Operating system: Microsoft Windows 10 Pro version 10.0.19041
Graphics card: NVIDIA GeForce GTX 780
Broken: 2.90.1, 3e85bb34d0d7, master, 2020-09-23
Worked: ??? (I updated straight from 2.79 to 2.90.1, big jump)
I was working on a final version of an animation after completing the rough version, and I don't know when it happened but any new line strokes I drew were much MUCH thicker than they were. The thickness of the brush had not changed. And even if I made it as thin as possible, it was still thicker than existing lines.
I tried starting a new file to see if the problem persisted. It did not. It was only in that save file.
I then tried copying everything over to a new save file, and doing that fixed the issue. However I managed to figure out what had caused it in the first place, purely by chance:
- Open attached .blend file
- Go to Object Mode, and delete the "Stroke" object under Collection.
- Go back to draw mode under either of the two remaining stroke objects, and draw a line.
(Hitting undo until before setting it to Object Mode fixes the issue)
(Doing anything in Object Mode also seems to cause the issue)
