OPTIX_ERROR_CUDA_ERROR in optixLaunch when creating a world texture with nodes
Graphics card: GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: rB3e85bb34d0d7
Worked: -
I'm trying to create a fairly simple node setup for environment texture, but after a while when changing anything within the setup (deleting a node, adjusting parameters) I'm getting an error message
OPTIX_ERROR_CUDA_ERROR in optixLaunch(pipelines[PIP_PATH_TRACE], cuda_stream[thread_index], launch_params_ptr, launch_params.data_elements, &sbt_params, wtile.w * wtile.num_samples, wtile.h, 1) (device_optix.cpp:760)
in shading mode and viewport cycles rendering just mess about with the nodes or move around the viewport for a few mins, not even adding anything, just make sure viewport render refreshes, eventually the error comes up, and cycles stops working until blender is restarted. reloading the .blend file without restarting blender doesn't work.
seems to only happen when using Optix rendering.
Philipp Oeser (lichtwerk) renamed this task from Error when creating a world texture with nodes to OPTIX_ERROR_CUDA_ERROR in optixLaunch when creating a world texture with nodes.Nov 25 2020, 3:39 PM
Aaron Carlisle (Blendify) changed the task status from Needs Triage to Needs Information from User.Sep 28 2021, 4:19 AM
Hi can you test with Blender 3.0 Alpha which can be downloaded from https://builder.blender.org/download/daily/
Raimund Klink (Raimund58) closed this task as Archived.Nov 4 2021, 9:37 AM
