Effector liquid
Operating system: windows 10
Graphics card: Quadro K2200
Broken: 2.91 effector does not work with liquid simulations, the liquid just passes thru the effector
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.EditedNov 10 2020, 11:23 AM
I can't reproduce this. The effector displaces the water simulation.
The steps I've tried:
  1. Start Blender
  2. Select the Cube
  3. Use Object > Quick Effect > Quick Fluid
  4. Add a sphere Add > Mesh > UV Sphere
  5. Select the sphere and in the Physics Properties, enable Fluid and set type to Effector
  6. Select the fluid domain, in the Physics Properties > Fluid > Cache set Type to All
  7. Save the project file
  8. Bake the simulation
Does this file work for you? You may have to adjust the cache path to a directory that exists on your system.
Please provided steps to reproduce this issue, the most recent version of Blender that worked properly and a minimal project file that demonstrates the issue.
@Adrian Brits (AJB123456789) Have you checked if the file I've provided work for you? In case you don't report back the ticket will be closed tomorrow due to inactivity.
Robert Guetzkow (rjg) closed this task as Archived.Nov 23 2020, 1:55 PM
