Blender stopped work when i plugged out the power charge.Or when i cloes off my mac ,that situations happens a lot.
Process: blender [5701]
Path: /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.90.1 (2.90.1 2020-09-23)
Code Type: X86-64 (Native)
Parent Process: steam_osx [900]
Responsible: steam_osx [900]
User ID: 501
Date/Time: 2020-12-02 21:54:39.991 +0800
OS Version: macOS 11.0.1 (20B50)
Report Version: 12
Bridge OS Version: 5.0.1 (18P2561)
Anonymous UUID: 33D82950-9B9B-EE2D-A766-094212902332
Time Awake Since Boot: 13000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: blender [5701]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff202e8f86 swtch_pri + 10
1 libsystem_pthread.dylib 0x00007fff2031b07c cthread_yield + 11
2 blender 0x0000000104283a75 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::receive_or_steal_task(long&, long) + 565
3 blender 0x0000000104283529 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 329
4 blender 0x00000001060ee768 tbb::internal::task_group_base::wait() + 24
5 blender 0x000000010b83db7e BLI_task_pool_work_and_wait + 494
6 blender 0x0000000104b2c9d1 blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph*) + 513
7 blender 0x0000000104b3f3e1 DEG_evaluate_on_refresh + 97
8 blender 0x00000001040f753b scene_graph_update_tagged + 427
9 blender 0x000000010428c323 wm_event_do_depsgraph + 179
10 blender 0x000000010428c480 wm_event_do_refresh_wm_and_depsgraph + 128
11 blender 0x000000010428caa4 wm_event_do_notifiers + 1540
12 blender 0x0000000104287ec8 WM_main + 40
13 blender 0x0000000103f49812 main + 914
14 libdyld.dylib 0x00007fff20338631 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff202e8eba semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff20172c5c _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff2017312e _dispatch_semaphore_wait_slow + 98
3 blender 0x0000000109d24142 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 blender 0x0000000109d22cae void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff2031d950 _pthread_start + 224
6 libsystem_pthread.dylib 0x00007fff2031947b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff283ff92a caulk::mach::semaphore::wait_or_error() + 16
2 com.apple.audio.caulk 0x00007fff283ec6e6 caulk::semaphore::timed_wait(double) + 110
3 com.apple.audio.caulk 0x00007fff283ec634 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff283ec3c0 void* caulk::thread_proxy<std::1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 14:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff202e8e7e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff202e91f0 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff21e09de5 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff21ca5477 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 3435
4 com.apple.audio.CoreAudio 0x00007fff21e48f3a HALB_IOThread::Entry(void*) + 72
Thread 15:
1 blender 0x000000010427ea88 tbb::internal::rml::private_worker::run() + 104
2 blender 0x000000010427ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff2031d950 _pthread_start + 224
4 libsystem_pthread.dylib 0x00007fff2031947b thread_start + 15
Thread 16:
Thread 17:
Thread 18:
0 libGL.dylib 0x00007fff6b5d8884 glDeleteBuffers + 18
1 blender 0x000000010a1ef93c GPU_buf_free + 44
2 blender 0x000000010a20a388 GPU_vertbuf_discard + 24
3 blender 0x00000001043c90f7 mesh_batch_cache_clear + 151
4 blender 0x00000001043c9e7e DRW_mesh_batch_cache_free + 14
5 blender 0x00000001040786c2 BKE_mesh_runtime_clear_cache + 210
6 blender 0x000000010405b179 BKE_mesh_eval_delete + 25
7 blender 0x000000010409e974 BKE_object_free_derived_caches + 468
8 blender 0x0000000104b30a26 blender::deg::ObjectRuntimeBackup::restore_to_object(Object*) + 166
9 blender 0x0000000104b30291 blender::deg::RuntimeBackup::restore_to_id(ID*) + 161
10 blender 0x0000000104b2e2fc blender::deg::deg_update_copy_on_write_datablock(blender::deg::Depsgraph const*, blender::deg::IDNode const*) + 156
11 blender 0x0000000104b2cc86 blender::deg::(anonymous namespace)::deg_task_run_func(TaskPool*, void*) + 134
12 blender 0x00000001042777cb tbb::interface7::internal::isolate_within_arena(tbb::interface7::internal::delegate_base&, long) + 75
13 blender 0x000000010b83df92 tbb::internal::function_task<Task>::execute() + 50
14 blender 0x0000000104283df9 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 377
15 blender 0x00000001042834e1 tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 257
16 blender 0x0000000104274945 tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 533
17 blender 0x000000010427dc8b tbb::internal::market::process(rml::job&) + 43
18 blender 0x000000010427ead8 tbb::internal::rml::private_worker::run() + 184
19 blender 0x000000010427ea19 tbb::internal::rml::private_worker::thread_routine(void*) + 9
20 libsystem_pthread.dylib 0x00007fff2031d950 _pthread_start + 224
21 libsystem_pthread.dylib 0x00007fff2031947b thread_start + 15
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff20415be7 CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff204142ba
CFRunLoopRun + 1315
4 com.apple.CoreFoundation 0x00007fff204136be CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22db336d _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff2031d950 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff2031947b thread_start + 15
Thread 27:
0 libsystem_kernel.dylib 0x00007fff202eb8e2 psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff2031de6f _pthread_cond_wait + 1254
2 libc++.1.dylib 0x00007fff20284cf2 std::
1::condition_variable::wait(std::1::unique_lock<std::1::mutex>&) + 18
3 libTahoe64.dylib 0x0000000129ef95b2 Tahoe::ThreadPoolImpl::threadFunc(Tahoe::ThreadPoolImpl*, int) + 610
4 libTahoe64.dylib 0x0000000129efaca0 void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (*)(Tahoe::ThreadPoolImpl*, int), Tahoe::ThreadPoolImpl*, int> >(void*) + 48
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
0 libsystem_kernel.dylib 0x00007fff202eb8e2 __psynch_cvwait + 10
2 libTahoe64.dylib 0x000000012add210b embree::TaskScheduler::ThreadPool::thread_loop(unsigned long) + 107
3 libTahoe64.dylib 0x000000012adce7f0 embree::threadStartup(embree::ThreadStartupData*) + 48
4 libsystem_pthread.dylib 0x00007fff2031d950 _pthread_start + 224
5 libsystem_pthread.dylib 0x00007fff2031947b thread_start + 15
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
0 libsystem_pthread.dylib 0x00007fff20319458 start_wqthread + 0
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000  rbx: 0x0000000000000018  rcx: 0x00007fff202e8f86  rdx: 0x00001f3800000000
rdi: 0x0000000000000000  rsi: 0x00001f38c3f36fb6  rbp: 0x00007ffeebdf71b0  rsp: 0x00007ffeebdf71a8
 r8: 0x0000000000000000   r9: 0x0000000000000008  r10: 0x00001f38c3f36fc2  r11: 0x0000000000000246
r12: 0x000000000000000b  r13: 0x0000000000000019  r14: 0x0000000000000003  r15: 0x00007ff6db354400
rip: 0x00007fff202e8f86  rfl: 0x0000000000000246  cr2: 0x0000000161d8e000
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 222
Thread 0 instruction stream not available.
Thread 0 last branch register state not available.
Binary Images:
   0x103e08000 -        0x10e2aefff +blender (0) <224DF617-650B-3C26-922B-92829E49957D> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/MacOS/blender
   0x114dfc000 -        0x114e68fff +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Users/USER/Library/Application Support/Steam/*/Blender.app/Contents/Resources/lib/libomp.dylib
   0x11edeb000 -        0x11ef4efff  com.apple.audio.units.Components (1.14 - 1.14) <F8D75F8D-B039-3219-817F-CC8619BA8B09> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
   0x11ef87000 -        0x11f536fff  com.apple.audio.AudioDSPComponents (1.0 - 1) <A8D32ACD-0292-320C-9387-23A38F969B7D> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
   0x11f967000 -        0x11f976fff  libobjc-trampolines.dylib (818.2) <27F9380F-20DE-3228-B34B-499FC8637F39> /usr/lib/libobjc-trampolines.dylib
   0x120790000 -        0x120af7fff  com.apple.AMDRadeonX6000MTLDriver (4.0.47 - 4.0.0) <7AF812ED-DE82-30AD-AD3C-762D71368CF4> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
   0x121674000 -        0x1217c7fff  com.apple.AMDRadeonX6000GLDriver (4.0.47 - 4.0.0) <C365FB60-E953-38B1-82BB-6EE76B3F7854> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
   0x121930000 -        0x121933fff  com.apple.CloudDocsFileProvider (1.0 - 726) <4D6FE4F4-D9A7-3D8C-9E46-AD0F39013259> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
   0x121944000 -        0x121947fff  com.apple.FileProviderOverride (325 - 325) <2612C540-143B-3BB9-BE93-ABED5A81D7BC> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
   0x121958000 -        0x121973fff  com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1350.1.1) <A64E9E4D-D141-3DC5-A0FE-E6CC3CE7150B> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
   0x124751000 -        0x124752fff +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
   0x12499b000 -        0x1249a0fff +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
   0x124d6d000 -        0x124d73fff +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
   0x124d7d000 -        0x124e18fff  dyld (832.7.1) <2705F0D8-C104-3DE9-BEB5-B1EF6E28656D> /usr/lib/dyld
   0x126ea3000 -        0x126ea7fff +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
   0x126ef5000 -        0x126ef5fff +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
   0x126efd000 -        0x127116fff +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
