Final sample file for the 'Moss' and 'Leaves' use-cases.
Fully described and documented with steps using separate workspaces.
The main goals for these two combined use-cases where to:
- allow using whole collections as base geometry input
- implement an intuitive but flexible workflow for the orientation of point instances
- get a simple method to generate blobby meshes with flexbile application using the Points-to-Volume-to-Mesh workflow
Renders:
Full
Base
Leaves
Moss
Screenshot:
Video Demo:
File:
