blender 0x0000000111b3dde5 ccl::thread::run(void*) + 37
17 libsystem_pthread.dylib 0x00007fff6f900109 _pthread_start + 148
18 libsystem_pthread.dylib 0x00007fff6f8fbb8b thread_start + 15
Thread 36:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff34d6dc75 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff34c69f18 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 2677
4 com.apple.audio.CoreAudio 0x00007fff34d9dc22 HALB_IOThread::Entry(void*) + 72
Thread 37:
0 libsystem_pthread.dylib 0x00007fff6f8fbb68 start_wqthread + 0
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000e  rbx: 0x000060000067c0e0  rcx: 0x0000700004cf5f08  rdx: 0x000000008a871064
rdi: 0x0000000000002903  rsi: 0xffffffffffffffff  rbp: 0x0000700004cf5f20  rsp: 0x0000700004cf5f08
 r8: 0x0000000000000154   r9: 0x00000000000007fb  r10: 0x000000000000009a  r11: 0x0000000000000246
r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x000060000067c0e0  r15: 0xffffffffffffffff
rip: 0x00007fff6f83ce36  rfl: 0x0000000000000246  cr2: 0x00007fc81c403004
Logical CPU: 0
Error Code: 0x01000024
Trap Number: 133
Binary Images:
   0x10c6f8000 -        0x116b9ef5f +org.blenderfoundation.blender (2.90.1 - 2.90.1 2020-09-23) <E1541495-045F-3CD5-9FE1-B0121E08C093> /Applications/Blender.app/Contents/MacOS/Blender
   0x11d6e7000 -        0x11d753ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib
   0x11f408000 -        0x11f40cfff  com.apple.audio.AppleGFXHDAHALPlugIn (100.1.429 - 100.1.429) <1D6B41CB-95E2-34B8-88B8-B1AFE0B6BF61> /System/Library/Extensions/AppleGFXHDA.kext/Contents/PlugIns/AppleGFXHDAHALPlugIn.bundle/Contents/MacOS/AppleGFXHDAHALPlugIn
   0x12153c000 -        0x121695ff7  com.apple.audio.units.Components (1.14 - 1.14) <EC8C35EE-35EB-3AE8-8500-431DC3CF9BD3> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
   0x1216c8000 -        0x121b28fff  com.apple.audio.AudioDSPComponents (1.0 - 1) <F84D78A6-A8F1-3A07-BEB7-306455FDD65A> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
   0x121b95000 -        0x121b98047  libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib
   0x121eb6000 -        0x121fd7ff7  com.apple.AMDRadeonX5000GLDriver (3.10.18 - 3.1.0) <56166645-6F7A-3F21-B0D2-6914C31224F4> /System/Library/Extensions/AMDRadeonX5000GLDriver.bundle/Contents/MacOS/AMDRadeonX5000GLDriver
   0x1236a3000 -        0x1236a4ff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
   0x1237ed000 -        0x1237f3ffb +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
   0x12383c000 -        0x123aec81b +_ssl.cpython-37m-darwin.so (0) <354522B6-4702-3B5C-BA0E-AB7A4E479091> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so
   0x123bb6000 -        0x123bbfffb +_socket.cpython-37m-darwin.so (0) <A4DDE5D0-B31B-3A17-82BE-4532FC9BCDA3> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so
   0x123c12000 -        0x123c17ffb +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
   0x123c24000 -        0x123c27fff +select.cpython-37m-darwin.so (0) <02400D4C-4C27-3FCA-B63B-7F29026E1FB1> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so
   0x123c32000 -        0x123c36ff3 +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
   0x123c44000 -        0x123c4aff7 +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
   0x123cd3000 -        0x123cd3ffb +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
   0x123cdb000 -        0x123ef411b +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
   0x123f8d000 -        0x123f92ff3 +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
   0x123f9c000 -        0x123facff3 +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
   0x124037000 -        0x124038ffb +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
   0x124040000 -        0x12404eff3 +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
   0x1240de000 -        0x1240f0fff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
   0x12413b000 -        0x124151ffb +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
   0x12415c000 -        0x12418aff7 +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
   0x124199000 -        0x124199ffb +grp.cpython-37m-darwin.so (0) <DEEAC15B-D065-3D28-9F79-32426A8C67B7> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
   0x1241a1000 -        0x1241a1ff3 +_scproxy.cpython-37m-darwin.so (0) <9673CE7F-B1B9-3C49-96D2-D03BFEB345AE> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so
   0x1241e9000 -        0x1241eafff +_posixsubprocess.cpython-37m-darwin.so (0) <3DC85D51-0860-37D2-9F6A-0AD91A2595CE> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so
   0x1248f2000 -        0x1249f0ffb +unicodedata.cpython-37m-darwin.so (0) <E65B37DA-33D3-364E-A794-CFAAC682C392> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/unicodedata.cpython-37m-darwin.so
   0x124cbc000 -        0x124cbdfff +_queue.cpython-37m-darwin.so (0) <2E95FB49-FE7E-3065-A632-9E7EBE8D25EA> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so
   0x12531b000 -        0x1253acf47  dyld (750.6) <1D318D60-C9B0-3511-BE9C-82AFD2EF930D> /usr/lib/dyld
   0x12ba2d000 -        0x12ba33fff +array.cpython-37m-darwin.so (0) <13F2F1B6-3644-36EB-A680-74EBC5DCE26F> /Applications/Blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so
   0x12be23000 -        0x12be25ff3  com.apple.CloudDocsFileProvider (1.0 - 698.17) <C03D572A-4C6B-3DFA-8AA9-064B4808BA72> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