   0x1271af000 -        0x1271b4fff +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
   0x1271be000 -        0x1271cefff +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
   0x127259000 -        0x12725afff +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
   0x127262000 -        0x12726bfff +_socket.cpython-37m-darwin.so (0) <A4DDE5D0-B31B-3A17-82BE-4532FC9BCDA3> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so
   0x12727e000 -        0x127281fff +select.cpython-37m-darwin.so (0) <02400D4C-4C27-3FCA-B63B-7F29026E1FB1> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so
   0x1272cc000 -        0x1272dafff +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
   0x12736a000 -        0x12761afff +_ssl.cpython-37m-darwin.so (0) <354522B6-4702-3B5C-BA0E-AB7A4E479091> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so
   0x127724000 -        0x127736fff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
   0x127741000 -        0x127757fff +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
   0x127762000 -        0x127790fff +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
   0x12779f000 -        0x12779ffff +grp.cpython-37m-darwin.so (0) <DEEAC15B-D065-3D28-9F79-32426A8C67B7> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
   0x1277e7000 -        0x1277e7fff +_scproxy.cpython-37m-darwin.so (0) <9673CE7F-B1B9-3C49-96D2-D03BFEB345AE> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so
   0x1277ef000 -        0x1277f5fff +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
   0x1277fe000 -        0x1277fffff +_posixsubprocess.cpython-37m-darwin.so (0) <3DC85D51-0860-37D2-9F6A-0AD91A2595CE> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so
   0x127847000 -        0x127945fff +unicodedata.cpython-37m-darwin.so (0) <E65B37DA-33D3-364E-A794-CFAAC682C392> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/unicodedata.cpython-37m-darwin.so
   0x127951000 -        0x127963fff +_pickle.cpython-37m-darwin.so (0) <85237162-4DE3-38EA-99F5-287A1DB8BB02> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_pickle.cpython-37m-darwin.so
   0x127974000 -        0x127975fff +lapack_lite.cpython-37m-darwin.so (0) <13E4865F-46D4-3301-9D3E-49CCFDD3D095> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/linalg/lapack_lite.cpython-37m-darwin.so
   0x127abe000 -        0x127e27fff +_multiarray_umath.cpython-37m-darwin.so (0) <8B761C71-2D89-37F3-BEB5-B9254A2C3E02> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so
   0x128104000 -        0x128111fff +_multiarray_tests.cpython-37m-darwin.so (0) <15017CB9-B1EE-3481-9902-487DBE7BDB6E> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/core/_multiarray_tests.cpython-37m-darwin.so
   0x128125000 -        0x128137fff +_ctypes.cpython-37m-darwin.so (0) <B0269B94-1975-35FC-93D8-B7862608A10E> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_ctypes.cpython-37m-darwin.so
   0x12818d000 -        0x1281a5fff +_umath_linalg.cpython-37m-darwin.so (0) <01FBC95E-932B-3A93-962E-52168F690BD9> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/linalg/_umath_linalg.cpython-37m-darwin.so
   0x1282b8000 -        0x1282f5fff +_decimal.cpython-37m-darwin.so (0) <E8636347-BAF6-3D6F-B05A-49B6FDB71DD2> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_decimal.cpython-37m-darwin.so
   0x12831a000 -        0x12832bfff +_pocketfft_internal.cpython-37m-darwin.so (0) <988AA5B5-36FB-3D86-805C-F00EEF719789> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/fft/_pocketfft_internal.cpython-37m-darwin.so
   0x1283b4000 -        0x12841cfff +mtrand.cpython-37m-darwin.so (0) <8D5E395F-CCC8-36F1-96D9-A6E9DDA41AAF> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/mtrand.cpython-37m-darwin.so
   0x128474000 -        0x1284a4fff +common.cpython-37m-darwin.so (0) <61D582CA-1C59-3309-8A00-F442A082F200> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/common.cpython-37m-darwin.so
   0x1284be000 -        0x128510fff +bounded_integers.cpython-37m-darwin.so (0) <36A58A6D-37D5-3609-8C1B-BBA03F904E00> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/bounded_integers.cpython-37m-darwin.so
   0x128538000 -        0x12854bfff +mt19937.cpython-37m-darwin.so (0) <2802AEBB-A054-36AF-A4C8-CC8456F69F62> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/mt19937.cpython-37m-darwin.so
   0x12855c000 -        0x12857afff +bit_generator.cpython-37m-darwin.so (0) <A731D255-3FD7-3C14-B391-DE7EBA4DE4D9> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/bit_generator.cpython-37m-darwin.so
   0x12859a000 -        0x1285a7fff +philox.cpython-37m-darwin.so (0) <57D29373-83CC-374B-96C9-4B36D0F68B4F> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/philox.cpython-37m-darwin.so
   0x1285b8000 -        0x1285c2fff +pcg64.cpython-37m-darwin.so (0) <90C29A5D-B621-3CE6-B439-AAB6B4337604> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/pcg64.cpython-37m-darwin.so
   0x1285d2000 -        0x1285dafff +sfc64.cpython-37m-darwin.so (0) <2C7FCA5F-DA2E-34A5-9D04-A984B86BC536> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/sfc64.cpython-37m-darwin.so
   0x1285e9000 -        0x12865ffff +generator.cpython-37m-darwin.so (0) <86FEA253-4515-3EF4-8253-E3E8DF2F4BD3> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/site-packages/numpy/random/generator.cpython-37m-darwin.so
   0x128b78000 -        0x128b7efff +array.cpython-37m-darwin.so (0) <13F2F1B6-3644-36EB-A680-74EBC5DCE26F> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so
   0x128c0d000 -        0x128c0dfff +_opcode.cpython-37m-darwin.so (0) <DA893BE1-01DF-330B-ACCA-C9A9A6B7EE04> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_opcode.cpython-37m-darwin.so
   0x128cd5000 -        0x1291effff +libRadeonProRender64.dylib (0) <6355D917-D290-3F20-82AC-DCF1734E2F1E> /Users/USER/Library/Application Support/Blender/*/libRadeonProRender64.dylib
   0x12932a000 -        0x129344fff +_cffi_backend.cpython-37m-darwin.so (0) <34A2EC26-072B-399C-9841-6AE90C845EA6> /Users/USER/Library/Application Support/Blender/*/_cffi_backend.cpython-37m-darwin.so
   0x12939b000 -        0x129537fff +libRprLoadStore64.dylib (0) <EFD208B1-1ED7-3F50-83FB-2ACB27A7CB71> /Users/USER/Library/Application Support/Blender/*/libRprLoadStore64.dylib
   0x1295a7000 -        0x129813fff +libRadeonImageFilters.dylib (0) <BF6ACFF0-6C91-362C-B5F3-064DFA55B353> /Users/USER/Library/Application Support/Blender/*/libRadeonImageFilters.dylib
   0x1298ab000 -        0x129b3dfff +libRPRBlenderHelper.dylib (0) <E355C15B-E884-39F5-BC3E-1B26962F5201> /Users/USER/Library/Application Support/Blender/*/libRPRBlenderHelper.dylib
   0x129d60000 -        0x12b0ebfff +libTahoe64.dylib (0) <83DE9C94-2B4E-30F1-8C6E-E09FAF417B35> /Users/USER/Library/Application Support/Blender/*/libTahoe64.dylib
   0x12b5a5000 -        0x12be63fff +libNorthstar64.dylib (0) <5623B719-0D73-3E00-B32E-05341B7F74C4> /Users/USER/Library/Application Support/Blender/*/libNorthstar64.dylib
   0x12c1b3000 -        0x12c1bbfff +_elementtree.cpython-37m-darwin.so (0) <E40CCCAE-65D4-3AEC-92BA-4D6BD010A4D0> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_elementtree.cpython-37m-darwin.so
   0x12c1ca000 -        0x12c1f7fff +pyexpat.cpython-37m-darwin.so (0) <8DE98AAE-6AC5-322D-B1B4-BB5B13CD12CE> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/pyexpat.cpython-37m-darwin.so
   0x12c3d0000 -        0x12c3d1fff +_queue.cpython-37m-darwin.so (0) <2E95FB49-FE7E-3065-A632-9E7EBE8D25EA> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so
   0x12c45a000 -        0x12c45bfff +termios.cpython-37m-darwin.so (0) <4B2954DF-DF6A-3130-B6AB-AD6585A9ECF2> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/termios.cpython-37m-darwin.so
   0x12c6e4000 -        0x12c6e4fff +_uuid.cpython-37m-darwin.so (0) <AE6BA881-84D6-3766-9641-7A5B34B11A16> /Users/USER/Library/Application Support/Steam/*/blender.app/Contents/Resources/2.90/python/lib/python3.7/lib-dynload/_uuid.cpython-37m-darwin.so
0x7fff20056000 -     0x7fff20057fff  libsystem_blocks.dylib (78) <83E2F888-F4C1-3181-B21B-136A0D7293DD> /usr/lib/system/libsystem_blocks.dylib
0x7fff20058000 -     0x7fff2008dfff  libxpc.dylib (2038.40.38) <DC50F7DD-1C4B-3BD2-A54D-C5D7D97A3718> /usr/lib/system/libxpc.dylib
0x7fff2008e000 -     0x7fff200a5fff  libsystem_trace.dylib (1277.50.1) <94196441-5456-342D-84D1-C60A9249D273> /usr/lib/system/libsystem_trace.dylib
0x7fff200a6000 -     0x7fff20141fff  libcorecrypto.dylib (1000.40.21) <2FA5C1BD-F41C-3FCF-B1FA-7BED6E19ABEE> /usr/lib/system/libcorecrypto.dylib
0x7fff20142000 -     0x7fff2016efff  libsystem_malloc.dylib (317.40.8) <3688DBCE-2FFD-3F98-B12B-69ABE231908D> /usr/lib/system/libsystem_malloc.dylib
0x7fff2016f000 -     0x7fff201b3fff  libdispatch.dylib (1271.40.12) <C55547DC-A05B-34A1-BD41-D54948D8F57F> /usr/lib/system/libdispatch.dylib
0x7fff201b4000 -     0x7fff201ecfff  libobjc.A.dylib (818.2) <DD09F187-80F1-308F-9395-912F27E9A390> /usr/lib/libobjc.A.dylib
0x7fff201ed000 -     0x7fff201effff  libsystem_featureflags.dylib (28.40.2) <3E1E8F98-E791-301D-909F-4CA205C94D1A> /usr/lib/system/libsystem_featureflags.dylib
0x7fff201f0000 -     0x7fff20278fff  libsystem_c.dylib (1439.40.11) <8D791F3A-4848-302F-88CD-46D91DE73127> /usr/lib/system/libsystem_c.dylib
0x7fff20279000 -     0x7fff202cefff  libc++.1.dylib (904.4) <E7F465AC-C8FF-31DB-8EC4-7EBBA7468EB5> /usr/lib/libc++.1.dylib
0x7fff202cf000 -     0x7fff202e7fff  libc++abi.dylib (904.4) <253848B5-ED35-3202-8593-5DCC763A8192> /usr/lib/libc++abi.dylib
