Blender crash when using collection user_id remapping (python)
Closed, ResolvedPublicBUG
Operating system: Linux-5.8.16-2-MANJARO-x86_64-with-arch-Manjaro-Linux 64 Bits
Graphics card: GeForce GTX 1660 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.100
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-10-23 17:33, hash: `rB70cc0d7121aa;
Wont work in 2.83 and 2.90 too
Worked: 2.82a
Caused by rB37e08e526c6f: Depsgraph: Add IDProperties handling.
Python script from attached blend file crashes Blender with error:
  • /snap/blender/47/./blender-wrapper: linie 19: 37036 Naruszenie ochrony pamięci (somthing about memory override error) (zrzut pamięci) $SNAP/blender "$@"
What the script does is:
  • add and assign custom PropertyGroup property to bpy.types.Collections
  • create new collection that is used for user remapping of existing collection 'cube_coll'.
  • if we assign some parameter to new PropertyGroup Parameter blender will crash
Script wont crash if we comment out new property assignment, or user remapping.
The script:
import bpy
class CollectionsSettings(bpy.types.PropertyGroup):
    parent: bpy.props.PointerProperty(name="parent", type=bpy.types.Collection)
bpy.utils.register_class(CollectionsSettings)
bpy.types.Collection.prop = bpy.props.PointerProperty(type=CollectionsSettings)
# 4 lines below gives crash
cube_col = bpy.data.collections['Cube_coll']
new_col = bpy.data.collections.new('new_col')
new_col.prop.parent = cube_col
cube_col.id_data.user_remap(new_col)
Just execute script from text editor to see the crash.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Oct 27 2020, 5:02 PM
Can confirm, caused by rB37e08e526c6f: Depsgraph: Add IDProperties handling.
This is only the case if you remap to the same id that holds the property -- and in that case, looks like this enters infinite recursion
1   IDP_foreach_property                                       idprop.c                 1145 0x31b3297
2   blender::deg::DepsgraphRelationBuilder::build_idproperties deg_builder_relations.cc 578  0xa34c6eb
3   blender::deg::DepsgraphRelationBuilder::build_collection   deg_builder_relations.cc 594  0xa34c751
4   blender::deg::DepsgraphRelationBuilder::build_id           deg_builder_relations.cc 497  0xa34c35e
5   blender::deg::build_idproperties_callback                  deg_builder_relations.cc 573  0xa34c6b9
6   IDP_foreach_property                                       idprop.c                 1151 0x31b32e6
7   IDP_foreach_property                                       idprop.c                 1158 0x31b3325
8   IDP_foreach_property                                       idprop.c                 1158 0x31b3325
9   blender::deg::DepsgraphRelationBuilder::build_idproperties deg_builder_relations.cc 578  0xa34c6eb
10  blender::deg::DepsgraphRelationBuilder::build_collection   deg_builder_relations.cc 594  0xa34c751
11  blender::deg::DepsgraphRelationBuilder::build_id           deg_builder_relations.cc 497  0xa34c35e
12  blender::deg::build_idproperties_callback                  deg_builder_relations.cc 573  0xa34c6b9
13  IDP_foreach_property                                       idprop.c                 1151 0x31b32e6
14  IDP_foreach_property                                       idprop.c                 1158 0x31b3325
15  IDP_foreach_property                                       idprop.c                 1158 0x31b3325
16  blender::deg::DepsgraphRelationBuilder::build_idproperties deg_builder_relations.cc 578  0xa34c6eb
17  blender::deg::DepsgraphRelationBuilder::build_collection   deg_builder_relations.cc 594  0xa34c751
18  blender::deg::DepsgraphRelationBuilder::build_id           deg_builder_relations.cc 497  0xa34c35e
19  blender::deg::build_idproperties_callback                  deg_builder_relations.cc 573  0xa34c6b9
20  IDP_foreach_property                                       idprop.c                 1151 0x31b32e6
... <More>
So if you remap to something else, no crash occurs
import bpy
# no crash
third_col = bpy.data.collections.new('third_col')
cube_col.id_data.user_remap(third_col)
Thx @Philipp Oeser (lichtwerk) I may simplified the script too much, but you are right. If I remap 'cube_col' first, then point cube_col to new_col we get no crash (no loop pointer to itself)
However in a bit more complicated case it will still crash:
import bpy
cube_col.id_data.user_remap(new_col)                              # remap first so no cyclip loop
new_col.prop.parent = cube_col            # A points to B
cube_col.prop.parent = new_col            # B points to A
I guess you may say there is still loop
new_col points to cube_col ; then cube_col points back to new_col; etc
It worked it 2.82 though. IMO blender could/should check for loop like those.
Bastien Montagne (mont29) triaged this task as High priority.
Bastien Montagne (mont29) edited projects, added BF Blender (2.91); removed BF Blender.
Bastien Montagne (mont29) moved this task from Backlog to bcon3: Bugs on the BF Blender (2.91) board.
