Property Search Improvements
Confirmed, NormalPublicTO DO
Ctrl-Tab Improvement
Currently ctrl-tab doesn't know about which tabs have search results. It should change a little bit:
  • If used while the text field is in focus, keep that focus.
  • Only cycle through tabs with results.
Fuzzy Search
D9145 Needs to be altered to not use per-word comparison, instead compare the entire text block at once.
It's not yet known if search will be a bottleneck for anyone on lower end hardware. At least some efforts should be made to identify any performance issues, and possibly address them. I did some initial profiling. Although I didn't find any major bottleneck, it's possible some things could be looked at.
I tested by maximizing the property editor in a relatively complex file and ctrl-scrolling up and down very quickly, so it should be redrawing as quickly as it can.
Here are some interesting items from the "Bottom up" results:
  • __strcmp_avx2: 5.52%
    • buttons_context: 1.15%
  • UI_panel_begin: 0.85%
  • BLI_strcasestr: 0.617% -- called from property search only
  • panel_add_check: 0.61%
  • uiItemFullR: 0.582%
I think the first thing I would consider is using GHash for buttons_context.c, similar to the recent changes in screen_context.
Revisions and Commits
Hans Goudey (HooglyBoogly) changed the task status from Needs Triage to Confirmed.Oct 29 2020, 9:11 PM
Hans Goudey (HooglyBoogly) created this task.
Hans Goudey (HooglyBoogly) updated the task description. (Show Details)
Just for the records: We haven't heard about any performance issues with the current implementation, so there's no urgent need to look into improvements there. So we can leave this task on the side for now.