   0x12be2e000 -        0x12be31fff  com.apple.FileProviderOverride (304.1 - 304.1) <FF452DA5-75BC-3EF3-B372-F4FD9B7D57B9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
   0x12be3a000 -        0x12be51ffb  com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.6.2) <E457A2FD-E5D8-3B85-B5FA-BF01EE9D6C09> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff286fa000 -     0x7fff28947ff8  com.apple.RawCamera.bundle (9.02.0 - 1350.29) <59F81722-039E-33F5-A20E-936E997575A3> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff28ab0000 -     0x7fff28ae6fff  ATIRadeonX5000SCLib.dylib (3.10.18) <BC9FA5E9-F379-3402-A61F-28AAED229552> /System/Library/Extensions/AMDRadeonX5000GLDriver.bundle/Contents/MacOS/ATIRadeonX5000SCLib.dylib
0x7fff28ae7000 -     0x7fff28d67ff8  com.apple.AMDRadeonX5000MTLDriver (3.10.18 - 3.1.0) <41D34EDA-5541-3FDA-9271-B36AAF3C5C05> /System/Library/Extensions/AMDRadeonX5000MTLDriver.bundle/Contents/MacOS/AMDRadeonX5000MTLDriver
0x7fff29f89000 -     0x7fff2a906fff  libSC.dylib (3.10.18) <3C722BC2-E988-3A2F-9C25-38D091AAE559> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff3128f000 -     0x7fff3128ffff  com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff31290000 -     0x7fff312a6fef  libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff312a7000 -     0x7fff318fdfff  com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff318fe000 -     0x7fff31b65ff7  libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff31b66000 -     0x7fff32039fef  libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff3203a000 -     0x7fff323d5fff  libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff323d6000 -     0x7fff323ebfec  libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff323ec000 -     0x7fff323f1ff3  libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff323f2000 -     0x7fff32462fff  libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff32463000 -     0x7fff32475fef  libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff32476000 -     0x7fff3264dfd7  libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff3264e000 -     0x7fff32710fef  libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff32711000 -     0x7fff32711fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff32712000 -     0x7fff32771ff0  com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff328bb000 -     0x7fff3367bff2  com.apple.AppKit (6.9 - 1894.60.100) <A64D10A6-FE17-39CE-9392-6615BE54E10E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff336cb000 -     0x7fff336cbfff  com.apple.ApplicationServices (48 - 50) <C23D2740-FAF6-3BD6-9E48-56F54D752864> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff336cc000 -     0x7fff33737fff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff337d0000 -     0x7fff3380eff0  libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff33869000 -     0x7fff33898fff  com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff33899000 -     0x7fff3389dffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff33937000 -     0x7fff3398effa  com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3398f000 -     0x7fff3399dfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3399e000 -     0x7fff339e3ffa  com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff339e4000 -     0x7fff339eeff7  com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff339ef000 -     0x7fff339fcffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff339fd000 -     0x7fff33adeffa  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <8CFA0620-5E43-3C4D-A75B-981C0961C2DE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff33ae0000 -     0x7fff33ae0fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <C8F9CC56-F7CF-3E77-B6FC-BD8E1D19FA92> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff33e77000 -     0x7fff34206ffa  com.apple.CFNetwork (1128.0.1 - 1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff34282000 -     0x7fff34282fff  com.apple.Carbon (160 - 162) <97E334B3-7FAE-3239-9E89-5A546BC26ADE> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff34283000 -     0x7fff34286ff3  com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff34287000 -     0x7fff3457bff3  com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3457c000 -     0x7fff3457fff3  com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff34580000 -     0x7fff34585ff7  com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff34586000 -     0x7fff34586fff  com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff34587000 -     0x7fff345a1ffa  com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff345c2000 -     0x7fff345c2fff  com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff345c3000 -     0x7fff345c5ff7  com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff345c6000 -     0x7fff345ccfff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff34766000 -     0x7fff34766fff  com.apple.Cocoa (6.11 - 23) <2192EE61-8CA8-3639-B7D3-0D68F200C9EF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff34774000 -     0x7fff3486afff  com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff34b55000 -     0x7fff3505effb  com.apple.audio.CoreAudio (5.0 - 5.0) <9DA02E7A-56A0-3FFF-94C2-1795BA761F07> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff350b1000 -     0x7fff350e9fff  com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff350ea000 -     0x7fff354d4fe8  com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff354d5000 -     0x7fff35607ff6  com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff35608000 -     0x7fff35a87feb  com.apple.CoreFoundation (6.9 - 1677.104) <C0D70026-EDBE-3CBD-B317-367CF4F1C92F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff35a89000 -     0x7fff360feff8  com.apple.CoreGraphics (2.0 - 1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3610c000 -     0x7fff36467ff0  com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff36828000 -     0x7fff36903ffc  com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff369f0000 -     0x7fff369f0fff  com.apple.CoreServices (1069.24 - 1069.24) <AA140158-E909-34C2-B2F5-20EBC93E0056> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff369f1000 -     0x7fff36a76fff  com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff36a77000 -     0x7fff36d58ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff36d59000 -     0x7fff36da6ffd  com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff36da7000 -     0x7fff36dafff7  com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff36db0000 -     0x7fff36feaff6  com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff36feb000 -     0x7fff37083ff1  com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff37084000 -     0x7fff370b1fff  com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff370b2000 -     0x7fff37119fff  com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3711a000 -     0x7fff3713eff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff37463000 -     0x7fff3761affc  com.apple.CoreText (643.1.5.1 - 643.1.5.1) <A88F052A-C840-3E6C-9BF8-FFFED34C0667> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3761b000 -     0x7fff3765fffb  com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff37660000 -     0x7fff376edffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff378a9000 -     0x7fff378b4ff7  com.apple.DirectoryService.Framework (10.15 - 220.40.1) <6EACB7D0-A013-3D2B-93D2-5113F7C2559D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff378b5000 -     0x7fff3795fff0  com.apple.DiscRecording (9.0.3 - 9030.4.5) <BCF3AFB0-6E1A-3F28-A575-1FD2D74E7C19> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff37984000 -     0x7fff3798afff  com.apple.DiskArbitration (2.7 - 2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff37b7f000 -     0x7fff37cadff6  com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff37cc2000 -     0x7fff37cc4ff3  com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff37cc5000 -     0x7fff3808afff  com.apple.Foundation (6.9 - 1677.104) <7C69F845-F651-3193-8262-5938010EC67D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff380f7000 -     0x7fff38147ff7  com.apple.GSS (4.0 - 2.0) <2F3A67E6-D42A-3CF0-9041-A42C22D46F95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff38284000 -     0x7fff38398ff3  com.apple.Bluetooth (7.0.6 - 7.0.6f7) <CF9CEFBA-97AC-3474-93AF-863C2C74C645> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff383fe000 -     0x7fff384a2ff3  com.apple.framework.IOKit (2.0.2 - 1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff384a4000 -     0x7fff384b5ffb  com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff38534000 -     0x7fff38690ffe  com.apple.ImageIO.framework (3.3.0 - 1976.11.1) <5DBAD721-B70E-396C-922C-A2742E6815D6> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff38691000 -     0x7fff38694fff  libGIF.dylib (1976.11.1) <1A04BEC5-95CF-3EA4-8FA6-FE19679331F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff38695000 -     0x7fff3874efe7  libJP2.dylib (1976.11.1) <686B045D-5627-3DEE-B018-72068B7136D4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3874f000 -     0x7fff38772fe3  libJPEG.dylib (1976.11.1) <13EAEDD3-D4CF-3B2C-B7A4-FB000A71D982> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff389f1000 -     0x7fff38a0bfef  libPng.dylib (1976.11.1) <031068A2-29E2-3BE0-93CC-76D154976A51> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff38a0c000 -     0x7fff38a0dfff  libRadiance.dylib (1976.11.1) <6B5A0402-F511-39ED-933A-C361005107B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff38a0e000 -     0x7fff38a54fff  libTIFF.dylib (1976.11.1) <1F089EF9-3DCE-3B49-9B2B-28B9AC3252D0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff39fb6000 -     0x7fff39fc8ff3  com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff39fc9000 -     0x7fff39fc9fff  libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff39fca000 -     0x7fff3a000ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <47D63DCF-2BDB-3983-B2A2-E9C47AA2401D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff3a35b000 -     0x7fff3a365ffb  com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3a431000 -     0x7fff3ab7eff2  com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3ab80000 -     0x7fff3ac4afff  com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3ac67000 -     0x7fff3aca4ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3aca5000 -     0x7fff3ad2ffe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3ad30000 -     0x7fff3ad55ff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3ad56000 -     0x7fff3ad6bffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3ad6c000 -     0x7fff3aecaffc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3aecb000 -     0x7fff3af1aff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3af1b000 -     0x7fff3af1cff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3bfab000 -     0x7fff3bfb7ffe  com.apple.NetFS (6.0 - 4.0) <4415F027-D36D-3B9C-96BA-AD22B44A4722> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3bfb8000 -     0x7fff3c10fff3  com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3c3fb000 -     0x7fff3c41dfff  com.apple.audio.OpenAL (1.8 - 1.8) <6D66C5D7-8410-35B7-B06E-3BE56E0A708E> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff3eb38000 -     0x7fff3eb40ff7  libcldcpuengine.dylib (2.14) <D20EF7DF-8508-3707-A9B3-B7D8190971F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff3eb41000 -     0x7fff3eb99fff  com.apple.opencl (3.5 - 3.5) <293FE223-9186-320B-81A4-EC8104C38357> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff3eb9a000 -     0x7fff3ebb6fff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff3ebb7000 -     0x7fff3ebc2ffd  com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff3f528000 -     0x7fff3f52afff  libCVMSPluginSupport.dylib (17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff3f52b000 -     0x7fff3f530fff  libCoreFSCache.dylib (176.15) <E9A20E72-B17F-33D6-8894-41934A10B822> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff3f531000 -     0x7fff3f535fff  libCoreVMClient.dylib (176.15) <018A48BA-1326-3847-8FB5-A7C99322EB87> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff3f536000 -     0x7fff3f53eff7  libGFXShared.dylib (17.10.22) <AB47B927-65E3-3924-88BE-0A5BE7906785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff3f53f000 -     0x7fff3f549fff  libGL.dylib (17.10.22) <FB5E6A75-398E-38EF-8CB2-59F5BFE3034C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff3f54a000 -     0x7fff3f57eff7  libGLImage.dylib (17.10.22) <9A3FE633-61B8-3CC7-8183-62960109401A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff3f57f000 -     0x7fff3f713ff7  libGLProgrammability.dylib (17.10.22) <85815C4E-3376-33DF-9FBB-6512142AB61B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff3f714000 -     0x7fff3f750fff  libGLU.dylib (17.10.22) <D8B4D804-7323-30BC-871C-B7236FFC2FE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff4018c000 -     0x7fff4019bff7  com.apple.opengl (17.10.22 - 17.10.22) <D3C57A32-6BD0-3228-B1C4-0F42A6128A6C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff4019c000 -     0x7fff40315fff  GLEngine (17.10.22) <B902FF53-A960-3137-99BD-1F9774F9586C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff40316000 -     0x7fff4033efff  GLRendererFloat (17.10.22) <F3D43FBE-7871-3260-B7C9-9BE260F081CD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff41159000 -     0x7fff413dcffb  com.apple.QuartzCore (1.11 - 841.4) <FE927B0E-BD49-32CC-8A55-90F553C86C15> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff41f5f000 -     0x7fff422a8ff1  com.apple.security (7.0 - 59306.140.5) <B6F8368F-2395-379B-B768-71C53BB1B903> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff422a9000 -     0x7fff42331ffb  com.apple.securityfoundation (6.0 - 55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff42360000 -     0x7fff42364ff8  com.apple.xpc.ServiceManagement (1.0 - 1) <2C62956C-F2D4-3EB0-86C7-EAA06331621A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff43010000 -     0x7fff4308aff7  com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4330a000 -     0x7fff4368dff4  com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff46ffa000 -     0x7fff470bffe7  com.apple.APFS (1412.141.1 - 1412.141.1) <C86A3423-E61C-335A-9D17-0B3CE5BB6467> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff481d4000 -     0x7fff481d5ff1  com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4876f000 -     0x7fff4878cff4  com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff487e1000 -     0x7fff487efff7  com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff48c6b000 -     0x7fff48c8fffb  com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff48f4d000 -     0x7fff48f5cfd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4905b000 -     0x7fff49066ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff490a8000 -     0x7fff490f0ff7  com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff494da000 -     0x7fff494deff7  com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff494df000 -     0x7fff49501fff  com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff495c0000 -     0x7fff495c3fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff495c4000 -     0x7fff49614ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4965d000 -     0x7fff4966cff9  com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff49baf000 -     0x7fff49faaff8  com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4a0e9000 -     0x7fff4a13aff9  com.apple.audio.AudioSession (1.0 - 17) <AB93CA04-083D-3D80-9C33-28B30BA7A525> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff4a13b000 -     0x7fff4a168ff7  libSessionUtility.dylib (17) <54A1C204-FCBA-3106-A896-28F22ECF144E> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff4a200000 -     0x7fff4a440fe0  com.apple.audio.AudioToolboxCore (1.0 - 1104.93) <5B539F50-93E8-3F73-9E4C-678C85D0488F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4a444000 -     0x7fff4a560fff  com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4a71d000 -     0x7fff4a726ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4a727000 -     0x7fff4a7c8ff5  com.apple.backup.framework (1.11.6 - 1298.6.2) <C4BC12A3-4D01-377F-A1DB-7E1490831CF2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4a7c9000 -     0x7fff4a855ff6  com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4a957000 -     0x7fff4a993ff7  com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4b513000 -     0x7fff4b562fff  com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff4b6bd000 -     0x7fff4b748ff8  com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff4c40e000 -     0x7fff4c41effb  com.apple.CommonAuth (4.0 - 2.0) <CF67FF34-4238-3ECA-B4A4-EA04F18A0D36> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff4c432000 -     0x7fff4c449fff  com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff4cb50000 -     0x7fff4cf25fc8  com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff4cf26000 -     0x7fff4cf53ff7  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4cf76000 -     0x7fff4cf97ff4  com.apple.analyticsd (1.0 - 1) <95A87174-A616-3F80-B17A-1FA7E3DB7C09> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff4d2a2000 -     0x7fff4d2adff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff4d52e000 -     0x7fff4d53eff3  com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff4db7e000 -     0x7fff4dbe8ff0  com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff4e016000 -     0x7fff4e01eff8  com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff4ea0b000 -     0x7fff4ea2efff  com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff4ea2f000 -     0x7fff4ea62fff  com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff4ea63000 -     0x7fff4ea91ffd  com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff4efb6000 -     0x7fff4f04cff7  com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff4f0e4000 -     0x7fff4f210ff6  com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff4f211000 -     0x7fff4f3caffa  com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff4f504000 -     0x7fff4f517ff1  com.apple.CrashReporterSupport (10.13 - 15016) <ADF138F0-0274-3BA2-A1D2-48B91577FE53> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff4f5d0000 -     0x7fff4f5e2ff8  com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4f5e3000 -     0x7fff4f5e8fff  com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff4f672000 -     0x7fff4f6ecff0  com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff4f738000 -     0x7fff4f775ff8  com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff4f776000 -     0x7fff4f8feff6  com.apple.desktopservices (1.14.5 - 1281.5.3) <BFA7D5B5-20EE-38E3-B8A7-96CE1F9BB48A> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff4fbad000 -     0x7fff4fc75ffe  com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <47CD30B9-887B-3660-B0EA-E8D8258263BC> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff4fc76000 -     0x7fff4fd49ff1  com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff4fe2c000 -     0x7fff4fe30ff9  com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff512bf000 -     0x7fff516daff1  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff51d32000 -     0x7fff51d32fff  com.apple.FinderSyncPriv (1.0.6 - 1298.6.2) <C16B806A-C162-3C1A-AEB9-ECD0430A4B0F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff51d79000 -     0x7fff51eb0ff4  libFontParser.dylib (277.2.6.1) <9E9E2EAA-3273-360E-A01B-EB986ECB7BCF> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff51eb1000 -     0x7fff51ee5fff  libTrueTypeScaler.dylib (277.2.6.1) <F8A27F0F-44B3-3A1E-8B75-2DFD4A90E1D4> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff51f4a000 -     0x7fff51f5aff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <1605B441-08E0-332D-B7D8-0E13F37B54E7> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff5543b000 -     0x7fff5543cfff  libmetal_timestamp.dylib (902.14.11) <C29C7125-A894-3718-8E1D-249C53BCC0B8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff56aea000 -     0x7fff56af5ff7  libGPUSupportMercury.dylib (17.10.22) <398D9635-B9CB-3BBB-A1E4-D1D1270D3F99> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff56af6000 -     0x7fff56afcfff  com.apple.GPUWrangler (5.2.6 - 5.2.6) <487F2E7A-A5FF-3C36-A8E9-B85D98618116> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff56e1b000 -     0x7fff56e41ff1  com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff57f6f000 -     0x7fff57f7dffb  com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5811c000 -     0x7fff581daff4  com.apple.Heimdal (4.0 - 2.0) <B86FE9DB-71BB-3B6E-A4AE-2B0B44570A7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff58bd7000 -     0x7fff58c06ff8  com.apple.HelpData (2.3 - 199) <A62E7DB6-8960-3470-8281-293711C166D8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5a356000 -     0x7fff5a35fffe  com.apple.IOAccelMemoryInfo (1.0 - 1) <50DDA9C2-BDDF-33D4-9BA9-A161E99F1EAD> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5a360000 -     0x7fff5a368ff5  com.apple.IOAccelerator (438.7.3 - 438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5a375000 -     0x7fff5a38cfff  com.apple.IOPresentment (47.10 - 37) <32F1B3BC-4644-3982-AAB2-8EB5D5FF0161> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5a714000 -     0x7fff5a75fff1  com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5a91d000 -     0x7fff5a924ff9  com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5abb1000 -     0x7fff5abd0ffd  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <6F655A32-F963-3A7E-B475-E460F4AC7D99> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5ad05000 -     0x7fff5add3ffd  com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5add4000 -     0x7fff5ae1cfff  com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5ae23000 -     0x7fff5ae28ff3  com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5aecc000 -     