UV Smart Project works wrong
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-08 13:39, hash: rB06dac0a45320
Smart UV unwrap does not react on UV seams
Use Smart UV unwrap with seams on some co-planar edges.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Nov 9 2020, 3:55 PM
Mind sharing an example file where this happens?
Look at the attached image.
Those "pinkish" lines are seams. And they are completely ignored by smart_project .
Recently Devs have changed something in the smart_project operator cause it gives error when using parameters that are included in current offcial 2.90.1 API and no info in the Changelog that something has been developed recently ( with 2.91 version I have to use Radians instead Degrees ).
You can download my add-on ( sorry for the quality of the code inside it ) and see that I had to use other parameters (watched from the operator call in Bblender ) than are mentioned in official API.
https://github.com/muchasty/UV-Tools/blob/master/LightmapAutoUV.py
Philipp Oeser (lichtwerk) closed this task as Archived.Nov 9 2020, 6:17 PM
Maybe I am misunderstanding, but Smart UV is not supposed to take Seams into account?
Instead, islands are defined by by Angle Limit?
https://docs.blender.org/manual/en/latest/modeling/meshes/editing/uv.html
So, if this was never working [which I think it wasnt], then this sounds more like a feature request than a bug.
Will have to close (but feel free to comment again if this was working at some point - or if this is a misunderstanding on my side)
Regarding the change between 2.90.1 and 2.91: smart UV was ported to C, see rB850234c1b10a: UV: port smart project from Python to C
Since this is a different subject - having to use radians instead of degrees - than the original report though, I would kindly ask to report this separately [agree, this should be mentioned in the release logs]
I am disappointed with that kind of bug filtering !
Please use 2.90.1 and you will see how the smart_project() should work !
Look at the attached image and find the difference ( this is from 2.90.1 with nicely cuts made by seams )
according to the previous image from 2.91Beta !
Philipp Oeser (lichtwerk) reopened this task as Needs Triage.Nov 9 2020, 11:10 PM
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.Nov 10 2020, 8:05 AM
No problem. Let's go forward and do not look back. :)
I hope that it will be fixed soon cause it is crucial for me for making with my add-on well working lightmaps for UE4.
Thank you.
Well, fix is in, should be in tomorrows build from https://builder.blender.org/download/ (and will also be in 2.91 release)
What is going on?
Problem came back in release blender-2.91.0-e580c188533c-windows64
