Broken: version: 2.91 documentation and all versions before
Pagename: files/data_blocks
https://docs.blender.org/manual/en/dev/files/data_blocks.html
The documentation does not explain the (totally non-intuitive) way to add a custom property subtype, such as a color (You have to manually enter a properly formatted array in the property value field). This is especially important to document properly now you can access them in the material node editor through the attribute node.