0x7fff5aed1ff7  com.apple.LoginUICore (4.0 - 4.0) <6FE011DE-A794-3D82-9E35-7FE1D62DEE7E> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff5b6c1000 -     0x7fff5b6c4fff  com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5b92d000 -     0x7fff5b9b7ff8  com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5b9b8000 -     0x7fff5b9ebfff  com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5c191000 -     0x7fff5c1ddfff  com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5c1de000 -     0x7fff5c2afffa  com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5c30d000 -     0x7fff5c326ff4  com.apple.MobileAssets (1.0 - 619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5c4e3000 -     0x7fff5c501fff  com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5c764000 -     0x7fff5c794ff7  com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5cc94000 -     0x7fff5cc9efff  com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5d6b4000 -     0x7fff5d6ffffb  com.apple.OTSVG (1.0 - 643.1.5.1) <001E5E8C-1DC0-3A6E-BDE4-1B7887E47F76> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5e91c000 -     0x7fff5e927ff2  com.apple.PerformanceAnalysis (1.243.2 - 243.2) <B47C00E5-ECC2-313D-93D4-DBDF562C48EF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5e928000 -     0x7fff5e950ffb  com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff603cb000 -     0x7fff603fbff7  com.apple.pluginkit.framework (1.0 - 1) <EFBD7FE7-02CC-3E30-999D-B036F252F805> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff60426000 -     0x7fff60439ffc  com.apple.PowerLog (1.0 - 1) <FAD6E2DC-8C9D-38A0-9CB1-75F48473A3E2> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff612b5000 -     0x7fff6130fff6  com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff61310000 -     0x7fff61329ffb  com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff61789000 -     0x7fff617b2ff1  com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff61917000 -     0x7fff61952ff0  com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff63233000 -     0x7fff63236ff5  com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff633a9000 -     0x7fff634d0fff  com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff63529000 -     0x7fff63547ff2  com.apple.shortcut (2.16 - 106) <9F669D19-13AD-3961-B247-ED728B7BFA19> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff63548000 -     0x7fff63568ff5  com.apple.sidecar-core (1.0 - 209.40.4) <469E5222-A5C7-3B09-B617-EDB6E9E46B93> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff63569000 -     0x7fff6357bff0  com.apple.sidecar-ui (1.0 - 209.40.4) <5CA517E3-4B92-30B1-96EF-77A7A2FBBEE4> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff648e5000 -     0x7fff64bdbff7  com.apple.SkyLight (1.600.0 - 451.4) <A24929C3-95E6-35A7-9654-46FF3F4D1E80> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff65428000 -     0x7fff65436ffb  com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff654f8000 -     0x7fff65784ffe  com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff65b12000 -     0x7fff65b53ff9  com.apple.StreamingZip (1.0 - 1) <72CA32F8-4C96-3264-A655-623329EB3A28> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff65c6a000 -     0x7fff65c73ff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <14929A5D-C369-3B46-844B-CD29A3D1A015> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff65ce4000 -     0x7fff65d0effe  com.apple.framework.SystemAdministration (1.0 - 1.0) <087553CB-5BF3-3D3D-B620-CA36AD334D92> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff65f2a000 -     0x7fff65f3aff3  com.apple.TCC (1.0 - 1) <017AB27D-6821-303A-8FD2-6DAC795CC7AA> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6645f000 -     0x7fff66525ff0  com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff666bc000 -     0x7fff666bdfff  com.apple.TrustEvaluationAgent (2.0 - 33) <10E56F70-E234-31E0-9286-96D93A8ED17E> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff666f5000 -     0x7fff6694dff0  com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff675c3000 -     0x7fff675e3ffc  com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6838f000 -     0x7fff68479ff8  com.apple.ViewBridge (464.1 - 464.1) <25CE39DF-2052-3873-9113-DB52B385C4BB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff6861f000 -     0x7fff68620fff  com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff69250000 -     0x7fff69253ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff692cd000 -     0x7fff692dbff5  com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6961d000 -     0x7fff6961fff3  com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff69620000 -     0x7fff69633ffd  com.apple.login (3.0 - 3.0) <C68367BA-2225-31DD-B2D8-16AC0A44421F> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff6c103000 -     0x7fff6c136ffa  libAudioToolboxUtility.dylib (1104.93) <A7249C4C-6C0A-3C14-BA27-DC966F6CC6A0> /usr/lib/libAudioToolboxUtility.dylib
0x7fff6c13d000 -     0x7fff6c171fff  libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff6c174000 -     0x7fff6c17efff  libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff6c17f000 -     0x7fff6c207fff  libCoreStorage.dylib (551) <A457B0FE-D77F-30AA-99A4-70F6A98DFE59> /usr/lib/libCoreStorage.dylib