0x7fff202e8000 -     0x7fff20316fff  libsystem_kernel.dylib (7195.50.7) <41068F5C-74E3-3C98-9256-6A18364FB5BA> /usr/lib/system/libsystem_kernel.dylib
0x7fff20317000 -     0x7fff20322fff  libsystem_pthread.dylib (454.40.3) <78072EC6-2257-361A-AAF5-4A3C1832B5EB> /usr/lib/system/libsystem_pthread.dylib
0x7fff20323000 -     0x7fff2035dfff  libdyld.dylib (832.7.1) <0C66AB9F-E22C-3286-B76B-DA4008698CD2> /usr/lib/system/libdyld.dylib
0x7fff2035e000 -     0x7fff20367fff  libsystem_platform.dylib (254.40.4) <6C05D209-129A-373A-A90D-CC27AB18C091> /usr/lib/system/libsystem_platform.dylib
0x7fff20368000 -     0x7fff20393fff  libsystem_info.dylib (542.40.3) <90DDEF9D-9DBA-3599-A9DD-A7F730AE945F> /usr/lib/system/libsystem_info.dylib
0x7fff20394000 -     0x7fff2082ffff  com.apple.CoreFoundation (6.9 - 1770.106) <7EBD4941-5978-33EF-98FB-724BB81E92C8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff20830000 -     0x7fff20a5efff  com.apple.LaunchServices (1122.5.1 - 1122.5.1) <E26F607E-C523-3753-95FC-7A75130632FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff20a5f000 -     0x7fff20b32fff  com.apple.gpusw.MetalTools (1.0 - 1) <0CC81516-4858-3463-A2D8-8FCA414B63FD> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff20b33000 -     0x7fff20d96fff  libBLAS.dylib (1336.40.1) <903B0DDC-4B74-3305-B81D-8E66D6AFAD04> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff20d97000 -     0x7fff20de4fff  com.apple.Lexicon-framework (1.0 - 86.1) <A6282972-785B-3AC4-84A5-6780315011F1> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff20de5000 -     0x7fff20e53fff  libSparse.dylib (106) <D2BC7FE6-7801-3C3B-B8AC-A1F152F92D12> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff20e54000 -     0x7fff20ed0fff  com.apple.SystemConfiguration (1.20 - 1.20) <660AA1E5-A70A-3FC1-9462-570FBBC76125> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff20ed1000 -     0x7fff20f06fff  libCRFSuite.dylib (50) <6873F563-F0FB-32C5-A47A-D97A4931FEA8> /usr/lib/libCRFSuite.dylib
0x7fff20f07000 -     0x7fff2113dfff  libmecabra.dylib (929) <CF4538C2-3F4A-360C-B6D9-DEBBA67CD5F0> /usr/lib/libmecabra.dylib
0x7fff2113e000 -     0x7fff214a1fff  com.apple.Foundation (6.9 - 1770.106) <87138770-ED31-393C-B462-4DAF1A0A52D7> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff214a2000 -     0x7fff2158efff  com.apple.LanguageModeling (1.0 - 247) <83FC0636-F2C6-33F1-A873-E3D5A07A9BA4> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff2158f000 -     0x7fff216c5fff  com.apple.CoreDisplay (229.1 - 229.1) <AA59D0CD-E87F-3C7A-AD83-6EC5D4E67DD5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff216c6000 -     0x7fff2193bfff  com.apple.audio.AudioToolboxCore (1.0 - 1180.19.2) <B7A2D61A-1494-31D8-B8BD-E4D99F512F2A> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff2193c000 -     0x7fff21b25fff  com.apple.CoreText (677.1.0.7 - 677.1.0.7) <ACB75DE7-96D0-379E-8E94-B7DF51A694B9> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff21b26000 -     0x7fff221c9fff  com.apple.audio.CoreAudio (5.0 - 5.0) <6A945D2C-386F-375C-8343-845012AAA414> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff221ca000 -     0x7fff22519fff  com.apple.security (7.0 - 59754.41.1) <93F55E6B-0EB7-3E06-A742-CEBE33A01DCE> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff2251a000 -     0x7fff2277bfff  libicucore.A.dylib (66108) <D5A29DA5-5693-38EA-B09B-5D7160B26339> /usr/lib/libicucore.A.dylib
0x7fff2277c000 -     0x7fff22785fff  libsystem_darwin.dylib (1439.40.11) <3BD9046F-FAED-3FD9-8191-49A4618555A3> /usr/lib/system/libsystem_darwin.dylib
0x7fff22786000 -     0x7fff22a6dfff  com.apple.CoreServices.CarbonCore (1307 - 1307) <F20CD75D-F81D-36F3-90AE-7C2F26E01DA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff22a6e000 -     0x7fff22aacfff  com.apple.CoreServicesInternal (476 - 476) <E861339B-F001-3BBC-96C7-916E41B0F238> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff22aad000 -     0x7fff22ae7fff  com.apple.CSStore (1122.5.1 - 1122.5.1) <74069AC7-3AA9-3953-A036-425105377BFF> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff22ae8000 -     0x7fff22b95fff  com.apple.framework.IOKit (2.0.2 - 1845.50.1) <18A1F263-4AE2-3F9B-A38F-50BEB00B43D1> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff22b96000 -     0x7fff22ba1fff  libsystem_notify.dylib (279.40.4) <73D358B2-6C2D-33DF-975C-BE9EE5F45A0F> /usr/lib/system/libsystem_notify.dylib
0x7fff22ba2000 -     0x7fff22bedfff  libsandbox.1.dylib (1441.40.38) <C3EE1BD6-3A84-3997-A6F1-B8CA56747A87> /usr/lib/libsandbox.1.dylib
0x7fff22bee000 -     0x7fff2394afff  com.apple.AppKit (6.9 - 2022.10.104) <FA93F8CC-AB69-3E81-AC53-3FA08704738C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2394b000 -     0x7fff23b9efff  com.apple.UIFoundation (1.0 - 725) <7F8DC3AA-296B-37DE-AF30-40F2653452C1> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff23b9f000 -     0x7fff23bb1fff  com.apple.UniformTypeIdentifiers (631.8 - 631.8) <071D25FB-2014-3066-9B85-6FE5CCC0B6AC> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
0x7fff23bb2000 -     0x7fff23d3cfff  com.apple.desktopservices (1.16 - 1346.1.2) <A32717C6-9203-365E-8999-2E0E846B59F5> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff23d3d000 -     0x7fff23d4ffff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <EA21B8E2-1435-3908-8C11-9C7EC5C615BA> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
0x7fff24009000 -     0x7fff2464cfff  libnetwork.dylib (2288.40.53) <CEC9E75A-51F6-3675-9EA5-007C3DB82A7B> /usr/lib/libnetwork.dylib
0x7fff2464d000 -     0x7fff24aeafff  com.apple.CFNetwork (1207.2 - 1207.2) <B3968D35-EAF0-3661-8F93-3255128411B6> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff24aeb000 -     0x7fff24af9fff  libsystem_networkextension.dylib (1295.40.29) <84A5011E-1511-30C7-86D8-514CFA59EF42> /usr/lib/system/libsystem_networkextension.dylib
0x7fff24afa000 -     0x7fff24afafff  libenergytrace.dylib (22) <3646415C-FA89-30B2-84C4-3FDB868DF6F6> /usr/lib/libenergytrace.dylib
0x7fff24afb000 -     0x7fff24b56fff  libMobileGestalt.dylib (978.40.29) <BC657BA3-6A59-35EF-8E90-26D431477F74> /usr/lib/libMobileGestalt.dylib
0x7fff24b57000 -     0x7fff24b6dfff  libsystem_asl.dylib (385) <EB8BA94D-1B45-322E-9D26-272872423807> /usr/lib/system/libsystem_asl.dylib
0x7fff24b6e000 -     0x7fff24b85fff  com.apple.TCC (1.0 - 1) <A3F5F853-54FC-3E67-9F8B-3605B1063D6F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff24b86000 -     0x7fff24ee4fff  com.apple.SkyLight (1.600.0 - 564) <8C9746D1-E3E5-346F-AA56-6EFCDC13DBA4> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff24ee5000 -     0x7fff25578fff  com.apple.CoreGraphics (2.0 - 1463) <C5688C95-BE5D-3278-B1CD-F0A02DF8BDEC> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff25579000 -     0x7fff2566ffff  com.apple.ColorSync (4.13.0 - 3472) <37533610-6D35-304E-8D76-945DA4E524AB> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff25670000 -     0x7fff256cbfff  com.apple.HIServices (1.22 - 712) <8B336535-DBFD-3B34-8099-FF2DEE52BE7F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff25a77000 -     0x7fff25e94fff  com.apple.CoreData (120 - 1044.1) <57B11511-9A86-3373-8A84-C1AEBC304131> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff25e95000 -     0x7fff25eabfff  com.apple.ProtocolBuffer (1 - 285.20.8.8.1) <7B0CA279-FD76-32D3-9A8B-ABA6AA799C30> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff25eac000 -     0x7fff2606bfff  libsqlite3.dylib (321.1) <821CC6A3-785F-3EE7-ADFA-9231367F8E09> /usr/lib/libsqlite3.dylib
0x7fff2606c000 -     0x7fff260e8fff  com.apple.Accounts (113 - 113) <71C2E841-B020-3116-B883-418F84E2343B> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff260e9000 -     0x7fff26101fff  com.apple.commonutilities (8.0 - 900) <8290C811-7A21-3492-B1BC-67FDF0E1BC3A> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff26102000 -     0x7fff26183fff  com.apple.BaseBoard (526 - 526) <E401B7D4-F695-3F7C-87E2-D553189CA550> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff26184000 -     0x7fff261cffff  com.apple.RunningBoardServices (1.0 - 505.40.18) <26B2DD3C-EF2D-3FD6-9653-D4F857930917> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff261d0000 -     0x7fff26245fff  com.apple.AE (918 - 918) <9A914CB1-A413-352B-95BA-D639D66DC591> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff26246000 -     0x7fff2624cfff  libdns_services.dylib (1310.40.42) <5D270035-0D34-3E64-9BA3-8F302E2D767C> /usr/lib/libdns_services.dylib
0x7fff2624d000 -     0x7fff26254fff  libsystem_symptoms.dylib (1431.40.36) <81345ED1-342F-347F-B979-39846E607C8C> /usr/lib/system/libsystem_symptoms.dylib
