Particle System Influence procedural textures [e.g. on hair length] dont update in realtime immediately [depsgraph relation will work only after certain updates]
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-18 20:27, hash: rB48c484a22e0d
  • create hair particle system
  • create texture for hair length parameter and try to manipulate with size, contrast, intensity or other
  • parameters not update until I check on/off hair length checkbox. try to change any parameter and on/off for apply.
  • create a keyframe on hair length (now changing clouds Size slider will update in realtime)
  • remove the keyframe: relation still works (clouds Size slider will update in realtime)
  • save the file
  • reload the file --> relation is intact (clouds Size slider will update in realtime)
Since this is only an issue if the file is not saved, an example file is not really showing the issue, here it is anyways
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Oct 30 2020, 9:43 AM
Philipp Oeser (lichtwerk) renamed this task from don`t update hair lenght with generated texture to Particle System Influence procedural textures [e.g. on hair length] dont update in realtime [animating works - even removing animation keeps relation intact].Oct 30 2020, 10:10 AM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) renamed this task from Particle System Influence procedural textures [e.g. on hair length] dont update in realtime [animating works - even removing animation keeps relation intact] to Particle System Influence procedural textures [e.g. on hair length] dont update in realtime immediately [depsgraph relation will work only after certain updates].Oct 30 2020, 10:31 AM
Think I got a fix [adding the texture should rebuild DEG relations immediately]