0x7fff6c20a000 -     0x7fff6c20cff7  libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6c252000 -     0x7fff6c409ffb  libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff6c430000 -     0x7fff6c436ff3  libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff6c518000 -     0x7fff6c51ffff  libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff6c54e000 -     0x7fff6c56eff7  libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff6c6e0000 -     0x7fff6c6e1fff  libSystem.B.dylib (1281.100.1) <0A6C8BA1-30FD-3D10-83FD-FF29E221AFFE> /usr/lib/libSystem.B.dylib
0x7fff6c76e000 -     0x7fff6c76ffff  libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff6c787000 -     0x7fff6c79dfff  libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff6c7d2000 -     0x7fff6c844ff7  libarchive.2.dylib (72.140.1) <AC311FBA-F2DD-3595-AA76-769F912942B8> /usr/lib/libarchive.2.dylib
0x7fff6c845000 -     0x7fff6c8defe5  libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff6c8e2000 -     0x7fff6c8e2ff3  libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
0x7fff6c9a8000 -     0x7fff6c9b8ffb  libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff6c9b9000 -     0x7fff6c9c5fff  libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff6c9c6000 -     0x7fff6ca18fff  libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff6ca19000 -     0x7fff6ca2effb  libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
0x7fff6ca2f000 -     0x7fff6ca2ffff  libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff6ca30000 -     0x7fff6ca41fff  libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
0x7fff6ca42000 -     0x7fff6ca59fd7  libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff6cd33000 -     0x7fff6cd49ff7  libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff6cd4a000 -     0x7fff6cd4bfff  libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff6d1ee000 -     0x7fff6d2f2fef  libcrypto.44.dylib (47.140.1) <CB6B188A-1ADC-3C5D-AFFC-2ACD86E235EE> /usr/lib/libcrypto.44.dylib
0x7fff6d2f5000 -     0x7fff6d300fff  libcsfde.dylib (551) <CEE22AEF-4E77-36B1-B007-00303819965F> /usr/lib/libcsfde.dylib
0x7fff6d308000 -     0x7fff6d367ff7  libcups.2.dylib (483.6) <C88D78FE-D238-376C-B16A-39270E39A79D> /usr/lib/libcups.2.dylib
0x7fff6d369000 -     0x7fff6d3ceff7  libcurl.4.dylib (118.120.2) <28809E22-6EF2-3AC7-9501-D77FB6FC5FBD> /usr/lib/libcurl.4.dylib
0x7fff6d471000 -     0x7fff6d471fff  libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff6d472000 -     0x7fff6d48afff  libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
0x7fff6d498000 -     0x7fff6d49afff  libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff6d4a9000 -     0x7fff6d4aefff  libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
0x7fff6d4af000 -     0x7fff6d4b8ff7  libheimdal-asn1.dylib (564.140.1) <0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib
0x7fff6d4b9000 -     0x7fff6d5a9fff  libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff6d5aa000 -     0x7fff6d801fff  libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff6d81b000 -     0x7fff6d81cfff  liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff6d81d000 -     0x7fff6d835ff3  liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
0x7fff6d84d000 -     0x7fff6d8f4ff7  libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff6d8f5000 -     0x7fff6db57ff1  libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
0x7fff6dec4000 -     0x7fff6def3fff  libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff6e023000 -     0x7fff6e49fff5  libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
0x7fff6e540000 -     0x7fff6e573fde  libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff6e574000 -     0x7fff6e575ff7  libodfde.dylib (26) <33F49412-5106-35B8-AA60-5A497C3967E6> /usr/lib/libodfde.dylib
0x7fff6e586000 -     0x7fff6e58afff  libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff6e58d000 -     0x7fff6e5c3ff7  libpcap.A.dylib (89.120.1) <A76EC076-A8EA-354C-B95F-7AB1EAFBCC65> /usr/lib/libpcap.A.dylib
0x7fff6e647000 -     0x7fff6e65ffff  libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
0x7fff6e661000 -     0x7fff6e6a5ff7  libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
0x7fff6e6a6000 -     0x7fff6e6b8ff7  libsasl2.2.dylib (213.120.1) <E7573AC1-83FD-305A-8FB8-03145BDA286B> /usr/lib/libsasl2.2.dylib
0x7fff6e6b9000 -     0x7fff6e6baff7  libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
0x7fff6e6bb000 -     0x7fff6e8a5ff7  libsqlite3.dylib (308.5) <35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib
0x7fff6e999000 -     0x7fff6e9c6ffb  libssl.46.dylib (47.140.1) <06932872-13DA-33E3-8C28-7B49FC582039> /usr/lib/libssl.46.dylib
0x7fff6ea9b000 -     0x7fff6eaf5ff8  libusrtcp.dylib (1880.120.4) <05346A91-737C-33D0-B21B-F040950DFB28> /usr/lib/libusrtcp.dylib
0x7fff6eaf6000 -     0x7fff6eaf9ffb  libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
0x7fff6eafa000 -     0x7fff6eb07ff7  libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
0x7fff6eb0d000 -     0x7fff6ebeffff  libxml2.2.dylib (33.5) <A579D158-2E09-316C-872E-DD9D93401B2F> /usr/lib/libxml2.2.dylib
0x7fff6ebf3000 -     0x7fff6ec1bfff  libxslt.1.dylib (16.9) <34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib
0x7fff6ec1c000 -     0x7fff6ec2eff3  libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff6f4dd000 -     0x7fff6f4e2ff3  libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
0x7fff6f4e3000 -     0x7fff6f4eefff  libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