0x7fff26255000 -     0x7fff263d9fff  com.apple.Network (1.0 - 1) <91834A81-98F8-36D6-B6DA-D024ED6ECFC7> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff263da000 -     0x7fff263fefff  com.apple.analyticsd (1.0 - 1) <C34AD81D-9BD0-3295-BBC5-39D762835717> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff263ff000 -     0x7fff26401fff  libDiagnosticMessagesClient.dylib (112) <BA70052F-9547-368E-A643-ACF46CA53A3F> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff26402000 -     0x7fff2644efff  com.apple.spotlight.metadata.utilities (1.0 - 2149.9) <732E84A3-6D75-3C92-8C0A-028547EDDF4D> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff2644f000 -     0x7fff264e9fff  com.apple.Metadata (10.7.0 - 2149.9) <19EA1487-2CDE-36C6-8EC1-537E33FB8874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff264ea000 -     0x7fff264f0fff  com.apple.DiskArbitration (2.7 - 2.7) <2E613BB2-B956-3668-9B33-1464DBC83611> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff264f1000 -     0x7fff26b97fff  com.apple.vImage (8.1 - 543) <9CFD36A4-7508-31EB-8B78-E5572F5C5426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff26b98000 -     0x7fff26e5afff  com.apple.QuartzCore (1.11 - 924.8.3) <5AB4670A-3630-3C4B-B3D5-6A55A09063FC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff26e5b000 -     0x7fff26e9cfff  libFontRegistry.dylib (309) <A9D64BDE-020F-35E6-8EE7-E5FCF748AEDB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff26e9d000 -     0x7fff26fdefff  com.apple.coreui (2.1 - 688.1) <41699554-ABC8-3431-A4E1-026EAD281148> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff26fdf000 -     0x7fff270cafff  com.apple.ViewBridge (550 - 550) <54AE4058-B1B7-3260-BF7F-27EB494505EC> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff270cb000 -     0x7fff270d6fff  com.apple.PerformanceAnalysis (1.275 - 275) <07995E93-BF12-3B63-B33C-9D8941CF43B3> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff270d7000 -     0x7fff270e6fff  com.apple.OpenDirectory (11.0 - 230.40.1) <F1AC2921-D026-3048-909D-B623F6AAFC94> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff270e7000 -     0x7fff27106fff  com.apple.CFOpenDirectory (11.0 - 230.40.1) <030D197F-1B82-3E26-AD80-C7621EF6656C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff27107000 -     0x7fff2710ffff  com.apple.CoreServices.FSEvents (1290.40.2 - 1290.40.2) <EE985F8A-608D-3A9E-8DDE-C8F635DC69CC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff27110000 -     0x7fff27134fff  com.apple.coreservices.SharedFileList (143 - 143) <CCD817BF-99F0-34A3-A619-8F47A1F83CC8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff27135000 -     0x7fff27137fff  libapp_launch_measurement.dylib (14.1) <7698D7E2-ECE9-3551-AD03-381DF65EE388> /usr/lib/libapp_launch_measurement.dylib
0x7fff27138000 -     0x7fff27180fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <14614F40-5A4F-31C0-90DC-B1FB3D8ECE66> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
0x7fff27181000 -     0x7fff27263fff  libxml2.2.dylib (34.8) <667639AF-E0DB-3BFD-B641-5D0BFBCBF6A3> /usr/lib/libxml2.2.dylib
0x7fff27264000 -     0x7fff272b0fff  com.apple.CoreVideo (1.8 - 408.4) <652F979C-432A-304C-964C-6AE3231398F3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff272b1000 -     0x7fff272b3fff  com.apple.loginsupport (1.0 - 1) <F748E027-FC2A-3492-BBBB-3ED232B2BD1A> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff272b4000 -     0x7fff272dcfff  com.apple.aps.framework (4.0 - 4.0) <B34512B2-7172-380A-973E-83DAE3D4DE96> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff272dd000 -     0x7fff272fafff  com.apple.UserManagement (1.0 - 1) <3677EF4B-F11A-3485-9DB5-D6251E690B77> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff272fb000 -     0x7fff2749afff  com.apple.cloudkit.CloudKit (962 - 962) <2143260C-E7B8-304A-A476-6E54D2BD109D> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff2749b000 -     0x7fff2751dfff  com.apple.CloudDocs (1.0 - 726) <5D3CA1B8-6177-3972-8B1E-85BF64DB6B33> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff28217000 -     0x7fff28293fff  com.apple.corelocation (2420.8.10.3.1 - 2420.8.10.3.1) <FC02CA2B-8F8B-3D5F-8BC5-129F14F83231> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff28294000 -     0x7fff282a4fff  libsystem_containermanager.dylib (318.41.1) <BF178091-2151-3462-AB4F-A2E111650BA2> /usr/lib/system/libsystem_containermanager.dylib
0x7fff282a5000 -     0x7fff282b6fff  com.apple.IOSurface (289.3 - 289.3) <457DD2AD-E48D-3BD3-9549-9CD9CA6B4F51> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff282b7000 -     0x7fff282c3fff  com.apple.IOAccelerator (439.35.4 - 439.35.4) <1FC8B98E-D5A3-3C7B-919B-D187D7A6F76B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff282c4000 -     0x7fff283e9fff  com.apple.Metal (244.32.6 - 244.32.6) <6BB79960-68EA-3CB9-89D9-E8A11B8C9491> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff283ea000 -     0x7fff28406fff  com.apple.audio.caulk (1.0 - 70) <DCBC8033-421D-39D1-938A-BDDFF9998179> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff28407000 -     0x7fff284f1fff  com.apple.CoreMedia (1.0 - 2757.5) <B547DA4C-81F0-3793-BCDC-4F454674CBC0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff284f2000 -     0x7fff2864efff  libFontParser.dylib (305.1.0.5) <A233E765-948B-3954-99C2-A9122040E41B> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff2864f000 -     0x7fff2894efff  com.apple.HIToolbox (2.1.1 - 1060.0.1) <97A715C9-6C47-388D-8801-A44FB84E5C4D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2894f000 -     0x7fff28962fff  com.apple.framework.DFRFoundation (1.0 - 264) <C38F9EBB-14D6-354F-8C25-0FB09B110384> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff28963000 -     0x7fff28966fff  com.apple.dt.XCTTargetBootstrap (1.0 - 17500) <71F236E8-7169-3A4B-A1CA-94D7F967971D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff28967000 -     0x7fff28990fff  com.apple.CoreSVG (1.0 - 149) <B105E089-D8AE-3BEF-BE0B-409009959692> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff28991000 -     0x7fff28bcafff  com.apple.ImageIO (3.3.0 - 2130.1.2) <E6C736F9-05FF-313E-9707-EBE4EB81BF03> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff28bcb000 -     0x7fff28f46fff  com.apple.CoreImage (15.0.0 - 1110.11) <AA028F01-5695-36EA-85EE-EB39CF889102> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff28f47000 -     0x7fff28fa2fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <A929F704-8938-3F9F-8B35-9ABDA03F4D37> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff28fa3000 -     0x7fff28fa6fff  libsystem_configuration.dylib (1109.40.9) <EA408233-7EA5-33B5-B099-E9609DD3A0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff28fa7000 -     0x7fff28fabfff  libsystem_sandbox.dylib (1441.40.38) <349F71A1-4C7C-3AE0-8A1B-B95CCBB2327F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff28fac000 -     0x7fff28fadfff  com.apple.AggregateDictionary (1.0 - 1) <59A5FE13-BE12-3393-BC0F-40007817F8D7> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff28fae000 -     0x7fff28fb1fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4CE6C43E-92B6-3933-BEE1-079336A0D6A1> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff28fb2000 -     0x7fff28fb3fff  liblangid.dylib (136) <EB65D90D-45E3-326D-9F1E-3E9E068E64C5> /usr/lib/liblangid.dylib
0x7fff28fb4000 -     0x7fff29054fff  com.apple.CoreNLP (1.0 - 245) <AC95402C-105B-3830-8A5B-DA9BCE1AB68B> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff29055000 -     0x7fff2905bfff  com.apple.LinguisticData (1.0 - 399) <5C2C56E5-6298-32D3-B374-362D7C7F4A85> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff2905c000 -     0x7fff29718fff  libBNNS.dylib (288.40.19) <C5CF6455-A81A-3B09-94F2-C8F7307E5A58> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff29719000 -     0x7fff298ecfff  libvDSP.dylib (760.40.6) <CA559095-DE79-3932-B718-7EFE7770CDF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff298ed000 -     0x7fff298fffff  com.apple.CoreEmoji (1.0 - 128) <7F9AAA77-3D73-3164-8961-F0BFE55D7AE8> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff29900000 -     0x7fff2990afff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <94F7D4E1-88DF-3445-90EF-A0EBC9AF7961> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
0x7fff2990b000 -     0x7fff299ddfff  com.apple.framework.CoreWLAN (16.0 - 1657) <F8A977ED-F434-33CD-8039-5679152B7971> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff299de000 -     0x7fff29bddfff  com.apple.CoreUtils (6.4 - 640.15) <D53B6F40-B920-3A30-A216-440FD2B7AF24> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff29bde000 -     0x7fff29c00fff  com.apple.MobileKeyBag (2.0 - 1.0) <841C6DAF-1AF1-304E-9EBD-49FC945B235A> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff29c01000 -     0x7fff29c11fff  com.apple.AssertionServices (1.0 - 505.40.18) <12D5EA20-2B9C-3C83-A132-70F77B172775> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff29c12000 -     0x7fff29c9efff  com.apple.securityfoundation (6.0 - 55240.40.4) <AC9A369B-6E9B-3267-B56E-2746853615A0> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff29c9f000 -     0x7fff29ca8fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A59DD866-92E0-3B0E-AE10-36E86878132C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff29ca9000 -     0x7fff29cadfff  com.apple.xpc.ServiceManagement (1.0 - 1) <D522DFA0-C2D9-31EC-BC6F-8B034DACA54D> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff29cae000 -     0x7fff29cb0fff  libquarantine.dylib (119.40.2) <3DD7F9EE-9B9A-3896-A8CC-4D5BE49385AE> /usr/lib/system/libquarantine.dylib
0x7fff29cb1000 -     0x7fff29cbcfff  libCheckFix.dylib (31) <E66C5541-5A04-3295-BE25-CC251EC627AE> /usr/lib/libCheckFix.dylib
0x7fff29cbd000 -     0x7fff29cd4fff  libcoretls.dylib (169) <32CA60AD-6EEF-335D-8FB0-A2695D455939> /usr/lib/libcoretls.dylib
0x7fff29cd5000 -     0x7fff29ce5fff  libbsm.0.dylib (68.40.1) <7530532D-8655-34D7-8C1A-273E196A0DE4> /usr/lib/libbsm.0.dylib
0x7fff29ce6000 -     0x7fff29d2ffff  libmecab.dylib (929) <533290ED-7500-37B4-9212-D9BA773228F8> /usr/lib/libmecab.dylib
0x7fff29d30000 -     0x7fff29d35fff  libgermantok.dylib (24) <14D82EB1-0212-3E80-90F5-842233FFA740> /usr/lib/libgermantok.dylib
