Switching a window from Image Editor to UV Editor does not change the UI if the Image Editor contains "Render Result"
Closed, DuplicatePublic
Operating system: Linux-5.4.0-54-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: AMD Radeon VII
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Switching a window from Image Editor containing "Render Result" to UV editor does not present any of the UV editor UI until the "image" is closed.
Open new blend file.
Split 3D viewport into two windows, make one of them an Image Editor.
In the "Browse image to be linked" dropdown, select Render Result.
Back in the 3D viewport, tab into edit mode as you would to edit the UVs of the default cube.
Change the Image Editor window to a UV Editor window
The bug now manifests, the UV Editor GUI does not appear, it remains an Image Editor window until you press the "X" button to the right of "Render Result".
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Nov 27 2020, 11:00 AM
Havent checked code, but I also find this confusing.
@Jeroen Bakker (jbakker): Should we just exclude the Render Result from the possibilities in the dropdown, as proposed in T73182: Exclude 'Render Result' and 'Viewer' image types in the dropdown in certain contexts [Shader Editor, Compositor, UV Editor...] as well?
@Philipp Oeser (lichtwerk) yes think that is the best solution. Don't show options that will never be useful except if that option can driver artistic freedom.
