Blender 2.91 crashes on startup
Operating system: WINDOWS 10 Family version 2004
Graphics card: AMD RADEON HD 6450 (drivers updated)
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) : blender-2.91.0-29780b8101eb-windows64
Worked: (newest version of Blender that worked as expected) : 2.90.1
When launching (from blender.exe file) blender immediately crashes (UI window closes before complete display)
Download last version of experimental Blender, unzipp folder, double click on blender.exe file
(also occured with 2.92 alpha and two previous hashes of 2.91 beta)
    • more info that may be useful :
  • 6 GB of installed RAM
  • blender 2.90.1 is installed and works fine.
  • appended blender.crash.txt file generated in AppData/Local/Temp folder when tryin to launch Blender 2.91
Looking forward to using next version Blender !
Thank you for your help
JB
Robert Guetzkow (rjg) closed this task as Archived.Nov 5 2020, 5:49 PM
Robert Guetzkow (rjg) claimed this task.
The crash occurs in the graphics driver. The AMD Radeon HD 6450 is from the AMD Radeon HD 6000 series and has the old TeraScale 2 micro-architecture. The minimum requirements for Blender 2.8x and 2.9x state that GCN first generation or later is required for running Blender.
Supported Graphics Cards
  • NVIDIA: GeForce 400 and newer, Quadro Tesla GPU architecture and newer, including RTX-based cards, with NVIDIA drivers (list of all GeForce and Quadro GPUs)
  • AMD: GCN 1st gen and newer (list of all AMD GPUs)
  • Intel: Haswell and newer (list of all Intel GPUs)
  • macOS: version 10.13 or newer with supported hardware
Unfortunately, this means that your GPU is below the minimum requirements and we don't provide support for it. Graphics glitches and even crashes due to unpatched bugs in the graphics driver can occur on unsupported hardware. You may have to use a previous release of Blender with lower requirements.