0x7fff29d36000 -     0x7fff29d4bfff  libLinearAlgebra.dylib (1336.40.1) <CF200364-E4AF-36A8-AB57-1ADFB6BF28B5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff29d4c000 -     0x7fff29f73fff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <C08BA44C-9764-363E-A35C-B21AEEFA424B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff29f74000 -     0x7fff29fc3fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <E7D2B0C7-FAE3-398A-B949-70A0F6CDAD75> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff29fc4000 -     0x7fff2a10afff  com.apple.MLCompute (1.0 - 1) <0621E469-4210-3C45-AC4E-023B25E0D1CE> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
0x7fff2a10b000 -     0x7fff2a141fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <328CA407-7A75-3FE6-9AC1-0D6CE0FF2B0A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff2a142000 -     0x7fff2a17ffff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <0CE771E3-E262-3BFC-BF02-888D7EBB0FE3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff2a180000 -     0x7fff2a210fff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <4130FBE4-C36C-3E1D-BB0B-63D1A64B28E2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff2a211000 -     0x7fff2a220fff  com.apple.AppleFSCompression (125 - 1.0) <5BE26EB2-6012-33E5-AF38-D8C5F4DF64CA> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff2a221000 -     0x7fff2a22efff  libbz2.1.0.dylib (44) <F171593B-230C-390E-8EF7-D0659D2F6B54> /usr/lib/libbz2.1.0.dylib
0x7fff2a22f000 -     0x7fff2a233fff  libsystem_coreservices.dylib (127) <670DDFEB-8100-3C51-BC96-76BD46A21DF6> /usr/lib/system/libsystem_coreservices.dylib
0x7fff2a234000 -     0x7fff2a261fff  com.apple.CoreServices.OSServices (1122.5.1 - 1122.5.1) <4F03F324-1072-38B8-8BC5-837601C2DBA9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2a262000 -     0x7fff2a393fff  com.apple.AuthKit (1.0 - 1) <50C7FC9C-283A-3BB0-8D30-BC39975A2318> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff2a437000 -     0x7fff2a449fff  libz.1.dylib (76) <0AF4F195-1F20-3F59-B09F-31E7249890D5> /usr/lib/libz.1.dylib
0x7fff2a44a000 -     0x7fff2a491fff  libsystem_m.dylib (3186.40.2) <0276200D-C6F2-3E79-AFDC-E4D7F60A7837> /usr/lib/system/libsystem_m.dylib
0x7fff2a492000 -     0x7fff2a492fff  libcharset.1.dylib (59) <56962263-B7B8-3B84-9C2F-F493D9D2630A> /usr/lib/libcharset.1.dylib
0x7fff2a493000 -     0x7fff2a498fff  libmacho.dylib (973.4) <F2E3F7A6-B15A-30ED-A6AD-4EFEC37CF3E7> /usr/lib/system/libmacho.dylib
0x7fff2a499000 -     0x7fff2a4b4fff  libkxld.dylib (7195.50.7) <6FFE0801-7BDA-34EE-89E9-EAEC21A7394C> /usr/lib/system/libkxld.dylib
0x7fff2a4b5000 -     0x7fff2a4c0fff  libcommonCrypto.dylib (60178.40.2) <66E10FDF-896D-35F4-B9A8-8EE9400AC23A> /usr/lib/system/libcommonCrypto.dylib
0x7fff2a4c1000 -     0x7fff2a4cbfff  libunwind.dylib (200.10) <BD13DE19-15F8-3982-ACCB-CD8C036D5D2B> /usr/lib/system/libunwind.dylib
0x7fff2a4cc000 -     0x7fff2a4d3fff  liboah.dylib (203.1.3) <5EC28751-3BE8-3BB7-9DBE-305225CBD41B> /usr/lib/liboah.dylib
0x7fff2a4d4000 -     0x7fff2a4defff  libcopyfile.dylib (173.40.2) <17A9CD2E-0527-3FF7-9CFA-57B30133DFB5> /usr/lib/system/libcopyfile.dylib
0x7fff2a4df000 -     0x7fff2a4e6fff  libcompiler_rt.dylib (102.2) <FE958653-7FEC-3ADD-9AC0-A386E47208CF> /usr/lib/system/libcompiler_rt.dylib
0x7fff2a4e7000 -     0x7fff2a4e9fff  libsystem_collections.dylib (1439.40.11) <31C10DA5-F9B8-36E4-B859-8F6B845FF65D> /usr/lib/system/libsystem_collections.dylib
0x7fff2a4ea000 -     0x7fff2a4ecfff  libsystem_secinit.dylib (87.40.10) <BB2A70F5-BECC-34BD-90FE-14D31C5FD80D> /usr/lib/system/libsystem_secinit.dylib
0x7fff2a4ed000 -     0x7fff2a4effff  libremovefile.dylib (49.40.3) <24CE2291-AEB3-30C9-94E8-535AA6E9C6F2> /usr/lib/system/libremovefile.dylib
0x7fff2a4f0000 -     0x7fff2a4f0fff  libkeymgr.dylib (31) <B47F66C0-27F4-3B77-BAA0-85E895A7421D> /usr/lib/system/libkeymgr.dylib
0x7fff2a4f1000 -     0x7fff2a4f8fff  libsystem_dnssd.dylib (1310.40.42) <F54EC6FB-DEC3-3DA8-A749-4892F50D1F08> /usr/lib/system/libsystem_dnssd.dylib
0x7fff2a4f9000 -     0x7fff2a4fefff  libcache.dylib (83) <C83C4423-D12A-32A0-875D-81450DF40F42> /usr/lib/system/libcache.dylib
0x7fff2a4ff000 -     0x7fff2a500fff  libSystem.B.dylib (1292.50.1) <14E3BB7B-B95F-3700-8D12-B9B2012C0AF8> /usr/lib/libSystem.B.dylib
0x7fff2a501000 -     0x7fff2a504fff  libfakelink.dylib (3) <6E8ABD0B-6BC7-3E2C-B36B-2A7DA4ED0804> /usr/lib/libfakelink.dylib
0x7fff2a505000 -     0x7fff2a505fff  com.apple.SoftLinking (1.0 - 1) <23011830-946E-312B-A4BA-1725568F5E76> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
0x7fff2a506000 -     0x7fff2a53dfff  libpcap.A.dylib (98.40.1) <F2D9427C-C7D7-35F9-8A65-AE2C76D73E4B> /usr/lib/libpcap.A.dylib
0x7fff2a53e000 -     0x7fff2a62efff  libiconv.2.dylib (59) <BFC929D5-6E2C-3A49-9760-870BC89FC558> /usr/lib/libiconv.2.dylib
0x7fff2a62f000 -     0x7fff2a640fff  libcmph.dylib (8) <ABEA25CF-8895-31DA-B884-F4012007E7E9> /usr/lib/libcmph.dylib
0x7fff2a641000 -     0x7fff2a6b2fff  libarchive.2.dylib (83.40.4) <54E0F2AE-C7F5-34A6-8B09-82FED0643886> /usr/lib/libarchive.2.dylib
0x7fff2a6b3000 -     0x7fff2a71afff  com.apple.SearchKit (1.4.1 - 1.4.1) <E51D4AB5-0576-3392-B45F-E9CA02D22ED5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2a71b000 -     0x7fff2a71cfff  libThaiTokenizer.dylib (3) <41BFE684-D7B8-3DBB-A3F6-E25DB819E86A> /usr/lib/libThaiTokenizer.dylib
0x7fff2a71d000 -     0x7fff2a744fff  com.apple.applesauce (1.0 - 16.26) <0AFF7A71-EE52-36E6-82B5-459459D99D68> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff2a745000 -     0x7fff2a75cfff  libapple_nghttp2.dylib (1.41) <94E600F0-740B-308D-9475-8720FFB1923E> /usr/lib/libapple_nghttp2.dylib
0x7fff2a75d000 -     0x7fff2a76ffff  libSparseBLAS.dylib (1336.40.1) <7A917514-DD2C-3A97-A29B-F41BDCA18852> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2a770000 -     0x7fff2a771fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <CC090B4C-48B8-3DE1-84FA-807642C38DF9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff2a772000 -     0x7fff2a776fff  libpam.2.dylib (28.40.1) <4C7D4B94-5CBA-3480-9BA0-D52B5C675D2A> /usr/lib/libpam.2.dylib
0x7fff2a777000 -     0x7fff2a78ffff  libcompression.dylib (96.40.6) <C84DBB3A-EDEB-3871-BB2F-AB682A0653F8> /usr/lib/libcompression.dylib
0x7fff2a790000 -     0x7fff2a795fff  libQuadrature.dylib (7) <C13CA095-EE2D-3C50-98E5-A3570323776F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2a796000 -     0x7fff2ab32fff  libLAPACK.dylib (1336.40.1) <5A406319-C3A7-3D73-93C2-9968ACC81241> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2ab33000 -     0x7fff2ab81fff  com.apple.DictionaryServices (1.2 - 341) <CBFBB0CC-093A-39AC-99E3-C032029AC7C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2ab82000 -     0x7fff2ab9afff  liblzma.5.dylib (16) <7AEA0ACB-B03C-323B-AD4F-C5BD0584D780> /usr/lib/liblzma.5.dylib
0x7fff2ab9b000 -     0x7fff2ab9cfff  libcoretls_cfhelpers.dylib (169) <86671710-F263-3ED2-8B7D-0052264682CF> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff2ab9d000 -     0x7fff2ac97fff  com.apple.APFS (1677.50.1 - 1677.50.1) <CBABD7ED-84C7-3F72-80EB-5F8AED435566> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff2ac98000 -     0x7fff2aca5fff  libxar.1.dylib (452) <8999C952-D05A-3BFA-A673-1EB0B27EBB73> /usr/lib/libxar.1.dylib
0x7fff2aca6000 -     0x7fff2aca9fff  libutil.dylib (58.40.2) <ECE0C079-2434-3B7E-89EE-B2E538E7BBAD> /usr/lib/libutil.dylib
0x7fff2acaa000 -     0x7fff2acd2fff  libxslt.1.dylib (17.2) <7C79FCBB-B6B4-33A4-BD4B-34D674C2866F> /usr/lib/libxslt.1.dylib
0x7fff2acd3000 -     0x7fff2acddfff  libChineseTokenizer.dylib (37) <F2ECD480-D020-3141-A3B0-D32C8EDA159F> /usr/lib/libChineseTokenizer.dylib
0x7fff2acde000 -     0x7fff2ad9cfff  libvMisc.dylib (760.40.6) <3CA6964F-742A-33C1-90BB-C8B2D1BF0A4D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2ad9d000 -     0x7fff2ae35fff  libate.dylib (3.0.4) <7D10CB14-3612-31A3-82F2-232602CA4E86> /usr/lib/libate.dylib
0x7fff2ae36000 -     0x7fff2ae3dfff  libIOReport.dylib (64) <AD8D1B4C-F575-316A-9B59-D24C7C15775E> /usr/lib/libIOReport.dylib
0x7fff2ae3e000 -     0x7fff2ae6cfff  com.apple.CrashReporterSupport (10.13 - 15045.1) <2BF44063-CC0D-3CF0-807A-F70E0487E079> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff2af58000 -     0x7fff2af5ffff  libMatch.1.dylib (38) <93E36D5B-9452-3D8E-BC00-DF3E29E9573F> /usr/lib/libMatch.1.dylib
0x7fff2af60000 -     0x7fff2afebfff  libCoreStorage.dylib (554) <7918C52C-BD4A-3661-9735-E7C6B907D48E> /usr/lib/libCoreStorage.dylib
0x7fff2afec000 -     0x7fff2b03ffff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <5F9D3C05-FBF9-345D-B49F-95ED20451F0E> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff2b040000 -     0x7fff2b059fff  libexpat.1.dylib (26) <AE175A8E-4D38-3080-A0A8-201ACBE332DE> /usr/lib/libexpat.1.dylib
0x7fff2b05a000 -     0x7fff2b063fff  libheimdal-asn1.dylib (597.40.10) <1316D27D-F0EA-34C6-A347-BEE21CB6AFA6> /usr/lib/libheimdal-asn1.dylib
0x7fff2b064000 -     0x7fff2b078fff  com.apple.IconFoundation (479.2 - 479.2) <80665902-A372-3C2A-A5EB-25CEDDA30A66> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