0x7fff6f4ef000 -     0x7fff6f4f6fff  libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff6f4f7000 -     0x7fff6f500ff7  libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff6f501000 -     0x7fff6f593fdb  libcorecrypto.dylib (866.140.1) <60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib
0x7fff6f6a0000 -     0x7fff6f6e0ff0  libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
0x7fff6f6e1000 -     0x7fff6f717fff  libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff6f718000 -     0x7fff6f718ffb  libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
0x7fff6f719000 -     0x7fff6f725ff3  libkxld.dylib (6153.141.2) <EE8ECB4B-2EDB-3440-BBC1-6BDDDF5F1BCE> /usr/lib/system/libkxld.dylib
0x7fff6f726000 -     0x7fff6f726ff7  liblaunch.dylib (1738.140.1) <AFBCBDD3-0B55-3ECD-8E04-A73A3A57356B> /usr/lib/system/liblaunch.dylib
0x7fff6f727000 -     0x7fff6f72cff7  libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
0x7fff6f72d000 -     0x7fff6f72fff3  libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
0x7fff6f730000 -     0x7fff6f731ff7  libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff6f732000 -     0x7fff6f749ff3  libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff6f74a000 -     0x7fff6f74aff7  libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff6f74b000 -     0x7fff6f7d2fff  libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
0x7fff6f7d3000 -     0x7fff6f7d6ffb  libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
0x7fff6f7d7000 -     0x7fff6f7dafff  libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib
0x7fff6f7db000 -     0x7fff6f7e3fff  libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff6f7e4000 -     0x7fff6f7ebfff  libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
0x7fff6f7ec000 -     0x7fff6f7edffb  libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
0x7fff6f7ee000 -     0x7fff6f83bff7  libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff6f83c000 -     0x7fff6f868ff7  libsystem_kernel.dylib (6153.141.2) <A576A1CF-7726-3146-B04B-A26E1CDB9757> /usr/lib/system/libsystem_kernel.dylib
0x7fff6f869000 -     0x7fff6f8b0fff  libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff6f8b1000 -     0x7fff6f8d8fff  libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff6f8d9000 -     0x7fff6f8e6ffb  libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
0x7fff6f8e7000 -     0x7fff6f8f0ff7  libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
0x7fff6f8f1000 -     0x7fff6f8f9fef  libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
0x7fff6f8fa000 -     0x7fff6f904fff  libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff6f905000 -     0x7fff6f909ff3  libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff6f90a000 -     0x7fff6f90cfff  libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
0x7fff6f90d000 -     0x7fff6f914ffb  libsystem_symptoms.dylib (1238.120.1) <5820A2AF-CE72-3AB3-ABCC-273A3419FB55> /usr/lib/system/libsystem_symptoms.dylib
0x7fff6f915000 -     0x7fff6f92bff2  libsystem_trace.dylib (1147.120) <04B47629-847B-3D74-8ABE-C05EF9DEEFE4> /usr/lib/system/libsystem_trace.dylib
0x7fff6f92d000 -     0x7fff6f932ff7  libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff6f933000 -     0x7fff6f968ffe  libxpc.dylib (1738.140.1) <3E243A41-030F-38E3-9FD2-7B38C66C35B1> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 78
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 236460
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=824.6M resident=0K(0%) swapped_out_or_unallocated=824.6M(100%)
Writable regions: Total=7.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=7.1G(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 896K 7
Activity Tracing 256K 1
CG backing stores 2096K 4
CG image 696K 18
CoreAnimation 180K 15
CoreGraphics 8K 1
CoreImage 48K 6
CoreServices 108K 1
CoreUI image data 1212K 12
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 5.1G 656
MALLOC guard page 48K 10
MALLOC_LARGE (reserved) 174.5M 1 reserved VM address space (unallocated)
MALLOC_MEDIUM (reserved) 1.1G 13 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 172K 43
Stack 76.3M 44
VM_ALLOCATE 202.2M 4924
VM_ALLOCATE (reserved) 128.0M 2 reserved VM address space (unallocated)
DATA 100.6M 363
DATA_CONST 420K 8
FONT_DATA 4K 1
GLSLBUILTINS 5176K 1
LINKEDIT 437.1M 39
OBJC_RO 32.3M 1
OBJC_RW 1908K 2
TEXT 387.6M 355
__UNICODE 564K 1
mapped file 75.7M 26
shared memory 640K 15
TOTAL 8.2G 6576
TOTAL, minus reserved VM space 6.4G 6576
Model: iMacPro1,1, BootROM 1037.147.4.0.0 (iBridge: 17.16.16610.0.0,0), 8 processors, 8-Core Intel Xeon W, 3.2 GHz, 32 GB, SMC
Graphics: kHW_AMDRadeonProVega56Item, Radeon Pro Vega 56, spdisplays_pcie_device, 8 GB
Memory Module: NODE 1/CPU1_DIMM_A0, 8 GB, DDR4, 2666 MHz, Hynix, HMA81GR7AFR8N-VK
Memory Module: NODE 1/CPU1_DIMM_B0, 8 GB, DDR4, 2666 MHz, Hynix, HMA81GR7AFR8N-VK
Memory Module: NODE 1/CPU1_DIMM_C0, 8 GB, DDR4, 2666 MHz, Hynix, HMA81GR7AFR8N-VK
Memory Module: NODE 1/CPU1_DIMM_D0, 8 GB, DDR4, 2666 MHz, Hynix, HMA81GR7AFR8N-VK
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Feb 28 2020 15:24:56 version 9.30.357.35.32.5.47 FWID 01-9ce4adf3
Bluetooth: Version 7.0.6f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci1b4b,9182, sppci_ahci, Thunderbolt@183,0,0
PCI Card: pci11c1,5901, sppci_ieee1394openhci, Thunderbolt@187,0,0
Serial ATA Device: HGST HDS724040ALE640, 4 TB
USB Device: USB 3.0 Bus
USB Device: Apple T2 Bus
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: iMac Pro, Apple Inc., 41.4
Thunderbolt Device: G-RAID with Thunderbolt, G-Technology, 1, 26.3
