inset face bug
Operating system: windows 10
Graphics card: 1050ti
Broken: 2.92 alpha, 2.91
the outset operation in inset faces is giving depth to the mesh instead of outseting the face when giving thickness value ( showing in image 1)
the operation is working properly if executed after an inset operation ( showing in image 2)
This comment has been deleted.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Dec 8 2020, 7:17 PM
Thanks for the report, but unfortunately I did not understand the steps to reproduce the problem :\
But don't you have to run it at least once to change the properties in the Redo Panel?
Please follow our submission template and guidelines, also read these tips about bug reports to make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, etc.
Also explained here: https://www.youtube.com/watch?v=JTD0OJq_rF4
Hi
this is the problem. the face is suppose to outset but it is working wrongly
this is the situation when the operation is working properly. were you can see i inseted a face and iam able to outset the previously inseted face without any problem
Thanks for the report, but it's not a bug. The Outset option inserts faces into the selection's suround geometry:
https://docs.blender.org/manual/en/latest/modeling/meshes/editing/face/inset_faces.html#options
In each case the geometry around the selection is different.
ok thank you. the thing that confused me is that it is working as expected in the second video.