0x7fff2b079000 -     0x7fff2b0e6fff  com.apple.IconServices (479.2 - 479.2) <3E085586-2251-350B-84CE-4CFE7873F9A0> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff2b0e7000 -     0x7fff2b184fff  com.apple.MediaExperience (1.0 - 1) <86D052FE-4200-311A-B53D-3C6EF5240A69> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff2b185000 -     0x7fff2b1aefff  com.apple.persistentconnection (1.0 - 1.0) <EA6A7841-EC57-39FC-9F2A-11752F6A972C> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff2b1af000 -     0x7fff2b1bdfff  com.apple.GraphVisualizer (1.0 - 100.1) <B9A37FA5-AB1B-3645-9F36-50C48732692D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff2b1be000 -     0x7fff2b5d9fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <54C42FE9-18BE-3284-A0F5-24F8BD8EE6AE> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff2b5da000 -     0x7fff2b624fff  com.apple.OTSVG (1.0 - 677.1.0.7) <918A1463-4534-3D72-A06E-0531915C4F37> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff2b625000 -     0x7fff2b62bfff  com.apple.xpc.AppServerSupport (1.0 - 2038.40.38) <A437306B-6D63-308B-AC69-468F1A70C8A6> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
0x7fff2b62c000 -     0x7fff2b63dfff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <D4873860-7D4B-3ACC-8940-2B0956DFB41B> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff2b63e000 -     0x7fff2b640fff  libspindump.dylib (295) <5B9254B7-7BAB-308E-9182-ECA60A0BA09A> /usr/lib/libspindump.dylib
0x7fff2b641000 -     0x7fff2b701fff  com.apple.Heimdal (4.0 - 2.0) <9382C6FC-4234-3D13-A598-0A13C04D9528> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff2b702000 -     0x7fff2b71cfff  com.apple.login (3.0 - 3.0) <9C424BA4-9280-30CE-858E-F18587C7E721> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff2b89b000 -     0x7fff2b89efff  libodfde.dylib (26) <B0C98B87-FAC4-3507-8546-BF4B03C1A827> /usr/lib/libodfde.dylib
0x7fff2b89f000 -     0x7fff2b909fff  com.apple.bom (14.0 - 233) <F2B16396-0757-3E1B-8A67-5979B9317EF3> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff2b90a000 -     0x7fff2b953fff  com.apple.AppleJPEG (1.0 - 1) <37C198D5-DF3F-3ED5-8DD3-5B1FBF7B3059> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff2b954000 -     0x7fff2ba32fff  libJP2.dylib (2130.1.2) <F4C74378-8FD9-3A9D-9E14-86F7213D468A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff2ba33000 -     0x7fff2ba36fff  com.apple.WatchdogClient.framework (1.0 - 98.40.5) <30521EFA-509E-335C-9D32-5FD6CA769A5A> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff2ba37000 -     0x7fff2ba6afff  com.apple.MultitouchSupport.framework (4400.28 - 4400.28) <7A065BB2-13BA-3DB4-93BB-FD4B034EE493> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff2ba6b000 -     0x7fff2bbbdfff  com.apple.VideoToolbox (1.0 - 2757.5) <286CE415-4B19-3F7E-A8E4-0CE8C85C7EBF> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff2bbbe000 -     0x7fff2bbf0fff  libAudioToolboxUtility.dylib (1180.19.2) <EE687E3D-BA7B-306F-95FC-35A97B7E373B> /usr/lib/libAudioToolboxUtility.dylib
0x7fff2bbf1000 -     0x7fff2bc17fff  libPng.dylib (2130.1.2) <C1D8DC7E-D118-3984-80B1-61D7FA89DC7C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff2bc18000 -     0x7fff2bc75fff  libTIFF.dylib (2130.1.2) <47BC22DE-0058-3402-90EB-8EC81BEBC244> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff2bc76000 -     0x7fff2bc92fff  com.apple.IOPresentment (50.10 - 37) <A84FB6B2-8ED1-31DC-AC7C-726E7915F541> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff2bc93000 -     0x7fff2bc99fff  com.apple.GPUWrangler (6.1.27 - 6.1.27) <89405160-B919-372E-B63A-BA35C9D62EFF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff2bc9a000 -     0x7fff2bc9dfff  libRadiance.dylib (2130.1.2) <6A2BF16D-8AF3-32AD-B42F-DA8029A8462E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff2bc9e000 -     0x7fff2bca3fff  com.apple.DSExternalDisplay (3.1 - 380) <9BF3CCC3-DB7C-30B3-879B-9650918C73FF> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff2bca4000 -     0x7fff2bcc8fff  libJPEG.dylib (2130.1.2) <E7902D69-99C3-3D7C-9244-86EA0D1A9617> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff2bcc9000 -     0x7fff2bcf8fff  com.apple.ATSUI (1.0 - 1) <39A55921-5BA9-3BA0-9C71-FD598BE2E80C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2bcf9000 -     0x7fff2bcfdfff  libGIF.dylib (2130.1.2) <BEE81025-0B18-37BD-BB5F-6E8FD2262336> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff2bcfe000 -     0x7fff2bd07fff  com.apple.CMCaptureCore (1.0 - 79.12.3) <43F3557A-D353-36B5-B5D6-3D352478EC2F> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
0x7fff2bd08000 -     0x7fff2bd4ffff  com.apple.print.framework.PrintCore (16 - 531) <0EB74D87-B560-380C-8B88-EDAED20D0D99> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2bd50000 -     0x7fff2be1cfff  com.apple.TextureIO (3.10.9 - 3.10.9) <44F02506-287C-3733-9ED2-01B36F97ABBF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff2be1d000 -     0x7fff2be25fff  com.apple.InternationalSupport (1.0 - 60) <D92C8AC5-6D8C-33C9-B011-DE275FA5BB88> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff2be26000 -     0x7fff2bea1fff  com.apple.datadetectorscore (8.0 - 674) <43D2CEDD-8A10-3A9F-BFE1-CFBBC35149C1> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff2bea2000 -     0x7fff2bf00fff  com.apple.UserActivity (434 - 434) <9FDA9333-95A0-3301-B75C-B6ABD7F94E09> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
0x7fff2bf01000 -     0x7fff2c667fff  com.apple.MediaToolbox (1.0 - 2757.5) <722521DC-E21A-36EA-8381-4E34B182D806> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff2cb21000 -     0x7fff2cb48fff  com.apple.locationsupport (2420.8.10.3.1 - 2420.8.10.3.1) <7BC41C49-445B-32A1-ABC4-BD791A0BDD99> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff2cb49000 -     0x7fff2cb7afff  libSessionUtility.dylib (76.7) <CA11B08D-BE35-3763-A358-E76B6341B089> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff2cb7b000 -     0x7fff2ccaafff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <6D66F9E9-C3ED-3015-AB27-BA6D2689A002> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2ccab000 -     0x7fff2cd12fff  com.apple.audio.AudioSession (1.0 - 76.7) <19D0DDAE-D4D2-363A-A6EE-D450E254427D> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff2cd13000 -     0x7fff2cd25fff  libAudioStatistics.dylib (25) <2310E5CF-38EC-338C-9C8D-FB79EC9B5C98> /usr/lib/libAudioStatistics.dylib
0x7fff2cd26000 -     0x7fff2cd35fff  com.apple.speech.synthesis.framework (9.0.48.1 - 9.0.48.1) <92283C03-C35F-3F97-8F81-383FB38CB66B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2cd36000 -     0x7fff2cda1fff  com.apple.ApplicationServices.ATS (377 - 516) <25751B9A-D1FD-3D90-8EB1-67D3DE9F6163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2cda2000 -     0x7fff2cdbafff  libresolv.9.dylib (68) <6C18FE1C-EB05-3E02-925D-DE09157C55F9> /usr/lib/libresolv.9.dylib
0x7fff2cdbb000 -     0x7fff2cdcefff  libsasl2.2.dylib (214) <C0EBD583-8C32-3BB2-9433-103A749C0DF8> /usr/lib/libsasl2.2.dylib
0x7fff2ceed000 -     0x7fff2cfccfff  libSMC.dylib (20) <2E125E1A-D5D6-3054-8384-E1A7A23DD0FE> /usr/lib/libSMC.dylib
0x7fff2cfcd000 -     0x7fff2d02cfff  libcups.2.dylib (494) <F27A4527-C76D-34FE-B268-1C57A127C542> /usr/lib/libcups.2.dylib
0x7fff2d02d000 -     0x7fff2d03cfff  com.apple.LangAnalysis (1.7.0 - 254) <B4F48E46-CEF9-3674-903C-609CA77E78B5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2d03d000 -     0x7fff2d047fff  com.apple.NetAuth (6.2 - 6.2) <54EC7F7F-0DBB-38E4-9BBA-0DB0404E2C9D> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff2d048000 -     0x7fff2d04ffff  com.apple.ColorSyncLegacy (4.13.0 - 1) <A34CD7EB-977C-3FF7-A422-9EC40D79A2BD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2d050000 -     0x7fff2d05bfff  com.apple.QD (4.0 - 416) <39777BBB-6781-36B5-AF36-E3452D222E09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2d05c000 -     0x7fff2d6cafff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <513ADF72-F3C7-3381-A926-FD1F6683EB09> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff2d6cb000 -     0x7fff2d6d7fff  com.apple.perfdata (1.0 - 67.40.1) <9C94952B-AA5F-3541-A326-649EFEAFE8B1> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff2d6d8000 -     0x7fff2d6e6fff  libperfcheck.dylib (41) <32799FC7-F2BF-3440-8853-378EE0E0445A> /usr/lib/libperfcheck.dylib
0x7fff2d6e7000 -     0x7fff2d6f6fff  com.apple.Kerberos (3.0 - 1) <2529747E-275C-35E6-AB6E-1D14DA5835D2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff2d6f7000 -     0x7fff2d746fff  com.apple.GSS (4.0 - 2.0) <DC8F40C2-966E-3F86-8A21-47B426965E85> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff2d747000 -     0x7fff2d757fff  com.apple.CommonAuth (4.0 - 2.0) <815F69EE-F251-3125-A094-C95B25804469> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff2d758000 -     0x7fff2d77efff  com.apple.MobileAssets (1.0 - 659.40.5) <AD744CE8-9213-389E-ACA8-0451B4FC885C> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff2d7aa000 -     0x7fff2d7ccfff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <AD781B2F-DEB0-3E13-9420-C0B6449EDE7A> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff2d7cd000 -     0x7fff2d7d5fff  com.apple.CorePhoneNumbers (1.0 - 1) <8922ABCB-0302-382B-A0DD-984668BFA8E3> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff2d92a000 -     0x7fff2d92afff  liblaunch.dylib (2038.40.38) <D71781B5-4034-3349-BBE5-4B796CD3629A> /usr/lib/system/liblaunch.dylib
0x7fff2d92b000 -     0x7fff2d930fff  libffi.dylib (27) <526FD43A-CFE3-3DFC-B57C-F8BC5A1F6F34> /usr/lib/libffi.dylib
0x7fff2e11c000 -     0x7fff2e262fff  com.apple.Sharing (1570.6 - 1570.6) <B76CAA48-84E4-309A-AE4D-FBB5E2D17CAD> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff2e263000 -     0x7fff2e383fff  com.apple.Bluetooth (8.0.1 - 8.0.1f5) <7136F7B5-F009-3139-BD52-D51815F7D9A4> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff2e384000 -     0x7fff2e398fff  com.apple.AppContainer (4.0 - 509.40.16) <705EFE05-0522-33E1-9139-F9D5B59AEFB7> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff2e399000 -     0x7fff2e39cfff  com.apple.SecCodeWrapper (4.0 - 509.40.16) <74BF3804-694F-3AE3-95A8-31B1DF5D9468> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff2e39d000 -     0x7fff2e3f6fff  com.apple.ProtectedCloudStorage (1.0 - 1) <F5C02479-9D92-3CB6-8C21-9AA229D411D4> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff2e64a000 -     0x7fff2fb34fff  com.apple.GeoServices (1.0 - 1757.20.8.12.21) <088A1DAC-0AD7-317F-B853-8882CF526324> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff2fb35000 -     0x7fff2fb40fff  com.apple.DirectoryService.Framework (11.0 - 230.40.1) <969BBAAA-736C-3262-8BAD-BB02EE3722A3> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff2fb41000 -     0x7fff2fb6cfff  com.apple.RemoteViewServices (2.0 - 163) <09228BBD-D1F6-388C-AD09-9AD113C44271> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff2fb6d000 -     0x7fff2fb7cfff  com.apple.SpeechRecognitionCore (6.1.12 - 6.1.12) <275341D7-157B-3B5A-A81D-382CEF408262> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff2fb7d000 -     0x7fff2fb84fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <66CCAAEC-B04B-326F-BB83-6A9E668111BC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2fdc8000 -     0x7fff2fdc8fff  libsystem_product_info_filter.dylib (8.40.1) <FF59B842-1290-3C4A-9015-AC972563406E> /usr/lib/system/libsystem_product_info_filter.dylib
0x7fff2fea3000 -     0x7fff2fea3fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <BBCF1D0C-F727-3B9B-801E-FCEA6C9C1103> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2feca000 -     0x7fff2fecafff  com.apple.CoreServices (1122.5.1 - 1122.5.1) <070D2800-D014-34E3-AAA9-CB7199EFC728> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff30198000 -     0x7fff30198fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <5D5F6FDF-38E5-363A-A73C-3C21A2D11574> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff301d9000 -     0x7fff301e4fff  com.apple.MediaAccessibility (1.0 - 130) <D7556226-D396-3EA8-B10D-F73C074ABFAD> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff301e5000 -     0x7fff30204fff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <8C52B479-2985-3112-8C95-38C082EC6DF4> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
0x7fff30205000 -     0x7fff30209fff  com.apple.AppleSRP (5.0 - 1) <663CC9B2-670B-3F1C-9C42-E8242A040287> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff3020a000 -     0x7fff30215fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <73EEC846-DC76-30EB-9D43-7D311452D440> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff30216000 -     0x7fff3024dfff  com.apple.framework.SystemAdministration (1.0 - 1.0) <31EFF4FD-12E6-3A3B-8F52-F7288263D549> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff309fc000 -     0x7fff30a91fff  com.apple.CoreBluetooth (1.0 - 1) <0F11E92C-6CFC-3912-BB82-B4CE7BA16FC7> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff30a92000 -     0x7fff30a9bfff  com.apple.SymptomDiagnosticReporter (1.0 - 79.40.12) <3FF67454-E235-33D7-AB87-02496A234188> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff30a9c000 -     0x7fff30aaffff  com.apple.PowerLog (1.0 - 1) <E34CC7ED-0ADB-3D16-87B4-1489D6D7918C> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff30ab0000 -     0x7fff30abcfff  com.apple.AppleIDAuthSupport (1.0 - 1) <7103A610-7E5A-34F7-BE69-5E25B334E66A> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff30abd000 -     0x7fff30b65fff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <12CEDA8E-D339-3022-BFD9-135458523B3E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff30b66000 -     0x7fff30b99fff  com.apple.MediaKit (16 - 927.40.2) <E5571EB2-2864-372E-BE83-DDE90F1A05CC> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff30b9a000 -     0x7fff30c85fff  com.apple.DiskManagement (14.0 - 1733.40.24) <7B3D0853-7B34-331A-902C-D2ED8004FD39> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff30c86000 -     0x7fff31040fff  com.apple.CoreAUC (321.2.0 - 321.2.0) <CF62493C-B5DE-3C08-B9B3-4B7B4D1AEA84> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff31041000 -     0x7fff31044fff  com.apple.Mangrove (1.0 - 25) <9E1C3E05-5B1A-3025-9DF5-BA2B40453CE5> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff31045000 -     0x7fff31072fff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <FA8FC4B3-851C-3082-AD2A-DF86089EB3C9> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff31073000 -     0x7fff31193fff  com.apple.FileProvider (325 - 325) <B02BE1B5-92B4-371F-AEBA-087BB58272D4> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff31194000 -     0x7fff311b7fff  com.apple.GenerationalStorage (2.0 - 322) <3400BD70-40AE-3FC5-BC7F-B6AB44B6134D> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff31a00000 -     0x7fff31a3ffff  com.apple.AppleVPAFramework (3.20.4 - 3.20.4) <9E22EFBC-493A-32A3-B7C2-0F56B4072D17> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff31b10000 -     0x7fff31b4cfff  com.apple.DebugSymbols (195.1 - 195.1) <93BEC865-279E-3A6E-A24B-487C51FF6459> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff31b4d000 -     0x7fff31c0afff  com.apple.CoreSymbolication (12.2 - 64541.4) <D9F608E4-437D-3A1C-83E7-7BD6CF830589> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff31c0b000 -     0x7fff31c14fff  com.apple.CoreTime (283) <A7E32D27-8B00-363C-AD63-C57D760632A3> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
0x7fff32a8b000 -     0x7fff32aeefff  com.apple.framework.Apple80211 (17.0 - 1728) <E5DB3BA3-DA6B-33B2-A111-852B5041DE4E> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff32aef000 -     0x7fff32c41fff  com.apple.CoreWiFi (3.0 - 341) <4B9C6F89-74B7-35F0-AC61-7ECD993B8139> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff32c5b000 -     0x7fff32c92fff  com.apple.LDAPFramework (2.4.28 - 194.5) <1D3EE3B4-47EA-3EA4-9D9B-8BE68438C97E> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff32c93000 -     0x7fff32c94fff  com.apple.TrustEvaluationAgent (2.0 - 35) <F8489D0F-CB98-3077-A14C-246B23A3CEDD> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff32c95000 -     0x7fff32d98fff  libcrypto.44.dylib (56.40.4) <4FDD7D62-15A2-328F-A9B4-1D3CF719048E> /usr/lib/libcrypto.44.dylib
0x7fff32d99000 -     0x7fff32dc6fff  libssl.46.dylib (56.40.4) <C516ED7A-78A0-3704-8E00-CCD04520EB9D> /usr/lib/libssl.46.dylib
0x7fff32dc7000 -     0x7fff32e76fff  com.apple.DiskImagesFramework (595.40.1 - 595.40.1) <BD2EAE99-4370-3837-A31E-696E60A0ED75> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff32eae000 -     0x7fff32ebdfff  com.apple.xpc.RemoteServiceDiscovery (1.0 - 2038.40.38) <7F2CB942-65FF-3A6B-AA1E-717BB18DEE80> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff32ebe000 -     0x7fff32ed5fff  com.apple.xpc.RemoteXPC (1.0 - 2038.40.38) <118A75E2-58FB-3E30-B0F0-064E42BD3A9B> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff32f1d000 -     0x7fff32f20fff  com.apple.help (1.3.8 - 71) <FFC118DA-4302-3A44-B166-8810A045B492> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff32f21000 -     0x7fff32f28fff  com.apple.EFILogin (2.0 - 2) <4EE8F2C6-F75A-3545-93C7-9EC7DB7E4337> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff32f29000 -     0x7fff32f34fff  libcsfde.dylib (554) <DB193672-8501-3F7B-BEB4-4F59C8887512> /usr/lib/libcsfde.dylib
0x7fff32f35000 -     0x7fff32f9afff  libcurl.4.dylib (121.40.2) <5058A2E4-6D41-3951-BCAE-AA3F1391E9C1> /usr/lib/libcurl.4.dylib
0x7fff32f9b000 -     0x7fff32fa2fff  com.apple.LoginUICore (4.0 - 4.0) <E5C4195B-FCDC-3045-9459-26259A47CEF0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff3315e000 -     0x7fff3315efff  com.apple.ApplicationServices (48 - 50) <BF6B5DC5-22AF-3926-8D21-7F4CFDB03644> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3345e000 -     0x7fff3345efff  libHeimdalProxy.dylib (79) <D67CF959-658D-3E1C-9900-5DC0A507D02A> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff33511000 -     0x7fff33511fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <106AE4DA-6F73-393B-889D-5D048ECDDDE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff33536000 -     0x7fff33578fff  com.apple.StreamingZip (1.0 - 1) <EA637C36-E29D-3332-9F15-821D32A3EA73> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff335bb000 -     0x7fff335c0fff  com.apple.PushKit (1.0 - 1) <3413F98D-29D1-324C-A6F4-CDA5E3A6B75A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff335c1000 -     0x7fff335f7fff  com.apple.C2 (1.3 - 569) <3A7AFD52-2823-3E0B-B6B7-3543DCB15B02> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff3362a000 -     0x7fff33e37fff  com.apple.vision.EspressoFramework (1.0 - 256) <48FD96E6-54BA-3E93-9CCD-9116BAB291C9> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff33e38000 -     0x7fff33e4ffff  com.apple.ANEServices (4.51 - 4.51) <A3787A57-C261-3CDE-92B1-5D40493303B3> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
0x7fff341ed000 -     0x7fff344b0fff  com.apple.spotlight.index (10.7.0 - 2149.9) <504A625F-1553-3F96-B4C3-4E5D1C794BD6> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff344c9000 -     0x7fff34519fff  com.apple.ChunkingLibrary (334 - 334) <996DC3E2-CC2E-376D-9A31-2D5093C078C5> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff34da1000 -     0x7fff34db7fff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <A4D0DD69-2A50-3022-A40F-73D755953297> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
0x7fff34f0f000 -     0x7fff34f12fff  com.apple.Cocoa (6.11 - 23) <D673DE75-8885-39F1-9847-81D602E69229> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff36329000 -     0x7fff36344fff  com.apple.openscripting (1.7 - 190) <EA384453-7A25-36CD-B6D5-FE58AB36334B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff36345000 -     0x7fff36348fff  com.apple.securityhi (9.0 - 55008) <E11B58BC-4B25-3991-B243-C2A5C797DE60> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff36349000 -     0x7fff3634cfff  com.apple.ink.framework (10.15 - 227) <1C0F3697-754A-307E-83B4-2D133D80E7B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3634d000 -     0x7fff36350fff  com.apple.CommonPanels (1.2.6 - 101) <50B28EBC-6852-3843-8BB6-93800D8EE7D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff36351000 -     0x7fff36358fff  com.apple.ImageCapture (1707 - 1707) <F8BA52A6-2076-3439-9F02-8EFABDFADC87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff391b3000 -     0x7fff391b6fff  com.apple.OSAServicesClient (1.0 - 1) <7193D631-42B0-3F65-AD4D-161DF0DC2633> /System/Library/PrivateFrameworks/OSAServicesClient.framework/Versions/A/OSAServicesClient
0x7fff3b894000 -     0x7fff3ba4ffff  libFosl_dynamic.dylib (200) <ED8086EA-BD50-3766-970B-014D0E163C01> /usr/lib/libFosl_dynamic.dylib
0x7fff3c6e3000 -     0x7fff3c6e6fff  com.apple.print.framework.Print (15 - 271) <47A826E5-8E5F-3B20-9131-58D9F94C58B6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3c6e7000 -     0x7fff3c6eafff  com.apple.Carbon (160 - 164) <DE2A89F4-03DF-3E98-8C90-48C095DA3FDC> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3c965000 -     0x7fff3c984fff  com.apple.private.SystemPolicy (1.0 - 1) <10BDB417-5EFA-348A-9DB7-154F4BC4136D> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
0x7fff3cb34000 -     0x7fff3cb51fff  com.apple.sidecar-core (1.0 - 228) <BDC5714E-4AEF-3220-BE47-ED9F7F0153D3> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff3d2a9000 -     0x7fff3d2b4fff  com.apple.MallocStackLogging (1.0 - 1) <F9CA682E-FCC0-371F-90EA-B5CE51ABF8AC> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
0x7fff3d2ca000 -     0x7fff3d2dcfff  libmis.dylib (274.40.12) <CF45C71D-4237-369F-9FE1-91C0B9C77C06> /usr/lib/libmis.dylib
0x7fff3d2dd000 -     0x7fff3d2e0fff  com.apple.gpusw.GPURawCounter (12.25 - 12.0) <45E2924C-2619-3149-9502-A5BFFA721231> /System/Library/PrivateFrameworks/GPURawCounter.framework/Versions/A/GPURawCounter
0x7fff3d7ec000 -     0x7fff3d7fdfff  com.apple.sidecar-ui (1.0 - 228) <05A81084-5FDE-3839-8AE1-B304938BE849> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff40a16000 -     0x7fff40a45fff  libncurses.5.4.dylib (57) <2555F8FB-385E-3E1A-993E-A6B9F2BA9FD6> /usr/lib/libncurses.5.4.dylib
0x7fff40a46000 -     0x7fff40a4ffff  com.apple.IOAccelMemoryInfo (1.0 - 1) <3D55F378-81F0-3117-BD6A-5DFCED8C2134> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff40e7e000 -     0x7fff40e9cfff  libCGInterfaces.dylib (543) <B19C6E0A-C7B5-3CCC-A77F-9751CC30523E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff43487000 -     0x7fff436fdfff  com.apple.RawCamera.bundle (9.10.0 - 1410.3) <D38297EA-053D-38C8-BE73-58DDD60CA203> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff46108000 -     0x7fff46113fff  libGPUSupportMercury.dylib (18.0.50) <4C1A229D-40B0-34B5-9A8F-010DC9C73D67> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff47765000 -     0x7fff477b3fff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <5B713D10-3346-3AAD-A977-7095220E3C03> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
0x7fff4b7ef000 -     0x7fff4b7f2fff  com.apple.FinderSyncPriv (1.2 - 1350.1.1) <F0893C0A-334A-3AE8-9152-0614DF2D1017> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff51235000 -     0x7fff512c6fff  com.apple.Symbolication (12.2 - 64541.5.1) <640AAE2D-353D-3009-A7A2-55AE3F965398> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff5503c000 -     0x7fff5503ffff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <F6F92115-95DF-3D4B-B2DC-DAA9E312C36E> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff5c713000 -     0x7fff5c722fff  libSimplifiedChineseConverter.dylib (90) <4C051F8F-58BB-3A06-B5DD-4F9316DEBD60> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x7fff5d48a000 -     0x7fff5d91afff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (16.0.49 - 16.0.0) <657DC26F-6B7B-3744-B891-F88AFF9DE83C> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff5d91b000 -     0x7fff5e31efff  libSC.dylib (4.0.47) <A359A503-DFDB-3768-AF05-4027D993FABD> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
0x7fff5e663000 -     0x7fff5f646fff  com.apple.driver.AppleIntelKBLGraphicsGLDriver (16.0.49 - 16.0.0) <1DDAEEF2-ADA1-33EA-A22A-516FF79EFA60> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff68f38000 -     0x7fff68f3cfff  libmetal_timestamp.dylib (31001.152) <A294D124-55AA-3C01-B873-225B5717923D> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libmetal_timestamp.dylib
0x7fff6b3a6000 -     0x7fff6b3acfff  libCoreFSCache.dylib (177.22) <F2BD275B-0979-3426-BC9D-60C22E4FDE1C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff6b3ad000 -     0x7fff6b3b1fff  libCoreVMClient.dylib (177.22) <57E480B5-F430-3150-A5D9-D255A2F761E5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff6b3b2000 -     0x7fff6b3c1fff  com.apple.opengl (18.0.50 - 18.0.50) <245D7013-B161-397D-9989-500B639ECDF3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff6b3c2000 -     0x7fff6b3c4fff  libCVMSPluginSupport.dylib (18.0.50) <58937D53-04AE-36EA-AF04-A2C6EBD8D8EE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff6b3c5000 -     0x7fff6b3cdfff  libGFXShared.dylib (18.0.50) <8BCF166B-60FA-3321-83BB-24A3527B60A3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff6b3ce000 -     0x7fff6b401fff  libGLImage.dylib (18.0.50) <BD69E573-1813-3078-BF27-C9183B515647> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff6b402000 -     0x7fff6b43efff  libGLU.dylib (18.0.50) <21591978-F81A-3C62-9281-CD0ACDF8EEAC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff6b43f000 -     0x7fff6b5d3fff  libGLProgrammability.dylib (18.0.50) <C109BB0E-3E50-3DD4-9AD4-5A2D43594A72> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff6b5d4000 -     0x7fff6b5defff  libGL.dylib (18.0.50) <D2379B83-F70E-375A-AD7A-B612D767ABE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff6b5df000 -     0x7fff6b75afff  GLEngine (18.0.50) <D5643B63-5D23-3969-859E-042E4C252528> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff6b75b000 -     0x7fff6b784fff  GLRendererFloat (18.0.50) <07926815-F627-35B1-9722-003262ACAF16> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff6ca15000 -     0x7fff6ca6dfff  com.apple.opencl (4.5 - 4.5) <4387AA57-D726-3378-8376-E5D6813E219F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff6ca6e000 -     0x7fff6ca76fff  libcldcpuengine.dylib (2.19) <378F3D95-C79C-37D8-B394-54853403C0BD> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff6dc9d000 -     0x7fff6dcecfff  ATIRadeonX6000SCLib.dylib (4.0.47) <095A72A1-8FD7-3C78-B840-9399258AB97D> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
0x7fff6e4f3000 -     0x7fff6e515fff  com.apple.audio.OpenAL (1.8 - 1.8) <771F426F-2A9A-3BB7-9074-472E2AFA972E> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff6ee71000 -     0x7fff6ee7bfff  com.apple.AccessibilityBundles (1.0 - 172) <5C9FDE8E-3AD8-3BD0-846B-96F0C916BF5B> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff7837f000 -     0x7fff78386fff  libRosetta.dylib (203.1.3) <5EC28751-3BE8-3BB7-9DBE-305225CBD41B> /usr/lib/libRosetta.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 13
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 37264
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=4.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.1G(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1024K 8
Activity Tracing 256K 1
CG backing stores 7824K 18
CG image 1276K 19
CoreAnimation 172K 20
CoreGraphics 20K 4
CoreImage 8K 2
CoreUI image data 1444K 16
Dispatch continuations 96.0M 1
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 1.2G 254
MALLOC guard page 48K 10
MALLOC_LARGE (reserved) 1.2G 3 reserved VM address space (unallocated)
MALLOC_MEDIUM (reserved) 1.2G 12 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 220K 55
Stack 105.4M 56
VM_ALLOCATE 120.2M 14834
VM_ALLOCATE (reserved) 128.0M 1 reserved VM address space (unallocated)
CTF 759 1
DATA 91.6M 441
DATA_CONST 17.6M 217
DATA_DIRTY 919K 116
FONT_DATA 4K 1
GLSLBUILTINS 5176K 1
LINKEDIT 551.7M 77
OBJC_RO 61.0M 1
OBJC_RW 2468K 2
TEXT 508.9M 424
__UNICODE 588K 1
mapped file 116.1M 62
shared memory 40K 4
TOTAL 5.4G 16667
TOTAL, minus reserved VM space 2.9G 16667
Model: MacBookPro16,1, BootROM 1554.50.3.0.0 (iBridge: 18.16.12561.0.0,0), 6 processors, 6-Core Intel Core i7, 2.6 GHz, 32 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, -
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Sep 11 2020 17:01:15 version 9.30.440.2.32.5.61 FWID 01-1d69e4b4
Bluetooth: Version 8.0.1f5, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB3.1 Hub
USB Device: External USB 3.0
USB Device: USB 3.1 Bus
USB Device: USB2.0 Hub
USB Device: ZOWIE Gaming mouse
USB Device: USB-C Digital AV Multiport Adapter
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 58.1
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Dec 8 2020, 6:09 AM
This could be same issue as T70856.
See info in description:
Crash can be avoided by not using eGPU but integrated Graphic on Mac Mini, or Disable Monitor sleep function.
Can you check if this is the case?
Robert Guetzkow (rjg) closed this task as Archived.Dec 22 2020, 1:57 PM
